Hi guys,
I’m new in this world of mikrotik. Im trying to make work pcc configuration with 4 wan to give internet to a port named lan. I follow this steps http://wiki.mikrotik.com/wiki/Manual:PCC but i cant reach outside internet using the port called lan. I read other sites, make some changes but still stuck. Don’t know what i am doing wrong. Can someone could give me some hints or advice to resolve this situation?
Thanks.
a little hint:
4 WAN = “wan1-pppoe”,“wan2-pppoe”,“wan3-pppoe”,“wan4-pppoe”
1 LAN = “lan”/ip route
add check-gateway=arp comment=“WAN 4 - Distance 1” disabled=no distance=1 dst-address=0.0.0.0/0 gateway=wan4-pppoe routing-mark=wan4
add check-gateway=arp comment=“WAN 3 - Distance 1” disabled=no distance=1 dst-address=0.0.0.0/0 gateway=wan3-pppoe routing-mark=wan3
add check-gateway=arp comment=“WAN 2 - Distance 1” disabled=no distance=1 dst-address=0.0.0.0/0 gateway=wan2-pppoe routing-mark=wan2
add check-gateway=arp comment=“WAN 1 - Distance 1” disabled=no distance=1 dst-address=0.0.0.0/0 gateway=wan1-pppoe routing-mark=wan1
add check-gateway=arp comment=“WAN 1 - Distance 2” disabled=no distance=2 dst-address=0.0.0.0/0 gateway=wan2-pppoe routing-mark=wan1
add check-gateway=arp comment=“WAN 2 - Distance 2” disabled=no distance=2 dst-address=0.0.0.0/0 gateway=wan3-pppoe routing-mark=wan2
add check-gateway=arp comment=“WAN 3 - Distance 2” disabled=no distance=2 dst-address=0.0.0.0/0 gateway=wan4-pppoe routing-mark=wan3
add check-gateway=arp comment=“WAN 4 - Distance 2” disabled=no distance=2 dst-address=0.0.0.0/0 gateway=wan1-pppoe routing-mark=wan4
add check-gateway=arp comment=“WAN 1 - Distance 3” disabled=no distance=3 dst-address=0.0.0.0/0 gateway=wan3-pppoe routing-mark=wan1
add check-gateway=arp comment=“WAN 2 - Distance 3” disabled=no distance=3 dst-address=0.0.0.0/0 gateway=wan4-pppoe routing-mark=wan2
add check-gateway=arp comment=“WAN 3 - Distance 3” disabled=no distance=3 dst-address=0.0.0.0/0 gateway=wan1-pppoe routing-mark=wan3
add check-gateway=arp comment=“WAN 4 - Distance 3” disabled=no distance=3 dst-address=0.0.0.0/0 gateway=wan2-pppoe routing-mark=wan4
add check-gateway=arp comment=“WAN 1 - Distance 4” disabled=no distance=4 dst-address=0.0.0.0/0 gateway=wan4-pppoe routing-mark=wan1
add check-gateway=arp comment=“WAN 2 - Distance 4” disabled=no distance=4 dst-address=0.0.0.0/0 gateway=wan1-pppoe routing-mark=wan2
add check-gateway=arp comment=“WAN 3 - Distance 4” disabled=no distance=4 dst-address=0.0.0.0/0 gateway=wan2-pppoe routing-mark=wan3
add check-gateway=arp comment=“WAN 4 - Distance 4” disabled=no distance=4 dst-address=0.0.0.0/0 gateway=wan3-pppoe routing-mark=wan4
add check-gateway=arp comment=“Default Route - Distance 1” disabled=no distance=1 dst-address=0.0.0.0/0 gateway=wan1-pppoe
add check-gateway=arp comment=“Default Route - Distance 2” disabled=no distance=2 dst-address=0.0.0.0/0 gateway=wan2-pppoe
add check-gateway=arp comment=“Default Route - Distance 3” disabled=no distance=3 dst-address=0.0.0.0/0 gateway=wan3-pppoe
add check-gateway=arp comment=“Default Route - Distance 4” disabled=no distance=4 dst-address=0.0.0.0/0 gateway=wan4-pppoe
add check-gateway=arp comment=“Static Route - WAN1” disabled=no distance=1 dst-address=0.0.0.0/0 gateway=wan1-pppoe routing-mark=static-wan1
add check-gateway=arp comment=“Static Route - WAN2” disabled=no distance=2 dst-address=0.0.0.0/0 gateway=wan2-pppoe routing-mark=static-wan2
add check-gateway=arp comment=“Static Route - WAN3” disabled=no distance=3 dst-address=0.0.0.0/0 gateway=wan3-pppoe routing-mark=static-wan3
add check-gateway=arp comment=“Static Route - WAN4” disabled=no distance=4 dst-address=0.0.0.0/0 gateway=wan4-pppoe routing-mark=static-wan4
/ip firewall mangle
