hi
this is the result after i eter comand:
[admin@MINARAT] > / interface wireless export
# jan/01/2002 19:11:37 by RouterOS 2.9.50
# software id = C2CW-LJT
set wlan1 name="wlan1" mtu=1500 mac-address=00:0C:42:18:10:64 arp=enabled \
disable-running-check=no radio-name="000C42181064" mode=ap-bridge \
ssid="minarat" area="" frequency-mode=manual-txpower \
country=no_country_set antenna-gain=0 frequency=2412 band=2.4ghz-b/g \
scan-list=default rate-set=default \
supported-rates-b=1Mbps,2Mbps,5.5Mbps,11Mbps \
supported-rates-a/g=6Mbps,9Mbps,12Mbps,18Mbps,24Mbps,36Mbps,48Mbps,54Mbps \
basic-rates-b=1Mbps basic-rates-a/g=6Mbps max-station-count=2007 \
ack-timeout=dynamic tx-power-mode=default noise-floor-threshold=default \
periodic-calibration=default periodic-calibration-interval=60 \
burst-time=disabled dfs-mode=none antenna-mode=ant-a wds-mode=dynamic \
wds-default-bridge=bridge1 wds-default-cost=100 wds-cost-range=50-150 \
wds-ignore-ssid=no update-stats-interval=disabled \
default-authentication=yes default-forwarding=yes default-ap-tx-limit=0 \
default-client-tx-limit=0 proprietary-extensions=post-2.9.25 hide-ssid=no \
security-profile=device2 disconnect-timeout=3s on-fail-retry-time=100ms \
hw-retries=15 preamble-mode=both compression=no allow-sharedkey=no \
comment="HAPPYDADDY" disabled=no
set wlan2 name="wlan2" mtu=1500 mac-address=00:15:6D:63:27:7D arp=enabled \
disable-running-check=no radio-name="00156D63277D" mode=ap-bridge \
ssid="loembridge" area="" frequency-mode=manual-txpower country="south \
africa" antenna-gain=0 frequency=5500 band=5ghz scan-list=default \
rate-set=default supported-rates-a/g=6Mbps,9Mbps,12Mbps,18Mbps,24Mbps,36Mbp\
s,48Mbps,54Mbps basic-rates-a/g=6Mbps max-station-count=2007 \
security-profile=default disconnect-timeout=3s on-fail-retry-time=100ms \
hw-retries=15 preamble-mode=long compression=no allow-sharedkey=no \
comment="PARROW" disabled=no
set wlan3 name="wlan3" mtu=1500 mac-address=00:0C:42:1F:3B:2D arp=enabled \
disable-running-check=no radio-name="000C421F3B2D" mode=ap-bridge \
ssid="loem.za.org" area="" frequency-mode=manual-txpower \
country=no_country_set antenna-gain=0 frequency=5260 band=5ghz \
comment="GRASSY PARK" disabled=no
set wlan4 name="wlan4" mtu=1500 mac-address=00:0B:6B:80:A5:8C arp=enabled \
disable-running-check=no radio-name="000B6B80A58C" mode=ap-bridge \
ssid="loem2" area="" frequency-mode=manual-txpower country=no_country_set \
antenna-gain=0 frequency=2447 band=2.4ghz-b/g scan-list=default \
rate-set=default supported-rates-b=1Mbps,2Mbps,5.5Mbps,11Mbps \
comment="OMNI PELICAN HEIGHTS" disabled=no
/ interface wireless nstreme
set wlan1 enable-nstreme=no enable-polling=yes framer-policy=none \
framer-limit=3200
set wlan2 enable-nstreme=no enable-polling=yes framer-policy=none \
framer-limit=3200
set wlan3 enable-nstreme=no enable-polling=yes framer-policy=none \
framer-limit=3200
set wlan4 enable-nstreme=no enable-polling=yes framer-policy=none \
framer-limit=3200
/ interface wireless manual-tx-power-table
set wlan1 manual-tx-powers=1Mbps:17,2Mbps:17,5.5Mbps:17,11Mbps:17,6Mbps:17,9Mbp\
s:17,12Mbps:17,18Mbps:17,24Mbps:17,36Mbps:17,48Mbps:17,54Mbps:17
set wlan2 manual-tx-powers=1Mbps:17,2Mbps:17,5.5Mbps:17,11Mbps:17,6Mbps:17,9Mbp\
set wlan3 manual-tx-powers=1Mbps:17,2Mbps:17,5.5Mbps:17,11Mbps:17,6Mbps:17,9Mbp\
set wlan4 manual-tx-powers=1Mbps:17,2Mbps:17,5.5Mbps:17,11Mbps:17,6Mbps:17,9Mbp\
/ interface wireless security-profiles
set default name="default" mode=none authentication-types="" \
unicast-ciphers="" group-ciphers="" wpa-pre-shared-key="" \
wpa2-pre-shared-key="" eap-methods=passthrough tls-mode=no-certificates \
tls-certificate=none static-algo-0=none static-key-0="" static-algo-1=none \
static-key-1="" static-algo-2=none static-key-2="" static-algo-3=none \
static-key-3="" static-transmit-key=key-0 static-sta-private-algo=none \
static-sta-private-key="" radius-mac-authentication=no group-key-update=5m
add name="device2" mode=none authentication-types="" unicast-ciphers="" \
group-ciphers="" wpa-pre-shared-key="" wpa2-pre-shared-key="" \
eap-methods=passthrough tls-mode=no-certificates tls-certificate=none \
static-algo-0=none static-key-0="" static-algo-1=none static-key-1="" \
static-algo-2=none static-key-2="" static-algo-3=none static-key-3="" \
/ interface wireless wds
/ interface wireless align
set frame-size=300 active-mode=yes receive-all=no \
audio-monitor=00:00:00:00:00:00 filter-mac=00:00:00:00:00:00 ssid-all=no \
frames-per-second=25 audio-min=-100 audio-max=-20
/ interface wireless snooper
set multiple-channels=yes channel-time=200ms receive-errors=no
/ interface wireless sniffer
set multiple-channels=no channel-time=200ms only-headers=no receive-errors=no \
memory-limit=10 file-name="" file-limit=10 streaming-enabled=no \
streaming-server=0.0.0.0 streaming-max-rate=0
i whould like to move away from wds please provide me best way to do this.
you should connect the AP bridge to the internet modem and all the five clients should be using station mode to read the ssid coming from the AP bridge and to connect to it .
The ap-bridge is on a Highsite and have more than one wireless card in it, connecting clients all around it (all not roaming clients, there equipement is fixed). there is no pc’s connected to the highsite only the mikrotik router. Also just to add i have 4 wireless cards in the highsite all connecting different clients around it. most client use cpe mikrotik. Also i am sharing my internet connection with the freinds and we use a local cap which allows us to surf locally in the modem and we dial rasspppoe to get to international websites. Our gatway is the modem 192.168.1.200
Hope i gave you enough info to set me on the right path.
thanks
