I probably should have mentioned that in my first post. debug logging has been on since before bringing up the first link. Nothing in the logs regarding this.
Some additional information… the only client on this link, is a school. Their network guy is pretty vague about what applications they’re running over the link, but insists it’s wreaking havoc on database transactions, which is hard to believe from what I’ve been able to see in terms of overall performance and reliability.
Maybe I need to take a VOIP phone out there or haul my home PC to their site and play some counter-strike, which will actually let me hear or “feel” any jitter or dropped packets.
For just one leg of this… current AP configuration:
set 1 adaptive-noise-immunity=ap-and-client-mode allow-sharedkey=no antenna-gain=0 antenna-mode=ant-a area="" arp=enabled band=5ghz-a \
basic-rates-a/g=6Mbps bridge-mode=enabled burst-time=disabled channel-width=20mhz comment="" compression=no country=\
no_country_set default-ap-tx-limit=0 default-authentication=yes default-client-tx-limit=0 default-forwarding=yes dfs-mode=none \
disable-running-check=no disabled=no disconnect-timeout=3s distance=dynamic frame-lifetime=0 frequency=5180 frequency-mode=\
manual-txpower frequency-offset=0 hide-ssid=no hw-fragmentation-threshold=disabled hw-protection-mode=none \
hw-protection-threshold=0 hw-retries=10 l2mtu=2290 mac-address=00:15:6D:68:B7:F2 max-station-count=2007 mode=bridge mtu=1500 \
name=PTP_SPS noise-floor-threshold=default nv2-cell-radius=30 nv2-noise-floor-offset=default nv2-preshared-key="" nv2-qos=default \
nv2-queue-count=2 nv2-security=disabled on-fail-retry-time=100ms periodic-calibration=default periodic-calibration-interval=60 \
preamble-mode=both proprietary-extensions=post-2.9.25 radio-name=PTP_SPS rate-set=configured scan-list=default security-profile=\
default ssid=VZ-PTP-SPS station-bridge-clone-mac=00:00:00:00:00:00 supported-rates-a/g=6Mbps,9Mbps,12Mbps,18Mbps,24Mbps,36Mbps \
tdma-override-rate=disabled tdma-override-size=0 tdma-period-size=2 tx-power-mode=default update-stats-interval=disabled \
wds-cost-range=50-150 wds-default-bridge=bridge1 wds-default-cost=100 wds-ignore-ssid=no wds-mode=dynamic wireless-protocol=\
802.11 wmm-support=disabled
Current CPE config:
arp=enabled band=5ghz-a basic-rates-a/g=6Mbps bridge-mode=enabled burst-time=disabled \
channel-width=20mhz comment="" compression=no country=no_country_set default-ap-tx-limit=0 \
disable-running-check=no disabled=no disconnect-timeout=3s distance=dynamic frame-lifetime=0 \
frequency=5200 frequency-mode=manual-txpower frequency-offset=0 hide-ssid=no \
hw-fragmentation-threshold=disabled hw-protection-mode=none hw-protection-threshold=0 \
hw-retries=15 l2mtu=2290 mac-address=00:15:6D:68:B7:EF max-station-count=2007 mode=station-wds \
mtu=1500 name=BH-VZ noise-floor-threshold=default nv2-cell-radius=30 nv2-noise-floor-offset=\
default nv2-preshared-key="" nv2-qos=default nv2-queue-count=2 nv2-security=disabled \
preamble-mode=both proprietary-extensions=post-2.9.25 radio-name=SPS_BH-VZ rate-set=default \
scan-list=default security-profile=default ssid=VZ-PTP-SPS station-bridge-clone-mac=\
00:00:00:00:00:00 supported-rates-a/g=6Mbps,9Mbps,12Mbps,18Mbps,24Mbps,36Mbps,48Mbps,54Mbps \
tdma-override-rate=disabled tdma-override-size=0 tdma-period-size=2 tx-power-mode=default \
update-stats-interval=disabled wds-cost-range=50-150 wds-default-bridge=none wds-default-cost=\
100 wds-ignore-ssid=no wds-mode=disabled wireless-protocol=nv2-nstreme-802.11 wmm-support=\
disabled
CPE monitor:
status: connected-to-ess
band: 5ghz-a
frequency: 5180MHz
wireless-protocol: 802.11
tx-rate: "24.0Mbps"
rx-rate: "24.0Mbps"
ssid: "VZ-PTP-SPS"
bssid: 00:15:6D:68:B7:F2
radio-name: "PTP_SPS"
signal-strength: -70dBm
signal-strength-ch0: -70dBm
tx-signal-strength: -68dBm
noise-floor: -100dBm
signal-to-noise: 30dB
tx-ccq: 89%
rx-ccq: 100%
p-throughput: 18057
overall-tx-ccq: 89%
authenticated-clients: 1
current-distance: 5
wds-link: yes
nstreme: no
framing-mode: none
routeros-version: "4.17"
802.1x-port-enabled: yes
management-protection: no
compression: no
current-tx-powers: 6Mbps:27(17/27),9Mbps:27(17/27),12Mbps:27(17/27),18Mbps:27(17/27),
24Mbps:27(17/27),36Mbps:25(15/25),48Mbps:23(13/23),54Mbps:21(11/21)
notify-external-fdb: no
Monitor from AP:
[admin@VZ_BH-BMRS_PTP-SPS] > /int wi monitor 1 once
status: running-ap
band: 5ghz-a
frequency: 5180MHz
noise-floor: -97dBm
overall-tx-ccq: 100%
registered-clients: 1
current-distance: 5
current-tx-powers: 6Mbps:27(17/27),9Mbps:27(17/27),12Mbps:27(17/27),18Mbps:27(17/27),24Mbps:27(17/27),36Mbps:25(15/25),
current-ofdm-errors: 402
notify-external-fdb: yes