add action=mark-connection chain=input comment=“Mark new inbound connection wan1” connection-state=new disabled=no in-interface=wan1-pppoe new-connection-mark=wan1 passthrough=yes
add action=mark-connection chain=input comment=“Mark new inbound connection wan2” connection-state=new disabled=no in-interface=wan2-pppoe new-connection-mark=wan2 passthrough=yes
add action=mark-connection chain=input comment=“Mark new inbound connection wan3” connection-state=new disabled=no in-interface=wan3-pppoe new-connection-mark=wan3 passthrough=yes
add action=mark-connection chain=input comment=“Mark new inbound connection wan4” connection-state=new disabled=no in-interface=wan4-pppoe new-connection-mark=wan4 passthrough=yes
add action=mark-connection chain=prerouting comment=“Mark established inbound connection wan1” connection-state=established disabled=no in-interface=wan1-pppoe new-connection-mark=wan1 passthrough=yes
add action=mark-connection chain=prerouting comment=“Mark established inbound connection wan2” connection-state=established disabled=no in-interface=wan2-pppoe new-connection-mark=wan2 passthrough=yes
add action=mark-connection chain=prerouting comment=“Mark established inbound connection wan3” connection-state=established disabled=no in-interface=wan3-pppoe new-connection-mark=wan3 passthrough=yes
add action=mark-connection chain=prerouting comment=“Mark established inbound connection wan4” connection-state=established disabled=no in-interface=wan4-pppoe new-connection-mark=wan4 passthrough=yes
add action=mark-connection chain=prerouting comment=“Mark related inbound connection wan1” connection-state=related disabled=no in-interface=wan1-pppoe new-connection-mark=wan1 passthrough=yes
add action=mark-connection chain=prerouting comment=“Mark related inbound connection wan2” connection-state=related disabled=no in-interface=wan2-pppoe new-connection-mark=wan2 passthrough=yes
add action=mark-connection chain=prerouting comment=“Mark related inbound connection wan3” connection-state=related disabled=no in-interface=wan3-pppoe new-connection-mark=wan3 passthrough=yes
add action=mark-connection chain=prerouting comment=“Mark related inbound connection wan4” connection-state=related disabled=no in-interface=wan4-pppoe new-connection-mark=wan4 passthrough=yes
add action=mark-routing chain=output comment=“Mark new inbound route wan1” connection-mark=wan1 disabled=no new-routing-mark=static-wan1 passthrough=no
add action=mark-routing chain=output comment=“Mark new inbound route wan2” connection-mark=wan2 disabled=no new-routing-mark=static-wan2 passthrough=no
add action=mark-routing chain=output comment=“Mark new inbound route wan3” connection-mark=wan3 disabled=no new-routing-mark=static-wan3 passthrough=no
add action=mark-routing chain=output comment=“Mark new inbound route wan4” connection-mark=wan4 disabled=no new-routing-mark=static-wan4 passthrough=no
add action=mark-connection chain=prerouting comment=“Mark traffic that isn’t local with PCC mark rand (4 possibilities) - option 1” connection-state=new disabled=no dst-address-type=!local in-interface=lan new-connection-mark=wan1_pcc_conn passthrough=yes per-connection-classifier=both-addresses:4/0
add action=mark-connection chain=prerouting comment=“Mark traffic that isn’t local with PCC mark rand (4 possibilities) - option 2” connection-state=new disabled=no dst-address-type=!local in-interface=lan new-connection-mark=wan2_pcc_conn passthrough=yes per-connection-classifier=both-addresses:4/1
add action=mark-connection chain=prerouting comment=“Mark traffic that isn’t local with PCC mark rand (4 possibilities) - option 3” connection-state=new disabled=no dst-address-type=!local in-interface=lan new-connection-mark=wan3_pcc_conn passthrough=yes per-connection-classifier=both-addresses:4/2
