im new here at mikrotik and i need to work with pcc load balancing and i don’t know what i’m doing wrong with my configuration,
can someon give me the reason why my PCC load balance not working
here’s my mangle rules:
0 chain=prerouting action=accept dst-address=122.54.44.224/30 in-interface=bridge-Residential
1 chain=prerouting action=accept dst-address=103.236.166.32/30 in-interface=bridge-Residential
2 chain=prerouting action=mark-connection new-connection-mark=conn_WAN1 connection-mark=no-mark in-interface=bridge-WAN1
3 chain=prerouting action=mark-connection new-connection-mark=conn_WAN2 connection-mark=no-mark in-interface=bridge-WAN2
4 chain=prerouting action=mark-connection new-connection-mark=conn_WAN1 dst-address-type=!local connection-mark=no-mark in-interface=bridge-Residential
per-connection-classifier=both-addresses:2/0
5 chain=prerouting action=mark-connection new-connection-mark=conn_WAN2 dst-address-type=!local connection-mark=no-mark in-interface=bridge-Residential
per-connection-classifier=both-addresses:2/1
6 chain=prerouting action=mark-routing new-routing-mark=to_WAN1 connection-mark=conn_WAN1 in-interface=bridge-Residential
7 chain=prerouting action=mark-routing new-routing-mark=to_WAN2 connection-mark=conn_WAN2 in-interface=bridge-Residential
8 chain=output action=mark-routing new-routing-mark=to_WAN1 connection-mark=conn_WAN1
9 chain=output action=mark-routing new-routing-mark=to_WAN2 connection-mark=conn_WAN2
Here is the screenshot of the WAN connection
CZFan
May 25, 2018, 10:47am
2
Not enough info, i.e. no route / nat info.
On a side note, it is per connection based, so you will only see 2nd WAN used with 2nd connection
sorry
Here’s the route and nat
# DST-ADDRESS PREF-SRC GATEWAY DISTANCE
0 A S 0.0.0.0/0 122.54.44.225 1
1 A S 0.0.0.0/0 103.236.166.33 1
2 A S 0.0.0.0/0 122.54.44.225 1
3 S 0.0.0.0/0 103.236.166.33 2
4 ADC 103.236.166.32/30 103.236.166.34 bridge-WAN2 0
5 ADC 122.54.44.224/30 122.54.44.226 bridge-WAN1 0
6 ADC 172.16.0.0/19 172.16.0.1 bridge-Residential 0
1 chain=srcnat action=masquerade out-interface=bridge-WAN1 log=no log-prefix=""
2 chain=srcnat action=masquerade out-interface=bridge-WAN2 log=no log-prefix=""
CZFan
May 25, 2018, 5:44pm
4
Apologies, full of flu medication and struggling to concentrate.
I can’t see any issues though, from what I can see is that you basically have a exact config from the Wiki manual.
here is another source for the config, maybe read through this and see if it helps:
https://mum.mikrotik.com/presentations/US12/steve.pdf
sindy
May 26, 2018, 9:07am
5
I cannot see which routes use which routing marks, can you use /ip route export instead of /ip route print ?
Other than that, in chain=prerouting everyting seems fine, but in chain=output you only translate connection marks to routing marks but you do not assign the connection marks.
Sob
May 26, 2018, 12:47pm
6
Output uses connection marks set in prerouting (rules 2 and 3).
And I don’t see the problem either. It could be typo in route mark’s name (but we don’t see them).
sindy
May 26, 2018, 1:06pm
7
Is this picture wrong then?
If not, no packet can first pass through chain=prerouting and later through chain=output . Only chain=input and chain=forward come next to chain=prerouting .
