paypal and Sign-up form
Hi Mikrotik Group
I thought a will give it a second chance ..
I went through your wiki you sent me. But it still does not work
i have now come to the form to see if there is some-one that can help me get PAYPAL and the login page to work …
the problem is that i have a hotel that wants to use the hotspot system, but they want the Sign-up form to come up first..
here i have exported my system to see if some-one see were i went wrong…
set 0 arp=enabled auto-negotiation=yes cable-settings=default comment="" disable-running-check=yes disabled=no full-duplex=yes mac-address=00:A0:C9:B1:7D:09 mtu=1500 name=WAN-1 \
    speed=100Mbps
set 1 arp=enabled auto-negotiation=yes cable-settings=default comment="" disable-running-check=yes disabled=no full-duplex=yes mac-address=00:50:DA:15:60:86 mtu=1500 name=WAN-2 \
    speed=100Mbps
set 2 arp=enabled auto-negotiation=yes cable-settings=default comment="" disable-running-check=yes disabled=no full-duplex=yes mac-address=00:19:E0:0D:1B:9A mtu=1500 name=WAN-3 \
    speed=100Mbps
set 3 arp=enabled auto-negotiation=yes cable-settings=default comment="" disable-running-check=yes disabled=no full-duplex=yes l2mtu=1600 mac-address=00:14:2A:8B:2F:46 mtu=1500 \
    name=LAN speed=100Mbps
set default authentication-types="" eap-methods=passthrough group-ciphers="" group-key-update=5m interim-update=0s management-protection=disabled management-protection-key="" \
    mode=none name=default radius-eap-accounting=no radius-mac-accounting=no radius-mac-authentication=no radius-mac-caching=disabled radius-mac-format=XX:XX:XX:XX:XX:XX \
    radius-mac-mode=as-username static-algo-0=none static-algo-1=none static-algo-2=none static-algo-3=none static-key-0="" static-key-1="" static-key-2="" static-key-3="" \
    static-sta-private-algo=none static-sta-private-key="" static-transmit-key=key-0 supplicant-identity=MikroTik tls-certificate=none tls-mode=no-certificates unicast-ciphers="" \
    wpa-pre-shared-key="" wpa2-pre-shared-key=""
/ip hotspot profile
set default dns-name="" hotspot-address=0.0.0.0 html-directory=hotspot http-cookie-lifetime=3d http-proxy=0.0.0.0:0 login-by=cookie,http-chap name=default rate-limit="" \
    smtp-server=0.0.0.0 split-user-domain=no use-radius=no add dns-name="" hotspot-address=10.5.50.1 html-directory=hotspot http-proxy=0.0.0.0:0 login-by=http-chap,http-pap name=hsprof1 nas-port-type=wireless-802.11 radius-accounting=yes \
    radius-default-domain="" radius-interim-update=received radius-location-id="" radius-location-name="" radius-mac-format=XX:XX:XX:XX:XX:XX rate-limit="" smtp-server=0.0.0.0 \
    split-user-domain=no use-radius=yes
/ip hotspot user profile
set default idle-timeout=none keepalive-timeout=2m name=default shared-users=1 status-autorefresh=1m transparent-proxy=no /ip ipsec proposal set default auth-algorithms=sha1 comment="" disabled=no enc-algorithms=3des lifetime=30m name=default pfs-group=modp1024 /ip pool add name=hs-pool-4 ranges=10.5.50.2-10.5.50.254 /ip dhcp-server add address-pool=hs-pool-4 authoritative=after-2sec-delay bootp-support=static disabled=no interface=LAN lease-time=1h name=dhcp1 /ip hotspot add address-pool=hs-pool-4 addresses-per-mac=2 disabled=no idle-timeout=5m interface=LAN keepalive-timeout=none name=hotspot1 profile=hsprof1 /port set 0 baud-rate=9600 data-bits=8 flow-control=none name=serial0 parity=none stop-bits=1 /ppp profile set default change-tcp-mss=yes comment="" name=default only-one=default use-compression=default use-encryption=default use-vj-compression=default set default-encryption change-tcp-mss=yes comment="" name=default-encryption only-one=default use-compression=default use-encryption=yes use-vj-compression=default /queue type set default kind=pfifo name=default pfifo-limit=50 set ethernet-default kind=pfifo name=ethernet-default pfifo-limit=50 set wireless-default kind=sfq name=wireless-default sfq-allot=1514 sfq-perturb=5 set synchronous-default kind=red name=synchronous-default red-avg-packet=1000 red-burst=20 red-limit=60 red-max-threshold=50 red-min-threshold=10 set hotspot-default kind=sfq name=hotspot-default sfq-allot=1514 sfq-perturb=5 set default-small kind=pfifo name=default-small pfifo-limit=10 /routing bgp instance set default as=65530 client-to-client-reflection=yes comment="" disabled=no ignore-as-path-len=no name=default out-filter="" redistribute-connected=no redistribute-ospf=no \
