PCC load balancing Inquiry
Hey,
Good day guys is it possible to implement PCC connection where the actual PPPoE clients are from different server apart from the router which will perform the NAT
Network Topology
Customers ->. ACCESS SWITCH → PPPoE Server → NAT Router → 5 WAN LINKS
We try to implement this topology with mix bag of results and found some articles that suggest it will not work because the src-address classifier requires the users should be home on the same PPPoE server and performs NAT at the same time
For your input, thanks in advance guys
Best,
Ronald
