Hi
I have a CCR1036-12G-4S. I have 3x VDSL lines connected on ether1, ether2 and ether3, with IPs: 192.168.1.1, 192.168.2.1, 192.168.3.1. I have bridged ether10,ether11 and ether12. I have connect my central AP link to ether12 from which I start my wireless network with more than 50 AP and stations (I use ubnt). I have setup on my mikrotik both hotspot and pppoe server and I use PCC load Balance. My problem is that even if I have 3 vdsl lines, load balance uses only the one of them. I’ve tried everything after reading and googling but I cannot find any solution for this issue, so I’m writing to this forum, hoping someone helps me.
Below is my setup:
IP > Firewall > Mangle:
0 ;;; Rule for passing to pppoe customers antennas
chain=prerouting action=accept src-address=172.19.0.0/22 dst-address=192.168.96.0/19 in-interface=br_hs
1 ;;; Rule for passing to pppoe customers antennas
chain=prerouting action=accept src-address=172.19.0.0/22 dst-address=10.10.0.0/22 in-interface=br_hs
2 ;;; Load Balance Setup
chain=prerouting action=accept dst-address=192.168.1.0/24 in-interface=br_hs
3 chain=prerouting action=accept dst-address=192.168.2.0/24 in-interface=br_hs
4 chain=prerouting action=accept dst-address=192.168.3.0/24 in-interface=br_hs
5 X chain=prerouting action=accept dst-address=192.168.4.0/24 in-interface=br_hs
6 X chain=prerouting action=accept dst-address=192.168.5.0/24 in-interface=br_hs
7 X chain=prerouting action=accept dst-address=192.168.6.0/24 in-interface=br_hs
8 X chain=prerouting action=accept dst-address=192.168.7.0/24 in-interface=br_hs
9 X chain=prerouting action=accept dst-address=192.168.8.0/24 in-interface=br_hs
10 X chain=prerouting action=accept dst-address=192.168.9.0/24 in-interface=br_hs
11 X chain=prerouting action=accept dst-address=192.168.10.0/24 in-interface=br_hs
12 chain=prerouting action=mark-connection new-connection-mark=wan1_conn passthrough=yes in-interface=pppoe-wan1 connection-mark=no-mark
13 chain=prerouting action=mark-connection new-connection-mark=wan2_conn passthrough=yes in-interface=pppoe-wan2 connection-mark=no-mark
14 chain=prerouting action=mark-connection new-connection-mark=wan3_conn passthrough=yes in-interface=pppoe-wan3 connection-mark=no-mark
15 X chain=prerouting action=mark-connection new-connection-mark=wan4_conn passthrough=yes in-interface=pppoe-wan4 connection-mark=no-mark
16 X chain=prerouting action=mark-connection new-connection-mark=wan5_conn passthrough=yes in-interface=pppoe-wan5 connection-mark=no-mark
17 X chain=prerouting action=mark-connection new-connection-mark=wan6_conn passthrough=yes in-interface=pppoe-wan6 connection-mark=no-mark
18 X chain=prerouting action=mark-connection new-connection-mark=wan7_conn passthrough=yes in-interface=pppoe-wan7 connection-mark=no-mark
19 X chain=prerouting action=mark-connection new-connection-mark=wan8_conn passthrough=yes in-interface=pppoe-wan8 connection-mark=no-mark
20 X chain=prerouting action=mark-connection new-connection-mark=wan9_conn passthrough=yes in-interface=pppoe-wan9 connection-mark=no-mark
21 X chain=prerouting action=mark-connection new-connection-mark=wan10_conn passthrough=yes in-interface=pppoe-wan10 connection-mark=no-mark
22 chain=prerouting action=mark-connection new-connection-mark=wan1_conn passthrough=yes dst-address-type=!local hotspot=auth in-interface=br_hs connection-mark=no-mark per-connection-classifier=dst-address-and-port:3/0
23 chain=prerouting action=mark-connection new-connection-mark=wan1_conn passthrough=yes dst-address-type=!local src-address-list=bypass hotspot=!auth in-interface=br_hs connection-mark=no-mark per-connection-classifier=dst-address-and-port:3/0
24 chain=prerouting action=mark-connection new-connection-mark=wan2_conn passthrough=yes dst-address-type=!local hotspot=auth in-interface=br_hs connection-mark=no-mark per-connection-classifier=dst-address-and-port:3/1
25 chain=prerouting action=mark-connection new-connection-mark=wan2_conn passthrough=yes dst-address-type=!local src-address-list=bypass hotspot="" in-interface=br_hs connection-mark=no-mark per-connection-classifier=dst-address-and-port:3/1
