PCC Load Balancing not working correctly
Hi, I recently upgraded to 4.3 and I decided to try PCC load balancing, the problem I have is that I don’t feel it’s working correctly because my first connection always has a lot more traffic than the second one. I have two 4mb adsl and the first one is always at it’s full capacity meanwhile the other is between 300 kbps and 1.5 mbps only in very rare ocations both are full, here is my configuration:
/ip firewall mangle
add action=accept chain=output comment=“” disabled=no dst-address=10.0.0.0/24
add action=accept chain=input comment=“” disabled=no dst-address=10.0.0.0/24
add action=accept chain=prerouting comment=“” disabled=no dst-address=
10.0.0.0/24 src-address-list=clients
add action=mark-connection chain=input comment=“Marcar Entrantes”
connection-state=new disabled=no in-interface=ether4 new-connection-mark=
adsl1_conn passthrough=yes
add action=mark-connection chain=input comment=“” connection-state=new
disabled=no in-interface=Bridge1 new-connection-mark=adsl2_conn
passthrough=yes
“Prevenir que las conexiones salientes sean marcadas y ruteadas por PCC”
disabled=no dst-address-list=clients
172.165.20.0/24
172.165.15.0/24
add action=accept chain=output comment=“Prevenir que las conexiones choquen co
n las marcas PCC y sean asignadas a otra salida” connection-state=new
disabled=no dst-address=192.168.20.0/24
add action=accept chain=output comment=“” connection-state=new disabled=no
dst-address=192.168.254.0/24
add action=mark-routing chain=output comment=“” connection-mark=adsl1_conn
disabled=no new-routing-mark=to_adsl1 passthrough=yes
add action=mark-routing chain=output comment=“” connection-mark=adsl2_conn
disabled=no new-routing-mark=to_adsl2 passthrough=yes
add action=accept chain=prerouting comment=“Reglas de Aceptacion-Prevenir cone
xiones locales que sean marcadas y enviadas a las salidas de ineternet don
de serian rechazadas porque las direcciones no coinciden” disabled=no
dst-address=192.168.20.0/24 src-address-list=clients
192.168.254.0/24 src-address-list=clients
add action=accept chain=prerouting comment=“” disabled=no dst-address-list=
clients src-address-list=clients
add action=mark-connection chain=prerouting comment=“Marcar las conexiones de
las direcciones de los clientes con el balanceo PCC para asignarles las re
glas de ruteo” connection-state=new disabled=no dst-address-type=!local
new-connection-mark=adsl1_conn passthrough=yes per-connection-classifier=
both-addresses:2/0 src-address-list=clients
add action=mark-connection chain=prerouting comment=“” connection-state=new
disabled=no dst-address-type=!local new-connection-mark=adsl2_conn
passthrough=yes per-connection-classifier=both-addresses:2/1
add action=mark-routing chain=prerouting comment=“” connection-mark=
adsl1_conn disabled=no new-routing-mark=to_adsl1 passthrough=yes
adsl2_conn disabled=no new-routing-mark=to_adsl2 passthrough=yes
add action=passthrough chain=unused-hs-chain comment=
“place hotspot rules here” disabled=yes
add action=dst-nat chain=dstnat comment=“Para User Mannager” disabled=no
dst-port=60000 protocol=tcp to-addresses=10.0.0.5
dst-port=8291 in-interface=ether4 protocol=tcp to-addresses=10.0.0.1
add action=masquerade chain=srcnat comment=NAT disabled=no out-interface=
ether4
add action=masquerade chain=srcnat comment=“” disabled=no out-int
add check-gateway=ping comment=“” disabled=no distance=1 dst-address=
0.0.0.0/0 gateway=192.168.20.254 routing-mark=to_adsl1 scope=30
target-scope=10
0.0.0.0/0 gateway=192.168.254.254 routing-mark=to_adsl2 scope=30
target-scope=10
add check-gateway=ping comment=“” disabled=no distance=2 dst-address=
0.0.0.0/0 gateway=192.168.20.254 scope=30 target-scope=10
add check-gateway=arp comment=“” disabled=no distance=3 dst-address=0.0.0.0/0
gateway=192.168.254.254 scope=30 target-scope=10
Help please.
how many packets have your PCC rules counted? are those values equal?
