pcc load balance dropping packets
hello everyone,
i am facing outlook disconnect every about 3 -5 minutes and reconnect automatically, mozila thunderbird is not sending email on first attempt (if email sent again after few seconds then it goes successfully). i think i am missing something in my script can anyone check my script(below) and tell me where the problem is?
i have 2 wan (50mb each) and using pcc method load balancing. i have a dhcp configured on interface=lan with 172.16.0.0/22
add address=172.16.0.1/22 network=172.16.0.0 broadcast=172.16.3.255 interface=Lan
add address=192.168.100.2/24 network=192.168.100.0 broadcast=192.168.100.255 interface=Wan1
add address=192.168.50.2/24 network=192.168.50.0 broadcast=192.168.50.255 interface=Wan2
/ip dns set allow-remote-requests=yes cache-max-ttl=1w cache-size=5000KiB max-udp-packet-size=512 servers=8.8.8.8
/ip firewall mangle
add chain=input in-interface=Wan1 action=mark-connection new-connection-mark=Wan1_conn
add chain=input in-interface=Wan2 action=mark-connection new-connection-mark=Wan2_conn
add chain=output connection-mark=Wan1_conn action=mark-routing new-routing-mark=to_Wan1
add chain=output connection-mark=Wan2_conn action=mark-routing new-routing-mark=to_Wan2
add chain=prerouting dst-address=192.168.50.0/24 action=accept in-interface=Lan
add chain=prerouting dst-address=192.168.100.0/24 action=accept in-interface=Lan
add chain=prerouting dst-address-type=!local in-interface=Lan per-connection-classifier=both-addresses-and-ports:2/0 action=mark-connection new-connection-mark=Wan1_conn passthrough=yes
add chain=prerouting dst-address-type=!local in-interface=Lan per-connection-classifier=both-addresses-and-ports:2/1 action=mark-connection new-connection-mark=Wan2_conn passthrough=yes
add chain=prerouting connection-mark=Wan1_conn in-interface=Lan action=mark-routing new-routing-mark=to_Wan1
add chain=prerouting connection-mark=Wan2_conn in-interface=Lan action=mark-routing new-routing-mark=to_Wan2
add dst-address=0.0.0.0/0 gateway=192.168.100.1 routing-mark=to_Wan1 check-gateway=ping
add dst-address=0.0.0.0/0 gateway=192.168.50.1 routing-mark=to_Wan2 check-gateway=ping
add dst-address=0.0.0.0/0 gateway=192.168.100.1 distance=1 check-gateway=ping
add dst-address=0.0.0.0/0 gateway=192.168.50.1 distance=2 check-gateway=ping
add chain=srcnat out-interface=Wan1 action=masquerade
add chain=srcnat out-interface=Wan2 action=masquerade
Start using connection-mark=no-mark like in https://wiki.mikrotik.com/wiki/Manual:PCC#Application_Example_-_Load_Balancing
I not see anything else bad here.
if you didnt see anything bad in the script then why my network is not so smooth? why the packets are dropping and why both wans are not equally utilizing the bandwidth, sometimes wan 1 is using full 50mb and wan 2 is 300kb , 400kb (see image attached)
https://wiki.mikrotik.com/wiki/How_PCC_works_(beginner)
The connectivity issues are from you not using per-connection-classifier=src-address, which is not the best option (every clients traffic will go out either through WAN1 OR WAN2) but it doesn’t break so many things like HTTPS and other services (Cisco Webex etc) that require you to make requests from one IP only.
Regarding the “load balance”, using only PCC you won’t be having a nice split of traffic over those two WANs, one user can watch some 4K stream and some other will be reading a forum, chances are that one will use WAN1 and the other WAN2 .. there’s no way those two will be equal in bandwidth.
