Hello everyone,
I’m still a beginner in MikroTik and I would like to ask for help regarding my PCC load balancing configuration. Below is my current setup, hardware information, bandwidth details, and configuration logic.
Hardware
- Router model: MikroTik RB450Gx4
1. WAN Configuration
I have 2 DHCP Clients:
DHCP Client on ether1 (ISP 1)
DHCP Client on ether2 (ISP 2)
Both WAN interfaces receive dynamic IP addresses.
Total ISP bandwidth:
ISP 1 (ether1): 30 Mbps
ISP 2 (ether2): 100 Mbps
2. LAN Configuration
I have 3 DHCP Servers:
DHCP Server for ether3
DHCP Server for ether4
DHCP Server for ether5
3. IP Addressing
Total 5 IP addresses:
2 dynamic IPs from DHCP Clients (ether1 and ether2)
ether3:
192.168.10.2 -
ether4:
192.168.20.2 -
ether5:
192.168.30.2
4. DNS
DNS servers used:
8.8.8.8 -
1.1.1.1
5. NAT
NAT configuration follows common tutorials:
Masquerade via ether1
Masquerade via ether2
6. Mangle Configuration
a. Accept Rules
There are 5 mangle rules with action=accept
Each rule is created for:
ether1
ether2
ether3
ether4
ether5
b. Mark Connection (WAN)
1 connection-mark rule for ether1
1 connection-mark rule for ether2
c. Mark Connection (LAN – PCC)
There are 13 PCC rules per LAN interface:
ether3
ether4
ether5
PCC method: src-address
Ratio used: 13/12
d. Mark Routing
There are 2 routing-mark rules
Applied to traffic coming from:
ether3
ether4
ether5
e. Output Chain
- There is an output chain rule to mark router-generated traffic.
7. Routes
In IP → Routes, I have 2 routes:
One default route via ether1
One default route via ether2
8. Bandwidth Limitation (QoS)
Bandwidth limitation is applied on LAN ports:
ether3 is limited to 50 Mbps
ether4 is limited to 50 Mbps
Bandwidth control is implemented using:
Simple Queue
PCQ (Per Connection Queue)
Problems Encountered
Issue on ether4 (Access Point 1)
ether4 is connected to an access point.
The internet speed becomes progressively slower as more users connect to the access point. -
Issue on ether3 (Access Point 2)
ether3 is connected to a second access point.
Devices connecting through Access Point 2 initially access the internet normally, but after 2–3 minutes the connection suddenly disconnects.
After that:-
The SSID of Access Point 2 is no longer visible on the client device.
To make the SSID visible again, I need to unplug and reconnect the LAN cable between Access Point 2 and ether3.