add action=mark-connection chain=prerouting comment=“Mark traffic that isn’t local with PCC mark rand (4 possibilities) - option 4” connection-state=new disabled=no dst-address-type=!local in-interface=lan new-connection-mark=wan4_pcc_conn passthrough=yes per-connection-classifier=both-addresses:4/3
add action=mark-connection chain=prerouting comment=“Mark established traffic that isn’t local with PCC mark rand (4 possibilities) - option 1” connection-state=established disabled=no dst-address-type=!local in-interface=lan new-connection-mark=wan1_pcc_conn passthrough=yes per-connection-classifier=both-addresses:4/0
add action=mark-connection chain=prerouting comment=“Mark established traffic that isn’t local with PCC mark rand (4 possibilities) - option 2” connection-state=established disabled=no dst-address-type=!local in-interface=lan new-connection-mark=wan2_pcc_conn passthrough=yes per-connection-classifier=both-addresses:4/1
add action=mark-connection chain=prerouting comment=“Mark established traffic that isn’t local with PCC mark rand (4 possibilities) - option 3” connection-state=established disabled=no dst-address-type=!local in-interface=lan new-connection-mark=wan3_pcc_conn passthrough=yes per-connection-classifier=both-addresses:4/2
add action=mark-connection chain=prerouting comment=“Mark established traffic that isn’t local with PCC mark rand (4 possibilities) - option 4” connection-state=established disabled=no dst-address-type=!local in-interface=lan new-connection-mark=wan4_pcc_conn passthrough=yes per-connection-classifier=both-addresses:4/3
add action=mark-connection chain=prerouting comment=“Mark related traffic that isn’t local with PCC mark rand (4 possibilities) - option 1” connection-state=related disabled=no dst-address-type=!local in-interface=lan new-connection-mark=wan1_pcc_conn passthrough=yes per-connection-classifier=both-addresses:4/0
add action=mark-connection chain=prerouting comment=“Mark related traffic that isn’t local with PCC mark rand (4 possibilities) - option 2” connection-state=related disabled=no dst-address-type=!local in-interface=lan new-connection-mark=wan2_pcc_conn passthrough=yes per-connection-classifier=both-addresses:4/1
add action=mark-connection chain=prerouting comment=“Mark related traffic that isn’t local with PCC mark rand (4 possibilities) - option 3” connection-state=related disabled=no dst-address-type=!local in-interface=lan new-connection-mark=wan3_pcc_conn passthrough=yes per-connection-classifier=both-addresses:4/2
add action=mark-connection chain=prerouting comment=“Mark related traffic that isn’t local with PCC mark rand (4 possibilities) - option 4” connection-state=related disabled=no dst-address-type=!local in-interface=lan new-connection-mark=wan4_pcc_conn passthrough=yes per-connection-classifier=both-addresses:4/3
add action=mark-routing chain=prerouting comment=“Mark routing for PCC mark - option 1” connection-mark=wan1_pcc_conn disabled=no new-routing-mark=wan1 passthrough=yes
add action=mark-routing chain=prerouting comment=“Mark routing for PCC mark - option 2” connection-mark=wan2_pcc_conn disabled=no new-routing-mark=wan2 passthrough=yes
add action=mark-routing chain=prerouting comment=“Mark routing for PCC mark - option 3” connection-mark=wan3_pcc_conn disabled=no new-routing-mark=wan3 passthrough=yes
add action=mark-routing chain=prerouting comment=“Mark routing for PCC mark - option 4” connection-mark=wan4_pcc_conn disabled=no new-routing-mark=wan4 passthrough=yes
add chain=srcnat out-interface=wan1-pppoe action=masquerade
add chain=srcnat out-interface=wan2-pppoe action=masquerade
add chain=srcnat out-interface=wan3-pppoe action=masquerade
add chain=srcnat out-interface=wan4-pppoe action=masquerade