    redistribute-other-bgp=no redistribute-rip=no redistribute-static=no router-id=0.0.0.0 routing-table=""
/routing ospf instance
set default comment="" disabled=no distribute-default=never in-filter=ospf-in metric-bgp=auto metric-connected=20 metric-default=1 metric-other-ospf=auto metric-rip=20 \
    metric-static=20 name=default out-filter=ospf-out redistribute-bgp=no redistribute-connected=no redistribute-other-ospf=no redistribute-rip=no redistribute-static=no \
    router-id=0.0.0.0
/routing ospf area
set backbone area-id=0.0.0.0 comment="" disabled=no instance=default name=backbone type=default /routing ospf-v3 instance set default comment="" disabled=no distribute-default=never metric-bgp=auto metric-connected=20 metric-default=1 metric-other-ospf=auto metric-rip=20 metric-static=20 name=default \
    redistribute-bgp=no redistribute-connected=no redistribute-other-ospf=no redistribute-rip=no redistribute-static=no router-id=0.0.0.0 /routing ospf-v3 area set backbone area-id=0.0.0.0 comment="" disabled=no instance=default name=backbone type=default /snmp set contact="" enabled=no engine-boots=0 engine-id="" location="" time-window=15 trap-sink=0.0.0.0 trap-version=1 /snmp community set public address=0.0.0.0/0 authentication-password="" authentication-protocol=MD5 encryption-password="" encryption-protocol=DES name=public read-access=yes security=none \
    write-access=no
/system logging action
set memory memory-lines=100 memory-stop-on-full=no name=memory target=memory set disk disk-file-count=2 disk-file-name=log disk-lines-per-file=100 disk-stop-on-full=no name=disk target=disk set echo name=echo remember=yes target=echo set remote bsd-syslog=no name=remote remote=0.0.0.0:514 src-address=0.0.0.0 syslog-facility=daemon syslog-severity=auto target=remote /user group add comment="" name=read policy=local,telnet,ssh,reboot,read,test,winbox,password,web,sniff,sensitive,!ftp,!write,!policy
add comment="" name=write policy=local,telnet,ssh,reboot,read,write,test,winbox,password,web,sniff,sensitive,!ftp,!policy
add comment="" name=full policy=local,telnet,ssh,ftp,reboot,read,write,policy,test,winbox,password,web,sniff,sensitive
/interface bridge settings
set use-ip-firewall=no use-ip-firewall-for-pppoe=no use-ip-firewall-for-vlan=no /interface l2tp-server server set authentication=pap,chap,mschap1,mschap2 default-profile=default-encryption enabled=no max-mru=1460 max-mtu=1460 mrru=disabled /interface ovpn-server server set auth=sha1,md5 certificate=none cipher=blowfish128,aes128 default-profile=default enabled=no keepalive-timeout=60 mac-address=FE:CE:55:DB:F0:72 max-mtu=1500 mode=ip netmask=24 \
    port=1194 require-client-certificate=no /interface pptp-server server set authentication=mschap1,mschap2 default-profile=default-encryption enabled=no keepalive-timeout=30 max-mru=1460 max-mtu=1460 mrru=disabled /interface wireless align set active-mode=yes audio-max=-20 audio-min=-100 audio-monitor=00:00:00:00:00:00 filter-mac=00:00:00:00:00:00 frame-size=300 frames-per-second=25 receive-all=no ssid-all=no /interface wireless sniffer set channel-time=200ms file-limit=10 file-name="" memory-limit=10 multiple-channels=no only-headers=no receive-errors=no streaming-enabled=no streaming-max-rate=0 \
    streaming-server=0.0.0.0
/interface wireless snooper