Sob
May 26, 2018, 1:52pm
8
Picture it correct. Route marking in output is to reply back to connections from outside the right way. And connections initiated from router to outside first take default way unmarked, and first reply packet will get the connection marked.
sindy
May 26, 2018, 2:02pm
9
Correct, what I had in mind was that if the locally initiated connections should be load-balanced, the per-connection-classifier rule assigning a connection-mark would be necessary in chain=output as well.
sindy
May 26, 2018, 2:11pm
10
Other than that, I think we are all blind because passthrough=yes is missing in all action=mark-connection rules, and the default behaviour if the parameter is not provided is passthrough=no , so the initial packet of each outgoing connection from LAN is not routing-marked.
Sob
May 26, 2018, 11:46pm
11
Can I use that in WinBox, passthrough is checked by default, as excuse?
Dear i am facing the same issue with PCC posting my configuration if someone can help
set [ find default-name=ether1 ] comment="WAN "
set [ find default-name=ether2 ] comment="LAN "
set [ find default-name=ether3 ] comment=“Wireless LAN”
set [ find default-name=ether4 ] comment=“Executive LAN” disabled=yes
/interface vlan
add interface=ether1 name=GERRY-202.69.x.x-VLAN-60 vlan-id=60
add interface=ether1 name=PERN-121.52..x.x-VLAN-50 vlan-id=50
add interface=ether1 name=PTCL-172.20.10.1-Vlan-40 vlan-id=40
add interface=ether1 name=PTCL-192.168.1.1-VLAN-20 vlan-id=20
add name=WAN
add name=LAN
/queue simple
add burst-limit=55M/55M burst-time=3s/3s max-limit=50M/50M name=queue1 target=172.15.0.0/16
add burst-limit=50M/50M burst-time=3s/3s max-limit=50M/50M name=queue2 target=172.16.0.0/16
/interface detect-internet
set detect-interface-list=all
add interface=ether2 list=LAN
add interface=ether3 list=LAN
add address=172.15.5.13/16 comment=“Executive Gateway” disabled=yes interface=ether2 network=172.15.0.0
add address=172.15.6.250/16 comment=“Campus Gateway” interface=ether2 network=172.15.0.0
add address=192.168.1.23/24 interface=PTCL-192.168.1.1-VLAN-20 network=192.168.1.0
add address=202.69.x.x interface=GERRY-202.69.x.x-VLAN-60 network=202.69.x.x
add address=121.52.x.x comment=WAN-PERN interface=PERN-121.52.x.x-VLAN-50 network=121.52.x.x
add address=172.16.11.5/16 comment=“WIRELESS LAN” interface=ether3 network=172.16.0.0
add address=172.20.10.63/24 interface=PTCL-172.20.10.1-Vlan-40 network=172.20.10.0
set allow-remote-requests=yes servers=8.8.8.8,8.8.4.4
/ip firewall address-list
add address=172.15.5.1-172.16.5.254 list=“Campus Internet”
add address=172.15.4.30 list=Zain
add action=accept chain=input dst-port=80 in-interface=GERRY-202.69.x.x-VLAN-60 protocol=tcp
add action=accept chain=input dst-port=8291 in-interface=GERRY-202.69.x.x-VLAN-60 protocol=tcp
/ip firewall mangle
add action=accept chain=prerouting dst-address=172.15.0.0/16 in-interface-list=LAN
add action=accept chain=prerouting dst-address=172.16.0.0/16 in-interface-list=LAN
add action=accept chain=prerouting dst-address=121.52.152.x.x in-interface-list=LAN
add action=accept chain=prerouting dst-address=202.69.x.x in-interface-list=LAN
add action=accept chain=prerouting dst-address=192.168.1.0/24 in-interface-list=LAN
add action=accept chain=prerouting dst-address=172.20.10.0/24 in-interface-list=LAN