Hi, I have no idea, in the manual I did’t read anything about packets, where and how do you configure that?
it’s in queue statistics =)
Thank you for your answer but I don’t understand what do you mean.
/ip firewall mangle print stats
CHAIN ACTION BYTES PACKETS
0 output accept 1330470 12394
1 input accept 5248563 46712
2 prerouting accept 4433971 34886
3 ;;; Marcar Entrantes
input mark-connection 813707 8045
4 input mark-connection 1863289 18440
5 ;;; Prevenir que las conexiones salientes sean marcadas y ruteadas por PCC
output accept 6275735408 5178346
6 output accept 0 0
7 output accept 0 0
8 ;;; Prevenir que las conexiones choquen con las marcas PCC y sean asign…
output accept 1983519 30471
9 output accept 1991181 30596
10 output mark-routing 709000 7249
11 output mark-routing 1180203 11559
12 ;;; Reglas de Aceptacion-Prevenir conexiones locales que sean marcadas …
prerouting accept 0 0
13 prerouting accept 43192 647
14 prerouting accept 1680387 20862
15 ;;; Marcar las conexiones de las direcciones de los clientes con el bal…
prerouting mark-connection 15603747 212883
16 prerouting mark-connection 14146853 185439
Actually the connection that has less traffic has more marked bytes, what I have seen is that it appears that web surfing traffic is distributed equal between the two connections but the downloads almost every time go to the first gateway.
It seems that the rules are working fine but it’s traffic that gets away or escapes from the rules, I have tried other PCC examples and alwas the default gateway gets a lot more traffic 3/1 proportion, anybody else has this problem?
actually, I was speaking about 15th and 16th rules, as I can see. ‘input’ is traffic directed to the router itself
seems like your downloaders are out of statistics, and they work via 1st gateway mainly )))
try to set ‘adsl2_conn’ mark for rule with ‘per-connection-classifier=both-addresses:2/0’ and ‘adsl1_conn’ mark for rule with ‘per-connection-classifier=both-addresses:2/1’ and then see whether traffic will change between interfaces…
Tried what you suggested but the traffic keeps going mostly to the same ethernet, as I told it seems that a lot of traffic is jumping the rules and goig through the default gateway.
hmmm… maybe try to see (add a rule with action=log), what packets do not have packet-mark after PCC rules…
I don’t know if this is what you wanted to see:
/log> print
21:53:30 firewall,info after-pcc prerouting: in:ether1 out:(none), src-mac 00:0c
:42:34:0f:1e, proto TCP (ACK), 172.165.15.22:1983->66.132.225.10:30000, len 20
21:53:30 firewall,info after-pcc prerouting: in:ether1 out:(none), src-mac 00:23
:69:94:1e:50, proto TCP (ACK), 172.165.15.18:49280->208.92.52.48:80, len 20
21:53:30 firewall,info after-pcc prerouting: in:ether1 out:(none), src-mac 00:16
:b6:8f:41:5b, proto TCP (ACK), 172.165.15.47:1962->209.222.128.224:80, len 20
