Hello everyone how are you?
Please I need some help
I configured PCC according Mikrotik´s official guide but is not working please help.
ISP1: 300 Mbps
ISP2: 150 Mbps
My configuration
Columns: ADDRESS, NETWORK, INTERFACE
ADDRESS NETWORK INTERFACE
;;; ISP1
192.168.1.254/24 192.168.1.0 ether1
;;; ISP2
192.168.2.254/24 192.168.2.0 ether2
;;; LAN
192.168.88.254/24 192.168.88.0 bridge
MANGLE
Flags: X - disabled, I - invalid; D - dynamic
0 ;;; Block traceroute
chain=prerouting action=change-ttl new-ttl=increment:2 passthrough=yes
log=no log-prefix=""
1 ;;; Accept rule
chain=prerouting action=accept dst-address=192.168.1.0/24
in-interface-list=LAN log=no log-prefix=""
2 chain=prerouting action=accept dst-address=192.168.2.0/24
3 ;;; Mark-Connections
chain=prerouting action=mark-connection new-connection-mark=ISP1_conn
passthrough=no connection-mark=no-mark in-interface=ether1 log=no
log-prefix=""
4 chain=prerouting action=mark-connection new-connection-mark=ISP2_conn
passthrough=no connection-mark=no-mark in-interface=ether2 log=no
log-prefix=""
5 ;;; PCC
passthrough=no dst-address-type=!local connection-mark=no-mark
in-interface-list=LAN per-connection-classifier=both-addresses:2/0 log=no
log-prefix=""
6 chain=prerouting action=mark-connection new-connection-mark=ISP2_conn
in-interface-list=LAN per-connection-classifier=both-addresses:2/1 log=no
log-prefix=""
7 ;;; Mark-Routing
chain=prerouting action=mark-routing new-routing-mark=To_ISP1
passthrough=no connection-mark=ISP1_conn in-interface-list=LAN log=no
log-prefix=""
8 chain=prerouting action=mark-routing new-routing-mark=To_ISP2 passthrough=no>
connection-mark=ISP2_conn in-interface-list=LAN log=no log-prefix=""
9 ;;; Output Connections
chain=output action=mark-routing new-routing-mark=To_ISP1 passthrough=no
connection-mark=ISP1_conn log=no log-prefix=""
10 chain=output action=mark-routing new-routing-mark=To_ISP2 passthrough=no
connection-mark=ISP2_conn log=no log-prefix=""
ROUTES
DST-ADDRESS GATEWAY DISTANCE
;;; Default route ISP1
0 s 0.0.0.0/0 192.168.1.1 1
;;; Default route ISP2
1 As 0.0.0.0/0 192.168.2.1 2
;;; PCC to ISP1
2 As 0.0.0.0/0 192.168.1.1 1 To_ISP1
;;; PCC to ISP2
3 As 0.0.0.0/0 190.147.134.1 1 To_ISP2
DAc 192.168.1.0/24 ether1 0
DAc 192.168.2.0/24 ether2 0
DAc 192.168.10.0/24 vlan10 0
DAc 192.168.20.0/24 vlan20 0
DAc 192.168.30.0/24 vlan30 0
DAc 192.168.88.0/24 bridge 0
NAT
0 ;;; defconf: masquerade
chain=srcnat action=masquerade out-interface=ether1 log=no log-prefix=""
ipsec-policy=out,none
1 ;;; defconf: masquerade
chain=srcnat action=masquerade out-interface=ether2 log=no log-prefix=""
FIREWALL
0 ;;; Port scan block rule
chain=input action=add-src-to-address-list protocol=tcp psd=21,3s,3,1
address-list=Port Scan Attackers address-list-timeout=1d log=no
log-prefix=""
1 ;;; Portscan block forward udp
chain=input action=add-src-to-address-list protocol=udp psd=21,3s,3,1
log-prefix=""
2 ;;; Portscan block forward tcp
chain=forward action=add-src-to-address-list protocol=tcp psd=21,3s,3,1
log-prefix=""
3 ;;; Portscan block forward udp
chain=forward action=add-src-to-address-list protocol=udp psd=21,3s,3,1
log-prefix=""
4 ;;; Portscan drop
chain=input action=drop src-address-list=Port Scan Attackers log=no
log-prefix=""
5 ;;; defconf: accept established,related,untracked
chain=input action=accept connection-state=established,related,untracked
6 X ;;; defconf: accept ICMP
chain=input action=accept protocol=icmp log=no log-prefix=""
7 ;;; defconf: accept to local loopback (for CAPsMAN)
chain=input action=accept dst-address=127.0.0.1 log=no log-prefix=""
8 X ;;; Allow IPSec from VPN server
chain=input action=accept protocol=udp in-interface-list=WAN
dst-port=500,4500,4510,4511 log=no log-prefix=""
9 X ;;; FTP
chain=input action=accept protocol=tcp in-interface=ether2 dst-port=21
10 ;;; Drop ICMP
chain=input action=drop protocol=icmp in-interface-list=WAN log=no
log-prefix=""
11 ;;; defconf: drop invalid
chain=input action=drop connection-state=invalid log=no log-prefix=""
12 ;;; defconf: drop invalid
chain=forward action=drop connection-state=invalid log=no log-prefix=""
13 ;;; defconf: drop all from WAN not DSTNATed
chain=forward action=drop connection-state=new
connection-nat-state=!dstnat in-interface-list=WAN log=no log-prefix=""
14 ;;; Drop bogons lists
chain=forward action=drop dst-address-list=Bogons log=no log-prefix=""
