How do you check time session limit on a MT pc router?
session time for what ???
M.
my router is taking kicking me off often, the connection last for 3 to 4 mins. Is there anything to setup or change the session timing?
Claudia Rdz
what do you mean by
my router is taking kicking me off often, ?
Are you talking about HotSpot, PPP or about accessing the router ?
when I login in my session last few minutes
If you are talking about your winbox session, it can’t tolerate a bad connection and will drop you quick if you have an unreliable network connection to it (ie, connecting wirelessly with a poor signal).