21:53:30 firewall,info after-pcc prerouting: in:ether1 out:(none), src-mac 00:40
:90:00:2b:45, proto TCP (SYN), 172.165.15.2:6569->69.63.181.11:80, len 28
:90:00:2b:45, proto TCP (ACK), 172.165.15.2:6569->69.63.181.11:80, len 20
:90:00:2b:45, proto TCP (ACK), 172.165.15.2:6569->69.63.181.11:80, len 1460
:90:00:2b:45, proto TCP (ACK,PSH), 172.165.15.2:6569->69.63.181.11:80, len 114
21:53:30 firewall,info after-pcc prerouting: in:ether4 out:(none), src-mac 00:23
:51:28:f3:91, proto TCP (ACK,PSH), 190.102.222.207:3256->192.168.20.50:6516, len
1460
:51:28:f3:91, proto TCP (ACK), 76.13.222.11:80->192.168.20.50:34545, len 32
:51:28:f3:91, proto TCP (ACK,PSH), 76.13.222.11:80->192.168.20.50:34545, len 494
:51:28:f3:91, proto TCP (ACK,FIN), 76.13.222.11:80->192.168.20.50:34545, len 32
:42:34:0f:1e, proto TCP (ACK), 172.165.15.22:60932->24.33.236.66:27443, len 20
:42:34:0f:1e, proto TCP (ACK), 172.165.15.22:61148->174.70.132.253:21697, len 20
:42:34:0f:1e, proto TCP (ACK), 172.165.15.22:61140->69.76.149.2:44061, len 20
:42:34:0f:1e, proto TCP (ACK), 172.165.15.22:60928->67.10.162.54:17999, len 20
:90:00:2b:45, proto TCP (ACK), 172.165.15.2:6568->76.13.222.11:80, len 20
:51:28:f3:91, proto TCP (ACK), 76.13.222.11:80->192.168.20.50:34544, len 1472
:51:28:f3:91, proto TCP (ACK,PSH), 76.13.222.11:80->192.168.20.50:34544, len 844
:51:28:f3:91, proto TCP (ACK,FIN), 76.13.222.11:80->192.168.20.50:34544, len 32
:51:28:f3:91, proto TCP (ACK,PSH), 190.218.153.10:62444->192.168.20.50:3002, len
46
628
:90:00:2b:45, proto TCP (ACK), 172.165.15.2:6566->76.13.222.11:80, len 20
:90:00:2b:45, proto TCP (ACK), 172.165.15.2:6516->190.102.222.207:3256, len 20
:51:28:f3:91, proto TCP (ACK,PSH), 190.182.37.190:54529->192.168.20.50:2812, len
39
:51:28:f3:91, proto TCP (ACK,PSH), 24.3.123.235:34267->192.168.20.50:60938, len
105
:90:00:2b:45, proto TCP (ACK), 172.165.15.2:6525->201.211.33.247:36984, len 20
:51:28:f3:91, proto TCP (ACK), 76.13.222.11:80->192.168.20.50:34544, len 32
:51:28:f3:91, proto TCP (ACK,PSH), 67.10.162.54:17999->192.168.20.50:60928, len
73
21:53:30 firewall,info after-pcc prerouting: in:Bridge1 out:(none), src-mac 00:1
4:95:93:bb:09, proto TCP (ACK,PSH), 24.33.236.66:27443->192.168.254.20:60932, le
n 158
:90:00:2b:45, proto TCP (SYN), 172.165.15.2:6570->76.13.222.11:80, len 28
:90:00:2b:45, proto TCP (SYN), 172.165.15.2:6571->69.63.176.178:80, len 28
1460
4:95:93:bb:09, proto TCP (ACK,PSH), 69.76.149.2:44061->192.168.254.20:61140, len
243
:90:00:2b:45, proto TCP (ACK), 172.165.15.2:6570->76.13.222.11:80, len 20
:90:00:2b:45, proto TCP (ACK), 172.165.15.2:6571->69.63.176.178:80, len 20
:90:00:2b:45, proto TCP (ACK), 172.165.15.2:6571->69.63.176.178:80, len 1460
:90:00:2b:45, proto TCP (ACK,PSH), 172.165.15.2:6571->69.63.176.178:80, len 145
:51:28:f3:91, proto TCP (ACK), 209.222.128.224:80->192.168.20.50:59818, len 1472
