Hello
How i can track all my all users monthly payment if i have example 5000 users.
I have some questions about payment system.
What payment system you can suggest me?
I need payment system for my wired users not for wireless but for wired.
wired or wireless - makes no difference. User Manager, Radmanager are a couple of possibles? Depends on your billing period and how you control their ability to connect. We use User Manager and PayPal as that is very suitable for a Hotspot.
Usermanager IS configurable to fit with your own html style. Maybe you are thinking of the older UM v3.x ?
If you are billing monthly, and for customers to be switched off at 00:00 (midnight) when their credit is finished, then RadManager is a possibility.
Radmanager is let down by not having the same timing logic for billing as used by Hotspots. That is to say, if a client buys one hour of access, they get one hour. Instead Radmanager uses actual connected time. SO they could have many many years of access possibility, until eventually use up their total actually connected time of one hour. UM works perfectly for us because if a client buys one hour, they only get one hour from first login. We are modifying UM v4 to make it look like our other web pages so that the client doe snot even know they are using Mikrotik UM system. They will think they are using our own system.
Both UM and RadManger can control client speed, as long as the interface that the client connects to, is controlled via Radius AAA back to the billing system. Radius performs the AAA communications between the billing system and the remote router connecting the client. So, in this way, you can create a customer, set the upload/download speed and a simple queue will be created on Mikrotik to control the speed of the client when they connect.
My couple of examples were User manager and RadManager from DMASoft labs. There are more, these are not the only providers of a billing system for WISPs. You can use Google to find more!
You can also design your own FreeRadius based system if you wish to control Mikrotik APs and have your own customised front end for your customers.
