i have dell gx110 with 3 ethernet card and i confiegrd that to have pcc + hotspot
this option it is very good without hotspot
i have tow adsl line 2M+2M the same getway & dns
without hotspot i make download by tow line 450k/s
but with hotspot i canot do that
what is the proplem
it is my config
/ip hotspot profile
set default dns-name="" hotspot-address=0.0.0.0 html-directory=hotspot \
http-proxy=0.0.0.0:0 login-by=http-chap name=default rate-limit="" \
smtp-server=0.0.0.0 split-user-domain=no use-radius=no
add dns-name=www.net.com hotspot-address=10.1.1.1 html-directory=hotspot \
http-proxy=0.0.0.0:0 login-by=http-chap name=hsprof1 rate-limit="" \
/ip hotspot user profile
set default advertise=no idle-timeout=none keepalive-timeout=1m name=default \
open-status-page=always rate-limit=64K/200K shared-users=1 \
status-autorefresh=1m transparent-proxy=yes
add advertise=yes advertise-interval=1s,5s advertise-timeout=immediately \
advertise-url=http://10.1.1.1/radvert.html idle-timeout=none \
keepalive-timeout=2m name="net cut" open-status-page=http-login \
session-timeout=5m shared-users=unlimited status-autorefresh=1m \
add advertise=no idle-timeout=none keepalive-timeout=2m name=uprof1 \
open-status-page=always shared-users=1 status-autorefresh=1m \
add advertise=no idle-timeout=none keepalive-timeout=1m name=1M \
open-status-page=always rate-limit=40K/800K shared-users=1 \
add name=dhcp-pool-1 ranges=10.1.1.2-10.1.1.254
add address-pool=dhcp-pool-1 authoritative=after-2sec-delay bootp-support=\
static disabled=no interface="hotspot\r\
\n" lease-time=3d name=dhcp1
add address=10.1.1.1/24 broadcast=10.1.1.255 comment="added by setup" \
\n" network=10.1.1.0
add address=15.5.5.5/32 broadcast=15.5.5.5 comment="" disabled=no interface=\
"hotspot\r\
\n" network=15.5.5.5
add address=10.5.5.2/24 broadcast=10.5.5.255 comment="" disabled=no \
interface=wan2 network=10.5.5.0
add address=10.4.4.2/24 broadcast=10.4.4.255 comment="" disabled=no \
interface=wan1 network=10.4.4.0
set allow-remote-requests=yes cache-max-ttl=1w cache-size=2048KiB \
max-udp-packet-size=512 primary-dns=4.2.2.6 secondary-dns=4.2.2.3
/ip firewall mangle
add action=accept chain=prerouting comment="" disabled=no dst-address=\
10.4.4.1 in-interface="hotspot\r\
\n"
10.5.5.1 in-interface="hotspot\r\
\n"
add action=mark-connection chain=input comment=NET1 disabled=no in-interface=\
wan1 new-connection-mark=wan1_conn passthrough=yes
add action=mark-connection chain=output comment="" disabled=no dst-port=80 \
new-connection-mark=wan1_conn passthrough=yes per-connection-classifier=\
both-addresses-and-ports:2/0 protocol=tcp
add action=mark-connection chain=prerouting comment="" disabled=no \
dst-address-type=!local dst-port=80 in-interface=wan1 \
both-addresses:2/0 protocol=tcp
add action=mark-routing chain=prerouting comment="" connection-mark=wan1_conn \
disabled=no in-interface=wan1 new-routing-mark=to_wan1 passthrough=yes
add action=mark-routing chain=output comment="" connection-mark=wan1_conn \
disabled=no new-routing-mark=to_wan1 passthrough=yes
add action=mark-connection chain=input comment=NET2 disabled=no in-interface=\
wan2 new-connection-mark=wan2_conn passthrough=yes
hotspot=auth new-connection-mark=wan2_conn passthrough=yes \
per-connection-classifier=both-addresses-and-ports:2/1 protocol=tcp
dst-address-type=!local dst-port=80 in-interface=wan2 \
new-connection-mark=wan2_conn passthrough=yes per-connection-classifier=\
both-addresses:2/1 protocol=tcp
add action=mark-routing chain=prerouting comment="" connection-mark=wan2_conn \
disabled=no in-interface=wan2 new-routing-mark=to_wan2 passthrough=yes
add action=mark-routing chain=output comment="" connection-mark=wan2_conn \
disabled=no new-routing-mark=to_wan2 passthrough=yes
add action=passthrough chain=unused-hs-chain comment=\
"place hotspot rules here" disabled=yes
add action=masquerade chain=srcnat comment="masquerade hotspot network" \
disabled=no src-address=10.1.1.0/24
add action=masquerade chain=srcnat comment="" disabled=no out-interface=wan1
add action=masquerade chain=srcnat comment="" disabled=no out-interface=wan2
add check-gateway=ping comment="" disabled=no distance=2 dst-address=\
0.0.0.0/0 gateway=10.5.5.1 routing-mark=to_wan2 scope=30 target-scope=10
0.0.0.0/0 gateway=10.5.5.1 scope=30 target-scope=10
add check-gateway=ping comment="" disabled=no distance=1 dst-address=\
0.0.0.0/0 gateway=10.4.4.1 routing-mark=to_wan1 scope=30 target-scope=10
0.0.0.0/0 gateway=10.4.4.1 scope=30 target-scope=10
