PCC 3WAN same gateway/ISP dynamic IP
Hi Folks,
first at all sorry for my bad englsich :slight_smile:
I have problems with an special config.
I need a config for loadbalancing PCC with thre WAN inputs and i used the sample https://wiki.mikrotik.com/wiki/Manual:PCC.
The problem ist I have the Same Gateway/ISP and dynamic IP adresses.
Can anybody help me
Best regards
Hannes Erber
Same gateway address can be solved using gateway=% syntax. And for dynamic addresses thereโ€™s DHCP lease script.