21:53:31 firewall,info after-pcc prerouting: in:ether1 out:(none), src-mac 00:40
:90:00:2b:45, proto TCP (ACK,PSH), 172.165.15.2:6570->76.13.222.11:80, len 966
21:53:31 firewall,info after-pcc prerouting: in:ether4 out:(none), src-mac 00:23
21:53:31 firewall,info after-pcc prerouting: in:ether1 out:(none), src-mac 00:16
21:53:31 firewall,info after-pcc prerouting: in:ether1 out:(none), src-mac 00:0e
:e8:6b:42:66, proto TCP (ACK), 172.165.15.3:3002->190.218.153.10:62444, len 20
:e8:6b:42:66, proto TCP (ACK), 172.165.15.3:2812->190.182.37.190:54529, len 20
:90:00:2b:45, proto TCP (SYN), 172.165.15.2:6560->80.31.255.246:3557, len 28
:51:28:f3:91, proto TCP (ACK,PSH), 68.50.12.253:63958->192.168.20.50:3267, len 4
6
628
:51:28:f3:91, proto TCP (ACK), 69.63.181.16:80->192.168.20.50:37747, len 32
:51:28:f3:91, proto TCP (SYN,ACK), 69.63.176.178:80->192.168.20.50:58285, len 24
:51:28:f3:91, proto TCP (SYN,ACK), 76.13.222.11:80->192.168.20.50:34547, len 40
21:53:31 firewall,info after-pcc prerouting: in:Bridge1 out:(none), src-mac 00:1
4:95:93:bb:09, proto TCP (ACK,PSH), 66.132.225.10:30000->192.168.254.20:1983, le
n 66
21:53:31 firewall,info after-pcc prerouting: in:ether1 out:(none), src-mac 00:0c
:42:34:0f:1e, proto TCP (ACK,PSH), 172.165.15.22:60932->24.33.236.66:27443, len
265
:42:34:0f:1e, proto UDP, 172.165.15.22:30804->192.168.1.112:6352, len 41
:42:34:0f:1e, proto TCP (ACK), 172.165.15.22:60938->24.3.123.235:34267, len 20
:90:00:2b:45, proto TCP (ACK,PSH), 172.165.15.2:6525->201.211.33.247:36984, len
245
:51:28:f3:91, proto TCP (ACK,PSH), 190.50.182.20:34637->192.168.20.50:3127, len
46
1460
:51:28:f3:91, proto TCP (ACK), 69.63.176.178:80->192.168.20.50:58285, len 20
:51:28:f3:91, proto TCP (ACK), 76.13.222.11:80->192.168.20.50:34547, len 32
n 27
:51:28:f3:91, proto TCP (ACK,RST), 207.46.216.54:80->192.168.20.50:39598, len 20
:51:28:f3:91, proto TCP (ACK,PSH), 69.63.176.178:80->192.168.20.50:58285, len 20
6
:51:28:f3:91, proto TCP (ACK,PSH), 69.63.176.178:80->192.168.20.50:58285, len 33
8
:51:28:f3:91, proto TCP (ACK,FIN), 69.63.176.178:80->192.168.20.50:58285, len 20
628
:51:28:f3:91, proto TCP (ACK,PSH), 69.63.181.16:80->192.168.20.50:37747, len 424
n 73
:e8:6b:42:66, proto TCP (ACK), 172.165.15.3:3267->68.50.12.253:63958, len 20
73
:90:00:2b:45, proto TCP (ACK,PSH), 172.165.15.2:3932->65.54.49.129:1863, len 446
174
:51:28:f3:91, proto TCP (ACK,PSH), 208.92.52.48:80->192.168.20.50:55862, len 964
105
:51:28:f3:91, proto TCP (ACK), 76.13.222.11:80->192.168.20.50:34547, len 1472
:51:28:f3:91, proto TCP (ACK,PSH), 76.13.222.11:80->192.168.20.50:34547, len 839
:51:28:f3:91, proto TCP (ACK,FIN), 76.13.222.11:80->192.168.20.50:34547, len 32
1460
:51:28:f3:91, proto TCP (ACK,PSH), 68.50.12.253:63958->192.168.20.50:3267, len 7
2
:e8:6b:42:66, proto TCP (ACK), 172.165.15.3:3127->190.50.182.20:34637, len 20
