Hello , i just want to know if im doing something wrong ,
i have used the PCC method to bond my 5x dsl lines.
all is balancing well but that is the problem , its only balancing it does not bond the lines.
Please have a look at my Script bellow and tell me if i can bond my dsl lines that i can get faster speed?
i have 5x 10Mbps lines but when do speed test i only het 8Mbps ballanced over the 5x dsl lines
add address=10.0.1.1/27 network=10.0.1.0 broadcast=10.0.1.31 interface=Local1
add address=192.168.0.1/24 network=192.168.0.0 broadcast=192.168.0.255 interface=Local2
add address=192.168.1.2/24 network=192.168.1.0 broadcast=192.168.1.255 interface=WAN1
add address=192.168.2.2/24 network=192.168.2.0 broadcast=192.168.2.255 interface=WAN2
add address=192.168.3.2/24 network=192.168.3.0 broadcast=192.168.3.255 interface=WAN3
add address=167.2.4.2/29 network=167.2.4.0 broadcast=167.2.4.7 interface=WAN4
add address=167.2.5.2/29 network=167.2.5.0 broadcast=167.2.5.7 interface=WAN5
/ip firewall mangle
add chain=input in-interface=WAN1 action=mark-connection new-connection-mark=WAN1_conn
add chain=input in-interface=WAN2 action=mark-connection new-connection-mark=WAN2_conn
add chain=input in-interface=WAN3 action=mark-connection new-connection-mark=WAN3_conn
add chain=input in-interface=WAN4 action=mark-connection new-connection-mark=WAN4_conn
add chain=input in-interface=WAN5 action=mark-connection new-connection-mark=WAN5_conn
add chain=output connection-mark=WAN1_conn action=mark-routing new-routing-mark=to_WAN1
add chain=output connection-mark=WAN2_conn action=mark-routing new-routing-mark=to_WAN2
add chain=output connection-mark=WAN3_conn action=mark-routing new-routing-mark=to_WAN3
add chain=output connection-mark=WAN4_conn action=mark-routing new-routing-mark=to_WAN4
add chain=output connection-mark=WAN5_conn action=mark-routing new-routing-mark=to_WAN5
add chain=prerouting dst-address=192.168.1.0/24 action=accept in-interface=Local2
add chain=prerouting dst-address=192.168.2.0/24 action=accept in-interface=Local2
add chain=prerouting dst-address=192.168.3.0/24 action=accept in-interface=Local2
add chain=prerouting dst-address=167.2.4.0/29 action=accept in-interface=Local2
add chain=prerouting dst-address=167.2.5.0/29 action=accept in-interface=Local2
add chain=prerouting dst-address-type=!local in-interface=Local2 per-connection-classifier=both-addresses-and-ports:5/0 action=mark-connection new-connection-mark=WAN1_conn passthrough=yes
add chain=prerouting dst-address-type=!local in-interface=Local2 per-connection-classifier=both-addresses-and-ports:5/1 action=mark-connection new-connection-mark=WAN2_conn passthrough=yes
add chain=prerouting dst-address-type=!local in-interface=Local2 per-connection-classifier=both-addresses-and-ports:5/2 action=mark-connection new-connection-mark=WAN3_conn passthrough=yes
add chain=prerouting dst-address-type=!local in-interface=Local2 per-connection-classifier=both-addresses-and-ports:5/3 action=mark-connection new-connection-mark=WAN4_conn passthrough=yes
add chain=prerouting dst-address-type=!local in-interface=Local2 per-connection-classifier=both-addresses-and-ports:5/4 action=mark-connection new-connection-mark=WAN5_conn passthrough=yes
add chain=prerouting connection-mark=WAN1_conn in-interface=Local2 action=mark-routing new-routing-mark=to_WAN1
add chain=prerouting connection-mark=WAN2_conn in-interface=Local2 action=mark-routing new-routing-mark=to_WAN2
add chain=prerouting connection-mark=WAN3_conn in-interface=Local2 action=mark-routing new-routing-mark=to_WAN3
add chain=prerouting connection-mark=WAN4_conn in-interface=Local2 action=mark-routing new-routing-mark=to_WAN4
add chain=prerouting connection-mark=WAN5_conn in-interface=Local2 action=mark-routing new-routing-mark=to_WAN5
add dst-address=0.0.0.0/0 gateway=192.168.1.1 routing-mark=to_WAN1 check-gateway=ping
add dst-address=0.0.0.0/0 gateway=192.168.2.1 routing-mark=to_WAN2 check-gateway=ping
add dst-address=0.0.0.0/0 gateway=192.168.3.1 routing-mark=to_WAN3 check-gateway=ping
add dst-address=0.0.0.0/0 gateway=167.2.4.1 routing-mark=to_WAN4 check-gateway=ping
add dst-address=0.0.0.0/0 gateway=167.2.5.1 routing-mark=to_WAN5 check-gateway=ping
add dst-address=0.0.0.0/0 gateway=192.168.1.1 distance=1 check-gateway=ping
add dst-address=0.0.0.0/0 gateway=192.168.2.1 distance=2 check-gateway=ping
add dst-address=0.0.0.0/0 gateway=192.168.3.1 distance=3 check-gateway=ping
add dst-address=0.0.0.0/0 gateway=167.2.4.1 distance=4 check-gateway=ping
add dst-address=0.0.0.0/0 gateway=167.2.5.1 distance=5 check-gateway=ping
add chain=srcnat out-interface=WAN1 action=masquerade
add chain=srcnat out-interface=WAN2 action=masquerade
add chain=srcnat out-interface=WAN3 action=masquerade
add chain=srcnat out-interface=WAN4 action=masquerade
add chain=srcnat out-interface=WAN5 action=masquerade
/ip dns set allow-remote-requests=yes cache-max-ttl=1w cache-size=5000KiB max-udp-packet-size=512 servers=192.168.1.1,192.168.2.1,8.8.8.8
