PC Engines APU3 series issues
did anyone had any success to boot this board with routerOS from an SD card?
netinstall cannot produce a bootable SD.
if i do the x86 iso boot installation in a VM, and installed RouterOS to the SD card there.
it started booting in the APU but hangs soon
PCEngines apu3
coreboot build 20170302
2032 MB DRAM
SeaBIOS (version rel-1.10.0.1)
Press F10 key now for boot menu
Booting from Hard Disk...
Loading system with initrd
the same happens with routeros installed on a USB stick
OK, finally managed to boot it from SATA. The process was the following:
  1. Created a VM in virtualbox with just a CD as mass storage device
  2. added the sata drive to it via an USB-to-SATA adapter as USB mass storage device under settings / ports / usb
  3. booted the ISO image downloaded from mikrotik.com
  4. finish installation as per screen instructions
  5. safely disconnect the USB disk from the computer
then connect it to the SATA port on the APU board, connect console, set your terminal emulator’s rate to 115200.
routeros will boot, and seemingly hang after displaying loading.initrd message.
the console defaults to 9600 after routerOS has been booted. the usual 2 beeps confirm, that it is up and running.
so altogether i managed to install RouterOS on it, but this was like a conversation with Zuzu Petals.
after login i was greeted with an empty device:
[admin@MikroTik] > /sys resource pci print detail
 0 device="04:00.0" name="BCM4328 802.11a/b/g/n (rev: 3)"
   vendor="Broadcom Corporation" category="Network controller"
   vendor-id="0x14e4" device-id="0x4328" irq=0
   memory=0xFE800000-0xFE8FFFFF,0xFE700000-0xFE7FFFFF
 1 device="03:00.0" name="unknown device (rev: 3)" vendor="Intel Corporation"
   category="Ethernet controller" vendor-id="0x8086" device-id="0x1539" irq=0
   memory=0xFE600000-0xFE6FFFFF,0xFE620000-0xFE623FFF io=0x3000-0x3FFF
 2 device="02:00.0" name="unknown device (rev: 3)" vendor="Intel Corporation"
   memory=0xFE500000-0xFE5FFFFF,0xFE520000-0xFE523FFF io=0x2000-0x2FFF
 3 device="01:00.0" name="unknown device (rev: 3)" vendor="Intel Corporation"
   memory=0xFE400000-0xFE4FFFFF,0xFE420000-0xFE423FFF io=0x1000-0x1FFF
 4 device="00:18.5" name="unknown device (rev: 0)"
   vendor="Advanced Micro Devices [AMD]" category="Host bridge"
   vendor-id="0x1022" device-id="0x1585" irq=0
 5 device="00:18.4" name="unknown device (rev: 0)"
   vendor-id="0x1022" device-id="0x1584" irq=0
 6 device="00:18.3" name="unknown device (rev: 0)"
   vendor-id="0x1022" device-id="0x1583" irq=0
 7 device="00:18.2" name="unknown device (rev: 0)"
   vendor-id="0x1022" device-id="0x1582" irq=0
 8 device="00:18.1" name="unknown device (rev: 0)"
   vendor-id="0x1022" device-id="0x1581" irq=0
 9 device="00:18.0" name="unknown device (rev: 0)"
   vendor-id="0x1022" device-id="0x1580" irq=0
10 device="00:14.7" name="unknown device (rev: 1)"
   vendor="Advanced Micro Devices [AMD]" category="SD Host controller"
   vendor-id="0x1022" device-id="0x7813" irq=0 memory=0xFEB25600-0xFEB256FF
11 device="00:14.3" name="unknown device (rev: 17)"
   vendor="Advanced Micro Devices [AMD]" category="ISA bridge"
   vendor-id="0x1022" device-id="0x780e" irq=0
12 device="00:14.0" name="unknown device (rev: 66)"
   vendor="Advanced Micro Devices [AMD]" category="SMBus" vendor-id="0x1022"
   device-id="0x780b" irq=0
13 device="00:13.0" name="unknown device (rev: 57)"
   vendor="Advanced Micro Devices [AMD]" category="USB Controller"
   vendor-id="0x1022" device-id="0x7808" irq=0 memory=0xFEB25500-0xFEB255FF
14 device="00:12.0" name="unknown device (rev: 57)"
   vendor-id="0x1022" device-id="0x7808" irq=0 memory=0xFEB25400-0xFEB254FF
15 device="00:11.0" name="unknown device (rev: 64)"
   vendor="Advanced Micro Devices [AMD]" category="SATA controller"