:90:00:2b:45, proto TCP (SYN), 172.165.15.2:6572->74.125.67.139:80, len 32
:90:00:2b:45, proto TCP (SYN), 172.165.15.2:6573->74.125.67.99:80, len 32
:51:28:f3:91, proto TCP (ACK,PSH), 65.54.49.129:1863->192.168.20.50:3932, len 30
:51:28:f3:91, proto TCP (ACK,PSH), 65.54.49.129:1863->192.168.20.50:3932, len 53
2
:51:28:f3:91, proto TCP (ACK,PSH), 65.54.49.129:1863->192.168.20.50:3932, len 24
5
628
4:95:93:bb:09, proto TCP (ACK,RST), 80.31.255.246:3557->192.168.254.20:6560, len
20
:90:00:2b:45, proto TCP (ACK), 172.165.15.2:6572->74.125.67.139:80, len 20
:90:00:2b:45, proto TCP (ACK), 172.165.15.2:6573->74.125.67.99:80, len 20
:90:00:2b:45, proto TCP (ACK), 172.165.15.2:3932->65.54.49.129:1863, len 20
n 73
:90:00:2b:45, proto TCP (ACK,PSH), 172.165.15.2:6572->74.125.67.139:80, len 603
:90:00:2b:45, proto TCP (ACK,PSH), 172.165.15.2:6573->74.125.67.99:80, len 734
1460
:51:28:f3:91, proto TCP (ACK,PSH), 74.125.67.101:80->192.168.20.50:40809, len 17
8
:51:28:f3:91, proto TCP (ACK,PSH), 190.173.4.190:17819->192.168.20.50:2867, len
46
:90:00:2b:45, proto TCP (SYN), 172.165.15.2:6574->190.201.28.62:9616, len 28
4:95:93:bb:09, proto TCP (ACK), 201.211.33.247:36984->192.168.254.20:6525, len 2
0
:51:28:f3:91, proto TCP (ACK,PSH), 74.125.67.104:80->192.168.20.50:42086, len 26
8
:51:28:f3:91, proto TCP (ACK,FIN,PSH), 174.129.220.145:80->192.168.20.50:64976,
len 633
628
:42:34:0f:1e, proto TCP (ACK), 172.165.15.22:64976->174.129.220.145:80, len 20
:42:34:0f:1e, proto TCP (ACK,FIN), 172.165.15.22:64976->174.129.220.145:80, len
20
21:53:31 firewall,info after-pcc prerouting: in:ether1 out:(none), src-mac 00:23
:90:00:2b:45, proto UDP, 172.165.15.2:6575->74.66.13.222:40749, len 37
73
:51:28:f3:91, proto TCP (ACK,PSH), 209.222.128.224:80->192.168.20.50:59818, len
288
73
:90:00:2b:45, proto UDP, 172.165.15.2:6529->200.33.146.194:53, len 60
1460
:51:28:f3:91, proto TCP (ACK), 174.129.220.145:80->192.168.20.50:64976, len 20
:51:28:f3:91, proto UDP, 192.168.20.254:53->192.168.20.50:53595, len 153
628
:51:28:f3:91, proto TCP (SYN,ACK), 190.201.28.62:9616->192.168.20.50:6574, len 2
8
142
:90:00:2b:45, proto TCP (ACK), 172.165.15.2:6574->190.201.28.62:9616, len 20
:e8:6b:42:66, proto TCP (ACK), 172.165.15.3:2867->190.173.4.190:17819, len 20
:42:34:0f:1e, proto TCP (ACK,PSH), 172.165.15.22:61140->69.76.149.2:44061, len 7
3
:90:00:2b:45, proto TCP (SYN), 172.165.15.2:6576->187.141.2.58:80, len 28
:90:00:2b:45, proto TCP (ACK), 172.165.15.2:6576->187.141.2.58:80, len 20
:51:28:f3:91, proto TCP (ACK), 208.92.52.48:80->192.168.20.50:55862, len 1472
:90:00:2b:45, proto TCP (SYN), 172.165.15.2:6577->69.63.176.178:80, len 28
:90:00:2b:45, proto TCP (ACK), 172.165.15.2:6577->69.63.176.178:80, len 20
:90:00:2b:45, proto TCP (ACK), 172.165.15.2:6577->69.63.176.178:80, len 1460
:90:00:2b:45, proto TCP (ACK,PSH), 172.165.15.2:6577->69.63.176.178:80, len 146