26 chain=prerouting action=mark-connection new-connection-mark=wan3_conn passthrough=yes dst-address-type=!local hotspot=auth in-interface=br_hs connection-mark=no-mark per-connection-classifier=dst-address-and-port:3/2
27 chain=prerouting action=mark-connection new-connection-mark=wan3_conn passthrough=yes dst-address-type=!local src-address-list=bypass hotspot="" in-interface=br_hs connection-mark=no-mark per-connection-classifier=dst-address-and-port:3/2
28 X chain=prerouting action=mark-connection new-connection-mark=wan4_conn passthrough=yes dst-address-type=!local hotspot=auth in-interface=br_hs connection-mark=no-mark per-connection-classifier=both-addresses:10/3
29 X chain=prerouting action=mark-connection new-connection-mark=wan5_conn passthrough=yes dst-address-type=!local hotspot=auth in-interface=br_hs connection-mark=no-mark per-connection-classifier=both-addresses:10/4
30 X chain=prerouting action=mark-connection new-connection-mark=wan6_conn passthrough=yes dst-address-type=!local hotspot=auth in-interface=br_hs connection-mark=no-mark per-connection-classifier=both-addresses:10/5
31 X chain=prerouting action=mark-connection new-connection-mark=wan7_conn passthrough=yes dst-address-type=!local hotspot=auth in-interface=br_hs connection-mark=no-mark per-connection-classifier=both-addresses:10/6
32 X chain=prerouting action=mark-connection new-connection-mark=wan8_conn passthrough=yes dst-address-type=!local hotspot=auth in-interface=br_hs connection-mark=no-mark per-connection-classifier=both-addresses:10/7
33 X chain=prerouting action=mark-connection new-connection-mark=wan9_conn passthrough=yes dst-address-type=!local hotspot=auth in-interface=br_hs connection-mark=no-mark per-connection-classifier=both-addresses:10/8
34 X chain=prerouting action=mark-connection new-connection-mark=wan10_conn passthrough=yes dst-address-type=!local hotspot=auth in-interface=br_hs connection-mark=no-mark per-connection-classifier=both-addresses:10/9
35 chain=prerouting action=mark-routing new-routing-mark=to_wan1 passthrough=yes in-interface=br_hs connection-mark=wan1_conn
36 chain=prerouting action=mark-routing new-routing-mark=to_wan2 passthrough=yes in-interface=br_hs connection-mark=wan2_conn
37 chain=prerouting action=mark-routing new-routing-mark=to_wan3 passthrough=yes in-interface=br_hs connection-mark=wan3_conn
38 X chain=prerouting action=mark-routing new-routing-mark=to_wan4 passthrough=yes in-interface=br_hs connection-mark=wan4_conn
39 X chain=prerouting action=mark-routing new-routing-mark=to_wan5 passthrough=yes in-interface=br_hs connection-mark=wan5_conn
40 X chain=prerouting action=mark-routing new-routing-mark=to_wan6 passthrough=yes in-interface=br_hs connection-mark=wan6_conn
41 X chain=prerouting action=mark-routing new-routing-mark=to_wan7 passthrough=yes in-interface=br_hs connection-mark=wan7_conn
42 X chain=prerouting action=mark-routing new-routing-mark=to_wan8 passthrough=yes in-interface=br_hs connection-mark=wan8_conn
43 X chain=prerouting action=mark-routing new-routing-mark=to_wan9 passthrough=yes in-interface=br_hs connection-mark=wan9_conn
44 X chain=prerouting action=mark-routing new-routing-mark=to_wan10 passthrough=yes in-interface=br_hs connection-mark=wan10_conn
45 chain=output action=mark-routing new-routing-mark=to_wan1 passthrough=yes connection-mark=wan1_conn
46 chain=output action=mark-routing new-routing-mark=to_wan2 passthrough=yes connection-mark=wan2_conn
47 chain=output action=mark-routing new-routing-mark=to_wan3 passthrough=yes connection-mark=wan3_conn
48 X chain=output action=mark-routing new-routing-mark=to_wan4 passthrough=yes connection-mark=wan4_conn
49 X chain=output action=mark-routing new-routing-mark=to_wan5 passthrough=yes connection-mark=wan5_conn
50 X chain=output action=mark-routing new-routing-mark=to_wan6 passthrough=yes connection-mark=wan6_conn
51 X chain=output action=mark-routing new-routing-mark=to_wan7 passthrough=yes connection-mark=wan7_conn
52 X chain=output action=mark-routing new-routing-mark=to_wan8 passthrough=yes connection-mark=wan8_conn
