Good Day
I have setup PCC and Hotspot with different profiles (3 in total) each having their own address list tags.
I want to limit 2 of the profiles so that they may not access Wan1. All attempts have not worked 100%. I tired the following where “src-address-list=Staffs” is the variable for ISP1. This just seems to mess with mail and skype. Browsing still works. I tried the same on Nat, trying to have only ISP1 nat to “src-address-list=Staffs”. Again no luck.
[admin@MikroTik] /ip firewall mangle> pri
0 chain=prerouting action=accept dst-address=XX.XX.XX.140/30
src-address-list=Staffs hotspot=auth in-interface=LAN
1 chain=prerouting action=accept dst-address=192.168.XX.0/24 hotspot=auth
in-interface=LAN
2 chain=prerouting action=mark-connection new-connection-mark=ISP1_conn
passthrough=yes src-address-list=Staffs hotspot=auth in-interface=ISP1
connection-mark=no-mark
3 chain=prerouting action=mark-connection new-connection-mark=ISP2_conn
passthrough=yes hotspot=auth in-interface=ISP2 connection-mark=no-mark
4 chain=prerouting action=mark-connection new-connection-mark=ISP1_conn
passthrough=yes dst-address-type=!local src-address-list=Staffs
hotspot=auth in-interface=LAN connection-mark=no-mark
per-connection-classifier=both-addresses:2/0
5 chain=prerouting action=mark-connection new-connection-mark=ISP2_conn
passthrough=yes dst-address-type=!local hotspot=auth in-interface=LAN
connection-mark=no-mark per-connection-classifier=both-addresses:2/1
6 chain=prerouting action=mark-routing new-routing-mark=to_ISP1
passthrough=yes src-address-list=Staffs hotspot=auth in-interface=LAN
7 chain=prerouting action=mark-routing new-routing-mark=to_ISP2
passthrough=yes hotspot=auth in-interface=LAN connection-mark=ISP2_conn
8 chain=output action=mark-routing new-routing-mark=to_ISP1 passthrough=yes
src-address-list=Staffs hotspot=auth connection-mark=ISP1_conn
9 chain=output action=mark-routing new-routing-mark=to_ISP2 passthrough=yes
hotspot=auth connection-mark=ISP2_conn
Is there an easier way to do this?
Thanks in advance
