My System: RB433 v5.8
i am trying to follow this Load Balancing example:http://wiki.mikrotik.com/wiki/Manual:PCC
But it just doesnt work. After i do the config i try to access the internet, i cannot, unless i specify a default route (without routing marks)
Heres my config
[admin@MikroTik]
/ip address print
# ADDRESS NETWORK INTERFACE
0 ;;; To use Router 10.0.11.22 as a Route (gateway)
10.0.11.1/24 10.0.11.0 ether1
1 ;;; To use Router 10.0.12.27 as a Route (gateway)
10.0.12.1/24 10.0.12.0 ether2
2 ;;; All PPPOE connections comes on here
192.168.0.1/32 192.168.0.1 bridge1
10 ;;; To be able to connect to This MikroTik = 10.0.4.1
10.0.4.1/24 10.0.4.0 ether1
/ip firewall mangle> print
0 chain=prerouting action=accept dst-address=10.0.11.0/24
in-interface=bridge1
1 chain=prerouting action=accept dst-address=10.0.20.0/24
2 chain=prerouting action=mark-connection
new-connection-mark=ISP1_conn passthrough=yes
dst-address-type=!local in-interface=bridge1
connection-mark=no-mark
per-connection-classifier=both-addresses:2/0
3 chain=prerouting action=mark-connection
new-connection-mark=ISP2_conn passthrough=yes
per-connection-classifier=both-addresses:2/1
4 chain=prerouting action=mark-routing new-routing-mark=to_ISP1
passthrough=yes in-interface=bridge1 connection-mark=ISP1_conn
5 chain=prerouting action=mark-routing new-routing-mark=to_ISP2
passthrough=yes in-interface=bridge1 connection-mark=ISP2_conn
[admin@MikroTik] /ip route> export
# nov/12/2011 08:29:05 by RouterOS 5.8
# software id = 6S61-VQPK
add disabled=no distance=1 dst-address=0.0.0.0/0 gateway=10.0.11.22 routing-mark=to_ISP1 \
scope=30 target-scope=10
add disabled=no distance=1 dst-address=0.0.0.0/0 gateway=10.0.20.1 routing-mark=to_ISP2 \
[admin@MikroTik] /ip firewall nat> print
0 chain=srcnat action=masquerade out-interface=ether1
1 chain=srcnat action=masquerade out-interface=ether2
2 chain=dstnat action=redirect to-ports=8080 protocol=tcp dst-port=80
(I did try disabling this rule:
so that it does not go thru the proxy. but still, same issue, cant access internet.