set channel-time=200ms multiple-channels=yes receive-errors=no /ip accounting set account-local-traffic=no enabled=no threshold=256 /ip accounting web-access set accessible-via-web=no address=0.0.0.0/0 /ip address add address=10.5.50.1/24 broadcast=10.5.50.255 comment="hotspot network" disabled=no interface=LAN network=10.5.50.0 /ip dhcp-client add add-default-route=yes comment="" default-route-distance=0 disabled=no interface=WAN-3 use-peer-dns=yes use-peer-ntp=yes /ip dhcp-server config set store-leases-disk=5m /ip dhcp-server network add address=10.5.50.0/24 comment="hotspot network" gateway=10.5.50.1 /ip dns set allow-remote-requests=no cache-max-ttl=1w cache-size=2048KiB max-udp-packet-size=512 servers=192.168.88.1,10.5.0.202 /ip firewall connection tracking set enabled=yes generic-timeout=10m icmp-timeout=10s tcp-close-timeout=10s tcp-close-wait-timeout=10s tcp-established-timeout=1d tcp-fin-wait-timeout=10s tcp-last-ack-timeout=10s \
    tcp-syn-received-timeout=5s tcp-syn-sent-timeout=5s tcp-syncookie=no tcp-time-wait-timeout=10s udp-stream-timeout=3m udp-timeout=10s /ip firewall filter add action=passthrough chain=unused-hs-chain comment="place hotspot rules here" disabled=yes /ip firewall nat add action=passthrough chain=unused-hs-chain comment="place hotspot rules here" disabled=yes add action=masquerade chain=srcnat comment="masquerade hotspot network" disabled=no src-address=10.5.50.0/24 /ip firewall service-port set ftp disabled=no ports=21 set tftp disabled=no ports=69 set irc disabled=no ports=6667 set h323 disabled=no set sip disabled=no ports=5060,5061 set pptp disabled=no /ip hotspot service-port set ftp disabled=no ports=21 /ip hotspot user add comment="" disabled=no name=admin password=ovislink profile=default /ip neighbor discovery set WAN-1 discover=yes set WAN-2 discover=yes set WAN-3 discover=yes set LAN discover=yes /ip proxy set always-from-cache=no cache-administrator=webmaster cache-hit-dscp=4 cache-on-disk=no enabled=no max-cache-size=none max-client-connections=600 max-fresh-time=3d \
    max-server-connections=600 parent-proxy=0.0.0.0 parent-proxy-port=0 port=8080 serialize-connections=no src-address=0.0.0.0 /ip service set telnet address=0.0.0.0/0 disabled=no port=23 set ftp address=0.0.0.0/0 disabled=no port=21 set www address=0.0.0.0/0 disabled=no port=80 set ssh address=0.0.0.0/0 disabled=no port=22 set www-ssl address=0.0.0.0/0 certificate=none disabled=yes port=443 set api address=0.0.0.0/0 disabled=yes port=8728 set winbox address=0.0.0.0/0 disabled=no port=8291 /ip socks set connection-idle-timeout=2m enabled=no max-connections=200 port=1080 /ip traffic-flow set active-flow-timeout=30m cache-entries=4k enabled=no inactive-flow-timeout=15s interfaces=all /ip upnp set allow-disable-external-interface=yes enabled=no show-dummy-rule=yes
/ipv6 nd
add advertise-dns=no advertise-mac-address=yes disabled=no hop-limit=unspecified interface=all managed-address-configuration=no mtu=unspecified other-configuration=no ra-delay=3s \
    ra-interval=3m20s-10m ra-lifetime=30m reachable-time=unspecified retransmit-interval=unspecified
/ipv6 nd prefix default
set autonomous=yes preferred-lifetime=1w valid-lifetime=4w2d /mpls set dynamic-label-range=16-1048575 propagate-ttl=yes /mpls interface add comment="" disabled=no interface=all mpls-mtu=1508 /mpls ldp set distribute-for-default-route=no enabled=no hop-limit=255 loop-detect=no lsr-id=0.0.0.0 path-vector-limit=255 transport-address=0.0.0.0 use-explicit-null=no /ppp aaa set accounting=yes interim-update=0s use-radius=yes /queue interface set WAN-1 queue=ethernet-default set WAN-2 queue=ethernet-default set WAN-3 queue=ethernet-default set LAN queue=ethernet-default /radius add accounting-backup=no accounting-port=1813 address=192.168.88.249 authentication-port=1812 called-id="" comment="" disabled=no domain="" realm="" secret=123456 service=hotspot \
    timeout=300ms
/radius incoming
set accept=yes port=3799
/routing bfd interface
set all comment="" disabled=no interface=all interval=0.2sec min-rx=0.2sec multiplier=5 /routing igmp-proxy set query-interval=2m5s query-response-interval=10s quick-leave=no /routing mme set bidirectional-timeout=2 gateway-class=none gateway-keepalive=1m gateway-selection=no-gateway origination-interval=5s preferred-gateway=0.0.0.0 timeout=1m ttl=50 /routing pim set switch-to-spt=yes switch-to-spt-bytes=0 switch-to-spt-interval=1m40s /routing rip set distribute-default=never garbage-timer=2m metric-bgp=1 metric-connected=1 metric-default=1 metric-ospf=1 metric-static=1 redistribute-bgp=no redistribute-connected=no \