53 X chain=output action=mark-routing new-routing-mark=to_wan9 passthrough=yes connection-mark=wan9_conn
54 X chain=output action=mark-routing new-routing-mark=to_wan10 passthrough=yes connection-mark=wan10_conn
IP > Routes:
0 A S dst-address=0.0.0.0/0 gateway=pppoe-wan1 gateway-status=pppoe-wan1 reachable check-gateway=ping distance=1 scope=30 target-scope=10 routing-mark=to_wan1
1 A S dst-address=0.0.0.0/0 gateway=pppoe-wan2 gateway-status=pppoe-wan2 reachable check-gateway=ping distance=1 scope=30 target-scope=10 routing-mark=to_wan2
2 A S dst-address=0.0.0.0/0 gateway=pppoe-wan3 gateway-status=pppoe-wan3 reachable check-gateway=ping distance=1 scope=30 target-scope=10 routing-mark=to_wan3
3 S dst-address=0.0.0.0/0 gateway=pppoe-wan4 gateway-status=pppoe-wan4 unreachable check-gateway=ping distance=1 scope=30 target-scope=10 routing-mark=to_wan4
4 S dst-address=0.0.0.0/0 gateway=pppoe-wan5 gateway-status=pppoe-wan5 unreachable check-gateway=ping distance=1 scope=30 target-scope=10 routing-mark=to_wan5
5 S dst-address=0.0.0.0/0 gateway=pppoe-wan6 gateway-status=pppoe-wan6 unreachable check-gateway=ping distance=1 scope=30 target-scope=10 routing-mark=to_wan6
6 S dst-address=0.0.0.0/0 gateway=pppoe-wan7 gateway-status=pppoe-wan7 unreachable check-gateway=ping distance=1 scope=30 target-scope=10 routing-mark=to_wan7
7 S dst-address=0.0.0.0/0 gateway=pppoe-wan8 gateway-status=pppoe-wan8 unreachable check-gateway=ping distance=1 scope=30 target-scope=10 routing-mark=to_wan8
8 S dst-address=0.0.0.0/0 gateway=pppoe-wan9 gateway-status=pppoe-wan9 unreachable check-gateway=ping distance=1 scope=30 target-scope=10 routing-mark=to_wan9
9 S dst-address=0.0.0.0/0 gateway=pppoe-wan10 gateway-status=pppoe-wan10 unreachable check-gateway=ping distance=1 scope=30 target-scope=10 routing-mark=to_wan10
10 A S dst-address=0.0.0.0/0 gateway=pppoe-wan2 gateway-status=pppoe-wan2 reachable check-gateway=ping distance=1 scope=30 target-scope=10
11 S dst-address=0.0.0.0/0 gateway=pppoe-wan1 gateway-status=pppoe-wan1 reachable check-gateway=ping distance=2 scope=30 target-scope=10
12 S dst-address=0.0.0.0/0 gateway=pppoe-wan3 gateway-status=pppoe-wan3 reachable check-gateway=ping distance=3 scope=30 target-scope=10
13 S dst-address=0.0.0.0/0 gateway=pppoe-wan4 gateway-status=pppoe-wan4 unreachable check-gateway=ping distance=4 scope=30 target-scope=10
14 S dst-address=0.0.0.0/0 gateway=pppoe-wan5 gateway-status=pppoe-wan5 unreachable check-gateway=ping distance=5 scope=30 target-scope=10
15 S dst-address=0.0.0.0/0 gateway=pppoe-wan6 gateway-status=pppoe-wan6 unreachable check-gateway=ping distance=6 scope=30 target-scope=10
16 S dst-address=0.0.0.0/0 gateway=pppoe-wan7 gateway-status=pppoe-wan7 unreachable check-gateway=ping distance=7 scope=30 target-scope=10
17 S dst-address=0.0.0.0/0 gateway=pppoe-wan8 gateway-status=pppoe-wan8 unreachable check-gateway=ping distance=8 scope=30 target-scope=10
18 S dst-address=0.0.0.0/0 gateway=pppoe-wan9 gateway-status=pppoe-wan9 unreachable check-gateway=ping distance=9 scope=30 target-scope=10
19 S dst-address=0.0.0.0/0 gateway=pppoe-wan10 gateway-status=pppoe-wan10 unreachable check-gateway=ping distance=10 scope=30 target-scope=10
49 ADC dst-address=80.106.108.42/32 pref-src=94.64.235.220 gateway=pppoe-wan1,pppoe-wan3,pppoe-wan2 gateway-status=pppoe-wan1 reachable,pppoe-wan3 reachable,pppoe-wan2 reachable distance=0 scope=10
50 ADC dst-address=172.19.0.0/22 pref-src=172.19.0.1 gateway=br_hs gateway-status=br_hs reachable distance=0 scope=10
51 ADC dst-address=192.168.1.0/24 pref-src=192.168.1.254 gateway=ether1-wan1 gateway-status=ether1-wan1 reachable distance=0 scope=10
52 ADC dst-address=192.168.2.0/24 pref-src=192.168.2.254 gateway=ether2-wan2 gateway-status=ether2-wan2 reachable distance=0 scope=10
53 ADC dst-address=192.168.3.0/24 pref-src=192.168.3.254 gateway=ether3-wan3 gateway-status=ether3-wan3 reachable distance=0 scope=10
57 ADC dst-address=192.168.96.0/19 pref-src=192.168.96.1 gateway=br_hs gateway-status=br_hs reachable distance=0 scope=10
Could you please help me???
Thanks in advanced…
