Has anyone tested recent PC Engines APU2.C4 board with RouterOS? Basically, I can’t install it on board itself, setup always display: “FATAL ERROR: no harddrives found”.
I’ve tried to install ROS on mSATA disk on another PC but after placing it back to APU2 system tries to boot and I see loading and then whole board LEDs are going blank. If I put a network cable in any port it seems to be up but nothing is listening on it. I did some tests with SD card also but no good news here.
For those who may concern. I got it finally working after installing ROS on mSATA disk using USB adapter and virtual machine.
After moving system installed that way it booted on APU.2c4 straight away, doesn’t matter if BIOS was flashed with AHCI nor IDE, native driver.
Unfortunately, board is equipped with Intel i211AT gigabit ethernet cards which are not recongized by system (MikroTik guys why??). I’m using R52HnD wireless card which seem to work stable here. mSATA disk is recognized, SD card is not (no matter which card I put).
At this moment I’m using it with wireless access and KVM for testing so I will have more thoughts after a few weeks.
hi memphisgd
please update the current situation is it running smoothly with ROS? and PCIe and built-in card read not useful? am interested in this board .
