Hi
I have a PCC setup with a DHCP allocated default gateway on a cable modem connection,which is likely to change when a new DHCP IP address is allocated.
On a DSL PPPoe connection, it is easy to specify the PPPOe interface as the default gateway in PCC rules, but how I can do similar things for a DHCP allocated WAN connection?
At the moment, I can manually specify the default gateway for the cable modem connection and PCC works fine, but there is a risk of the DHCP allocated gateway changing…
