PCC load balancing equalizer ideas
Need some ideas please. I load balance 8 ADSL lines using PCC. The problem however is that you get congestion of lines while the other lines is un utilized. As an example, for the week line 3,4 and 5 used 16 Gb data each and the rest around 8Gb each. I use src address as qualifier in order for internet banking and so forth to work. Also mark P2P and use both address and port as qualifier, which helped a lot Would like to be able to move a user to a unutilized line instead of just using PCC or some better kind of load balancing. Any ideas would be appreciated.
