doush
November 4, 2008, 10:37am
1
On a 5 PCI slot x86 board we will put 5 mpci to PCI converters with 5 SR and XR series cards.
3 of them will serve as AP one will be used for backbone and one will be for failover.
Did anybody tried such a setup ? If so how it performs ?
Is there any problems with the mpci cards running next to each other in terms of intereference issues on a PC board ?
normis
November 4, 2008, 12:17pm
2
we tested 24 minipci cards, in a PC with 6xPCI slots, and each having a 4 slot miniPCI adapter inside
it worked fine heat wise, but I don’t know how it performs in real life situations
I had problems - had to reduce TX-power of the cards. So I suggest to go for less powerful cars for this setup and concentrate on more powerful antennas
normis
November 4, 2008, 12:21pm
4
better antenna is always better than power.
doush
November 4, 2008, 4:48pm
5
i will not use routerboard 14 or 18 but those 1 slot pc engines ones. Should i still use low power cards ?
what about SR or R52H ?
doush
November 8, 2008, 7:19pm
7
I have been searching the forum for 2 days and in 1 post it says that if i use 1 slot pci to mpci converters, I can use 400mW cards with no problems.
please help if u have further information on the topic.
thanks
normis
November 10, 2008, 12:26pm
8
what else do you want to know?
doush
November 10, 2008, 6:46pm
9
normis;
I want to know If i can use high power cards like SR5 or XR5 or R5H with those mpci to PCI converters (1 slot ones) ?
thanks
