payment gateway
Hello
I want to add payment system, i want to use only that payment gateway which is supported by my cart, paypal isnot suppordet by my country.
My question.
  1. is it possible to connect from mysql to user manager to transfer requests?
or
  1. how a can add time (profile) from telnet using command line in userman v4?
    Thank you
It’s probably significantly easier to just not use user manager, but to use a standalone RADIUS server instead that directly connects to that database.
Which radius you suggest me?
FreeRADIUS is nice.
Thank you for fast helping
how many clients can work on free radius?
RADIUS just takes login requests and either accepts or denies them. It can handle hundreds of requests per minute. How many user accounts can be stored depends entirely on the database backend.
I bought license of mikrotik fo user manager, it will be great if i will find terminal command which adds time,
is there any solution to work with userman from mysql or send commands from terminal?