:90:00:2b:45, proto UDP, 172.165.15.2:6529->200.33.146.194:53, len 50
1460
:51:28:f3:91, proto TCP (ACK,PSH), 174.70.132.253:21697->192.168.20.50:61148, le
n 73
n 105
:90:00:2b:45, proto TCP (SYN), 172.165.15.2:6578->187.141.2.58:80, len 28
628
:90:00:2b:45, proto TCP (ACK), 172.165.15.2:6578->187.141.2.58:80, len 20
:90:00:2b:45, proto TCP (ACK,PSH), 172.165.15.2:6576->187.141.2.58:80, len 778
121
:90:00:2b:45, proto TCP (ACK,PSH), 172.165.15.2:6578->187.141.2.58:80, len 528
:51:28:f3:91, proto TCP (SYN,ACK), 187.141.2.58:80->192.168.20.50:33171, len 40
:51:28:f3:91, proto TCP (SYN,ACK), 187.141.2.58:80->192.168.20.50:33172, len 40
:51:28:f3:91, proto TCP (SYN,ACK), 69.63.176.178:80->192.168.20.50:58287, len 24
:51:28:f3:91, proto TCP (ACK), 187.141.2.58:80->192.168.20.50:33171, len 32
:51:28:f3:91, proto TCP (ACK), 187.141.2.58:80->192.168.20.50:33171, len 1472
:51:28:f3:91, proto TCP (ACK,PSH), 187.141.2.58:80->192.168.20.50:33171, len 147
2
:51:28:f3:91, proto TCP (ACK,PSH), 187.141.2.58:80->192.168.20.50:33171, len 580
:51:28:f3:91, proto TCP (ACK), 187.141.2.58:80->192.168.20.50:33172, len 32
1460
:51:28:f3:91, proto TCP (ACK,PSH), 187.141.2.58:80->192.168.20.50:33172, len 377
4:95:93:bb:09, proto TCP (ACK,PSH), 201.211.33.247:36984->192.168.254.20:6525, l
en 195
628
73
:90:00:2b:45, proto TCP (SYN), 172.165.15.2:6579->187.141.2.58:80, len 28
4:95:93:bb:09, proto TCP (ACK,PSH), 201.221.233.46:21950->192.168.254.20:6504, l
en 1420
:90:00:2b:45, proto TCP (ACK), 172.165.15.2:6579->187.141.2.58:80, len 20
en 1460
:51:28:f3:91, proto TCP (ACK), 69.63.176.178:80->192.168.20.50:58287, len 20
en 668
:90:00:2b:45, proto TCP (ACK,PSH), 172.165.15.2:6579->187.141.2.58:80, len 775
en 628
:90:00:2b:45, proto TCP (ACK), 172.165.15.2:6504->201.221.233.46:21950, len 20
21:53:32 firewall,info after-pcc prerouting: in:ether1 out:(none), src-mac 00:40
21:53:32 firewall,info after-pcc prerouting: in:ether4 out:(none), src-mac 00:23
2
:90:00:2b:45, proto TCP (ACK,PSH), 172.165.15.2:6574->190.201.28.62:9616, len 25
7
2
:51:28:f3:91, proto TCP (ACK,PSH), 187.141.2.58:80->192.168.20.50:33171, len 645
21:53:32 firewall,info after-pcc prerouting: in:ether1 out:(none), src-mac 00:23
21:53:32 firewall,info after-pcc prerouting: in:Bridge1 out:(none), src-mac 00:1
en 1420
n 73
n 49
21:53:32 firewall,info after-pcc prerouting: in:ether1 out:(none), src-mac 00:0c
:90:00:2b:45, proto TCP (SYN), 172.165.15.2:6580->69.63.181.11:80, len 28
105
n 27
en 1460
en 668
en 1460
4:95:93:bb:09, proto ICMP (type 0, code 0), 192.168.254.254->192.168.254.20, len
36
:90:00:2b:45, proto TCP (ACK), 172.165.15.2:6580->69.63.181.11:80, len 20
:90:00:2b:45, proto TCP (ACK), 172.165.15.2:6580->69.63.181.11:80, len 1460
:90:00:2b:45, proto TCP (ACK,PSH), 172.165.15.2:6580->69.63.181.11:80, len 114
73
Thats true… I have the same problem too !!
