Yes absolutely. Here is the info you requested. thanks.
/ip route> print detail
0 A S dst-address=0.0.0.0/0 gateway=70.76.0.1
gateway-status=70.76.0.1 reachable via WAN1 check-gateway=ping
distance=1 scope=30 target-scope=10 routing-mark=to_WAN1
1 A S dst-address=0.0.0.0/0 gateway=216.197.184.254
gateway-status=216.197.184.254 reachable via WAN2 check-gateway=ping
distance=1 scope=30 target-scope=10 routing-mark=to_WAN2
2 A S dst-address=0.0.0.0/0 gateway=216.197.184.254
3 S dst-address=0.0.0.0/0 gateway=70.76.0.1
distance=2 scope=30 target-scope=10
4 ADC dst-address=70.76.0.0/24 pref-src=70.76.0.251 gateway=WAN1
gateway-status=WAN1 reachable distance=0 scope=10
5 ADC dst-address=192.168.2.0/24 pref-src=192.168.2.1 gateway=bridge1
gateway-status=bridge1 reachable distance=0 scope=10
6 ADC dst-address=216.197.184.0/24 pref-src=216.197.184.175 gateway=WAN2
gateway-status=WAN2 reachable distance=0 scope=10
/ip address> print detail
0 address=70.76.0.251/24 network=70.76.0.0 interface=WAN1
actual-interface=WAN1
1 address=192.168.2.1/24 network=192.168.2.0 interface=bridge1
actual-interface=bridge1
2 address=216.197.184.175/24 network=216.197.184.0 interface=WAN2
actual-interface=WAN2
3 X address=192.168.3.1/24 network=192.168.3.0 interface=ether10
actual-interface=ether10
/ip firewall> export
jan/04/1970 21:15:16 by RouterOS 5.12
software id = 7AV9-TYKY
set enabled=yes generic-timeout=10m icmp-timeout=10s tcp-close-timeout=10s
tcp-close-wait-timeout=10s tcp-established-timeout=1d tcp-fin-wait-timeout=
10s tcp-last-ack-timeout=10s tcp-syn-received-timeout=5s
tcp-syn-sent-timeout=5s tcp-syncookie=no tcp-time-wait-timeout=10s
udp-stream-timeout=3m udp-timeout=10s
add action=passthrough chain=unused-hs-chain comment="place hotspot rules here"
disabled=yes
/ip firewall mangle
add action=mark-connection chain=input disabled=no in-interface=WAN1
new-connection-mark=WAN1_conn passthrough=yes
add action=mark-connection chain=input disabled=no in-interface=WAN2
new-connection-mark=WAN2_conn passthrough=yes
add action=mark-routing chain=output connection-mark=WAN1_conn disabled=no
new-routing-mark=to_WAN1 passthrough=yes
add action=mark-routing chain=output connection-mark=WAN2_conn disabled=no
new-routing-mark=to_WAN2 passthrough=yes
add action=accept chain=prerouting disabled=no dst-address=70.76.0.0/24
in-interface=bridge1
add action=accept chain=prerouting disabled=no dst-address=216.197.184.0/24
add action=mark-connection chain=prerouting disabled=no dst-address-type=!local
in-interface=bridge1 new-connection-mark=WAN2_conn passthrough=yes
per-connection-classifier=src-address:2/1
in-interface=bridge1 new-connection-mark=WAN1_conn passthrough=yes
per-connection-classifier=src-address:2/0
add action=mark-routing chain=prerouting connection-mark=WAN1_conn disabled=no
in-interface=bridge1 new-routing-mark=to_WAN1 passthrough=yes
add action=mark-routing chain=prerouting connection-mark=WAN2_conn disabled=no
in-interface=bridge1 new-routing-mark=to_WAN2 passthrough=yes
disabled=yes
add action=masquerade chain=srcnat disabled=no out-interface=WAN1
add action=masquerade chain=srcnat disabled=no out-interface=WAN2
add action=masquerade chain=srcnat comment="masquerade hotspot network"
disabled=no src-address=192.168.2.0/24
/ip firewall service-port
set ftp disabled=no ports=21
set tftp disabled=no ports=69
set irc disabled=no ports=6667
set h323 disabled=no
set sip disabled=no ports=5060,5061 sip-direct-media=yes
set pptp disabled=no
There you go...hope this helps you.
Cheers!