    redistribute-ospf=no redistribute-static=no routing-table=main timeout-timer=3m update-timer=30s /routing ripng set distribute-default=never garbage-timer=2m metric-bgp=1 metric-connected=1 metric-default=1 metric-ospf=1 metric-static=1 redistribute-bgp=no redistribute-connected=no \
    redistribute-ospf=no redistribute-static=no timeout-timer=3m update-timer=30s /store add comment="" disabled=no disk=sata1 name=user-manager1 type=user-manager add comment="" disabled=no disk=sata1 name=web-proxy1 type=web-proxy /system clock set time-zone-name=manual /system clock manual set dst-delta=+00:00 dst-end="jan/01/1970 00:00:00" dst-start="jan/01/1970 00:00:00" time-zone=+00:00 /system console add disabled=no port=serial0 term=vt102 set [ find vcno=1 ] disabled=no term=linux set [ find vcno=2 ] disabled=no term=linux set [ find vcno=3 ] disabled=no term=linux set [ find vcno=4 ] disabled=no term=linux set [ find vcno=5 ] disabled=no term=linux set [ find vcno=6 ] disabled=no term=linux set [ find vcno=7 ] disabled=no term=linux set [ find vcno=8 ] disabled=no term=linux /system console screen set line-count=25 /system hardware set multi-cpu=yes /system health set state-after-reboot=enabled /system identity set name=MikroTik /system logging add action=memory disabled=no prefix="" topics=info add action=memory disabled=no prefix="" topics=error add action=memory disabled=no prefix="" topics=warning add action=echo disabled=no prefix="" topics=critical /system note set note="" show-at-login=yes /system ntp client set enabled=no mode=unicast primary-ntp=0.0.0.0 secondary-ntp=0.0.0.0 /system ntp server set broadcast=no enabled=no manycast=yes multicast=no /system routerboard bios set /system upgrade mirror set check-interval=1d enabled=no primary-server=0.0.0.0 secondary-server=0.0.0.0 user=""
/system watchdog
set auto-send-supout=no automatic-supout=yes no-ping-delay=5m watch-address=none watchdog-timer=yes /tool bandwidth-server set allocate-udp-ports-from=2000 authenticate=yes enabled=yes max-sessions=100 /tool e-mail set from=<> password="" server=41.204.200.49:25 username=""
/tool graphing
set page-refresh=300 store-every=5min
/tool mac-server
add disabled=no interface=all
/tool mac-server ping
set enabled=yes
/tool sms
set allowed-number="" channel=0 keep-max-sms=0 receive-enabled=no secret=""
/tool sniffer
set file-limit=10 file-name="" filter-address1=0.0.0.0/0:0-65535 filter-address2=0.0.0.0/0:0-65535 filter-protocol=ip-only filter-stream=yes interface=all memory-limit=10 \
    memory-scroll=no only-headers=no streaming-enabled=no streaming-server=0.0.0.0 /tool user-manager customer add backup-allowed=yes city=JHb comment="" company="Hotel" country="South Africa" currency=USD date-format=%b/%d/%Y disabled=no email=info@sandtonparkhotel.co.za \
    login=admin parent=admin password=123456 paypal-accept-pending=yes paypal-allowed=yes paypal-business-id=hotel@sawireless.co.za paypal-secure-response=yes permissions=owner \
    public-host=10.5.50.1 signup-allowed=yes time-zone=+02:00 add backup-allowed=no comment="" currency=ZAR disabled=no login=admin1 parent=admin password=123456 paypal-accept-pending=no paypal-allowed=no paypal-secure-response=no \
    permissions=full signup-allowed=yes time-zone=+02:00 /tool user-manager router add comment="" customer=admin disabled=no ip-address=192.168.88.249 log=auth-fail name=WAN shared-secret=123456 add comment="" customer=admin disabled=no ip-address=10.5.50.1 log=auth-fail name=LAN shared-secret=123456 /user aaa set accounting=yes default-group=read interim-update=0s use-radius=no
Regards
Joe
joe@sawireless.co.za
Hi,do you find any solution ?
Did you find the solution of the problem, I have a similar problem with you with a paypal page to load not only the party hotspot, I do not know what I’m doing wrong