   vendor-id="0x1022" device-id="0x7800" irq=0 memory=0xFEB25000-0xFEB253FF
   io=0x4000-0x400F
16 device="00:10.0" name="unknown device (rev: 17)"
   vendor-id="0x1022" device-id="0x7814" irq=0 memory=0xFEB22000-0xFEB23FFF
17 device="00:08.0" name="unknown device (rev: 0)"
   vendor="Advanced Micro Devices [AMD]" category="Encryption controller"
   vendor-id="0x1022" device-id="0x1537" irq=0
   memory=0xFEB00000-0xFEB1FFFF,0xFE900000-0xFE9FFFFF,0xFEB24000-0xFEB24FFF,
       0xFEA00000-0xFEAFFFFF,0xFEB20000-0xFEB21FFF
18 device="00:02.5" name="unknown device (rev: 0)"
   vendor="Advanced Micro Devices [AMD]" category="PCI bridge"
   vendor-id="0x1022" device-id="0x1439" irq=0 io=0x1F0-0x1F7
19 device="00:02.4" name="unknown device (rev: 0)"
20 device="00:02.3" name="unknown device (rev: 0)"
21 device="00:02.2" name="unknown device (rev: 0)"
22 device="00:02.0" name="unknown device (rev: 0)"
   vendor-id="0x1022" device-id="0x156b" irq=0
23 device="00:00.0" name="unknown device (rev: 0)"
   vendor-id="0x1022" device-id="0x1566" irq=0
[admin@MikroTik] > /interface print
 #     NAME                                TYPE       ACTUAL-MTU L2MTU
[admin@MikroTik] > /sys resource irq print
Flags: ro - read-only
 #    IRQ USERS                                    CPU ACTIVE-CPU         COUNT
 0 ro   4 serial                                  auto                    1 279
 1      9 acpi                                    auto          0             0
 2     14 ide0                                    auto          1             0
 3     15 ide1                                    auto          2             0
 4     18 usb2                                    auto          3            44
          usb1
 5     19 ahci                                    auto          0         5 432
[admin@MikroTik] > /sys resource cpu print detail
 0 cpu="cpu0" load=0% irq=0% disk=0%
 1 cpu="cpu1" load=0% irq=0% disk=0%
 2 cpu="cpu2" load=0% irq=0% disk=0%
 3 cpu="cpu3" load=0% irq=0% disk=0%
[admin@MikroTik] > /sys reso print
                   uptime: 4m5s
                  version: 6.43rc12 (testing)
               build-time: May/11/2018 09:08:21
              free-memory: 1873.5MiB
             total-memory: 1893.7MiB
                      cpu: AMD
                cpu-count: 4
            cpu-frequency: 998MHz
                 cpu-load: 0%
           free-hdd-space: 14.7GiB
          total-hdd-space: 14.8GiB
  write-sect-since-reboot: 2280
         write-sect-total: 2280
        architecture-name: x86
               board-name: x86
                 platform: MikroTik
[admin@MikroTik] > /sys health print
               state: disabled
  state-after-reboot: enabled
[admin@MikroTik] > /system hardware print
  multi-cpu: yes
[admin@MikroTik] > /sys routerboard print
  routerboard: no
that is no external USB support, no ethernet support. whatever supported mPCIe cards you insert they will probably work though. but without wired ethernet support, this is just cumbersome.
only the internal USB headers work:
[admin@MikroTik] >  /sys resource usb print
 # DEVICE VENDOR                   NAME                  SPEED
 0 1-0    Linux 3.3.5-smp ehci_hcd EHCI Host Controller  480
 1 2-0    Linux 3.3.5-smp ehci_hcd EHCI Host Controller  480
 2 1-1                                                   480
 3 2-1                                                   480
 4 1-1.3  Generic                  USB EDC               480
[admin@MikroTik] > /disk print
 # NAME            LABEL           TYPE    DISK                 FREE       SIZE
 0 disk1           NO NAME         fat32   USB EDC          475.5MiB   486.3MiB
the external ones seem to be USB3.0, by the way. also, the SD card slot is directly driven by the SOC, so this is not a regular USB-to-SD bridge, hence it is not supported.
