hello, I have a problem with pcc matcher just in the game Call of Duty is unable to connect to the servers, voip calls… however if I deactivate one of the wans works correctly, how can I force some traffic or some ip to always use the same wan?
This is my pcc config
/ ip address
add address=192.168.10.10/24 network=192.168.10.0 broadcast=192.168.10.255 interface=Local
add address=10.111.0.2/24 network=10.111.0.0 broadcast=10.111.0.255 interface=ether1
add address=10.112.0.2/24 network=10.112.0.0 broadcast=10.112.0.255 interface=ether2/ ip firewall mangle
add chain=input in-interface=ether1 action=mark-connection new-connection-mark=ether1_conn
add chain=input in-interface=ether2 action=mark-connection new-connection-mark=ether2_conn
add chain=output connection-mark=ether1_conn action=mark-routing new-routing-mark=to_ether1
add chain=output connection-mark=ether2_conn action=mark-routing new-routing-mark=to_ether2
add chain=prerouting dst-address=10.111.0.0/24 action=accept in-interface=Local
add chain=prerouting dst-address=10.112.0.0/24 action=accept in-interface=Local
add chain=prerouting dst-address-type=!local in-interface=Local per-connection-classifier=both-addresses:2/0
action=mark-connection new-connection-mark=ether1_conn passthrough=yes
add chain=prerouting dst-address-type=!local in-interface=Local per-connection-classifier=both-addresses:2/1
action=mark-connection new-connection-mark=ether2_conn passthrough=yes
add chain=prerouting connection-mark=ether1_conn in-interface=Local action=mark-routing new-routing-mark=to_ether1
add chain=prerouting connection-mark=ether2_conn in-interface=Local action=mark-routing new-routing-mark=to_ether2/ ip route
add dst-address=0.0.0.0/0 gateway=10.111.0.1 routing-mark=to_ether1 check-gateway=ping
add dst-address=0.0.0.0/0 gateway=10.112.0.1 routing-mark=to_ether2 check-gateway=ping
add dst-address=0.0.0.0/0 gateway=10.111.0.1 distance=1 check-gateway=ping
add dst-address=0.0.0.0/0 gateway=10.112.0.1 distance=2 check-gateway=ping/ ip firewall nat
add chain=srcnat out-interface=ether1 action=masquerade
add chain=srcnat out-interface=ether2 action=masquerade
thanks a lot