add action=mark-connection chain=prerouting connection-mark=no-mark in-interface=PTCL-192.168.1.1-VLAN-20
new-connection-mark=PTCL-192.168.1.1-VLAN-20 passthrough=yes
add action=mark-connection chain=prerouting connection-mark=no-mark in-interface=GERRY-202.69.x.x-VLAN-60
new-connection-mark=GERRY-202.69.x.x-VLAN-60 passthrough=yes
add action=mark-connection chain=prerouting connection-mark=no-mark in-interface=PERN-121.52.x.x-VLAN-50
new-connection-mark=PERN-121.52.x.x-VLAN-50 passthrough=yes
add action=mark-connection chain=prerouting connection-mark=no-mark in-interface=PTCL-172.20.10.1-Vlan-40
new-connection-mark=PTCL-172.20.10.1-Vlan-40 passthrough=yes
add action=mark-connection chain=prerouting connection-mark=no-mark dst-address-type=!local in-interface-list=LAN
new-connection-mark=GERRY-202.69.x.x-VLAN-60 passthrough=yes per-connection-classifier=both-addresses:4/3
new-connection-mark=PTCL-172.20.10.1-Vlan-40 passthrough=yes per-connection-classifier=src-address:4/2
new-connection-mark=PERN-121.52.x.x-VLAN-50 passthrough=yes per-connection-classifier=both-addresses:4/2
new-connection-mark=PTCL-192.168.1.1-VLAN-20 passthrough=yes per-connection-classifier=src-address:4/0
add action=mark-routing chain=prerouting connection-mark=PTCL-192.168.1.1-VLAN-20 in-interface-list=LAN
new-routing-mark=to_PTCL-192.168.1.1-VLAN-20 passthrough=yes
add action=mark-routing chain=prerouting connection-mark=PTCL-172.20.10.1-Vlan-40 in-interface-list=LAN
new-routing-mark=to_PTCL-172.20.10.1-Vlan-40 passthrough=yes
add action=mark-routing chain=prerouting connection-mark=GERRY-202.69.x.x-VLAN-60 in-interface-list=LAN
new-routing-mark=to_GERRY-202.69.x.x-VLAN-60 passthrough=yes
add action=mark-routing chain=prerouting connection-mark=PERN-121.52.x.x-VLAN-50 in-interface-list=LAN
new-routing-mark=to_PERN-121.52.x.x-VLAN-50 passthrough=yes
add action=mark-routing chain=output connection-mark=PTCL-192.168.1.1-VLAN-20 new-routing-mark=
add action=mark-routing chain=output connection-mark=GERRY-202.69.x.x-VLAN-60 new-routing-mark=
add action=mark-routing chain=output connection-mark=PERN-121.52.x.x-VLAN-50 new-routing-mark=
add action=mark-routing chain=output connection-mark=PTCL-172.20.10.1-Vlan-40 new-routing-mark=
add action=masquerade chain=srcnat out-interface=PTCL-172.20.10.1-Vlan-40
add action=masquerade chain=srcnat out-interface=PTCL-192.168.1.1-VLAN-20
add action=masquerade chain=srcnat out-interface=GERRY-202.69.x.x-VLAN-60
add action=masquerade chain=srcnat out-interface=PERN-121.52.x.x-VLAN-50
add check-gateway=ping distance=1 gateway=192.168.1.1 routing-mark=to_PTCL-192.168.1.1-VLAN-20
add check-gateway=ping distance=1 gateway=202.69.49.73 routing-mark=to_GERRY-202.69.x.x-VLAN-60
add check-gateway=ping distance=1 gateway=121.52.152.225 routing-mark=to_PERN-121.52.x.x-VLAN-50
add distance=1 gateway=172.20.10.1
add check-gateway=ping distance=2 gateway=192.168.1.1
add check-gateway=ping distance=2 gateway=202.69.x.x
add check-gateway=ping distance=2 gateway=121.52.x.x
/system clock
anav
August 2, 2021, 2:35pm
13
His method doesn’t work well in v7 for some reason, so the fix for me is to condense everything into rules that directly mark routes based on the PCC.
anav
August 3, 2021, 3:14pm
15
Thanks Cable, didnt realize it was for V7. Not sure if V7 is wrong and needs to be adjusted or MUM after V7 will produce an updated PCC presentation.