MMM MMM KKK TTTTTTTTTTT KKK
MMMM MMMM KKK TTTTTTTTTTT KKK
MMM MMMM MMM III KKK KKK RRRRRR OOOOOO TTT III KKK KKK
MMM MM MMM III KKKKK RRR RRR OOO OOO TTT III KKKKK
MMM MMM III KKK KKK RRRRRR OOO OOO TTT III KKK KKK
MMM MMM III KKK KKK RRR RRR OOOOOO TTT III KKK KKK
MikroTik RouterOS 3.30 (c) 1999-2009 http://www.mikrotik.com/
[admin@MikroTik] > ip
[admin@MikroTik] /ip> firewall
[admin@MikroTik] /ip firewall> mangle
[admin@MikroTik] /ip firewall mangle> print
0 ;;; Mark new inbound connection WAN1
chain=input action=mark-connection new-connection-mark=wan1
passthrough=yes connection-state=new in-interface=LinkDotNet
1 ;;; Mark new inbound connection wan2
chain=input action=mark-connection new-connection-mark=wan2
passthrough=yes connection-state=new in-interface=TeData
2 ;;; Mark established inbound connection wan1
chain=prerouting action=mark-connection new-connection-mark=wan1
passthrough=yes connection-state=established in-interface=LinkDotNet
3 ;;; Mark established inbound connection wan2
chain=prerouting action=mark-connection new-connection-mark=wan2
passthrough=yes connection-state=established in-interface=TeData
4 ;;; Mark related inbound connection wan1
passthrough=yes connection-state=related in-interface=LinkDotNet
5 ;;; Mark related inbound connection wan2
passthrough=yes connection-state=related in-interface=TeData
6 ;;; Mark new inbound route wan1
chain=output action=mark-routing new-routing-mark=wan1 passthrough=yes
7 ;;; Mark new inbound route wan2
chain=output action=mark-routing new-routing-mark=wan2 passthrough=yes
8 chain=prerouting action=mark-connection new-connection-mark=wan1_pcc_conn
passthrough=yes connection-state=new dst-address-type=!local
in-interface=LAN per-connection-classifier=both-addresses:2/0
9 chain=prerouting action=mark-connection new-connection-mark=wan2_pcc
in-interface=LAN per-connection-classifier=src-address:2/1
10 chain=prerouting action=mark-connection new-connection-mark=wan1_pcc_conn
passthrough=yes connection-state=established dst-address-type=!local
11 chain=prerouting action=mark-connection new-connection-mark=wan2_pcc
in-interface=LAN per-connection-classifier=both-addresses:2/1
12 chain=prerouting action=mark-connection new-connection-mark=wan1_pcc_conn
passthrough=yes connection-state=related dst-address-type=!local
13 chain=prerouting action=mark-connection new-connection-mark=wan2_pcc
14 chain=prerouting action=mark-routing new-routing-mark=wan1 passthrough=ye>
15 chain=prerouting action=mark-routing new-routing-mark=wan2 passthrough=ye>
[admin@MikroTik] /ip firewall mangle> /ip
[admin@MikroTik] /ip firewall> nat
[admin@MikroTik] /ip firewall nat> print
0 ;;; place hotspot rules here
chain=unused-hs-chain action=passthrough
1 ;;; masquerade hotspot network
chain=srcnat action=masquerade src-address=192.168.80.0/24
2 ;;; masquerade hotspot network
chain=srcnat action=masquerade src-address=192.168.88.0/24
[admin@MikroTik] /ip firewall nat> /ip
[admin@MikroTik] /ip> route
[admin@MikroTik] /ip route> print
Flags: X - disabled, A - active, D - dynamic, C - connect, S - static, r - rip, b - bgp, o - ospf, m - mme,
DST-ADDRESS PREF-SRC GATEWAY-STATE GATEWAY DISTANCE INTERFACE
0 A S ;;; WAN 1 - Distance 1
0.0.0.0/0 reachable LinkDotNet 1 LinkDotNet
1 S ;;; WAN 1 - Distance 2
0.0.0.0/0 reachable TeData 2 TeData
2 A S ;;; WAN 2 - Distance 1
0.0.0.0/0 reachable TeData 1 TeData
3 S ;;; WAN 2 - Distance 2
0.0.0.0/0 reachable LinkDotNet 2 LinkDotNet
4 S ;;; Default Route - Distance 2
5 A S ;;; Default Route - Distance 1
6 ADC 41.130.0.1/32 41.130.11.54 0 LinkDotNet
7 ADC 163.121.170.22/32 196.202.112.105 0 TeData
8 ADC 192.168.80.0/24 192.168.80.1 0 wlan1
9 ADC 192.168.88.0/24 192.168.88.1 0 LAN
vdelarenal75, have you set ‘connection-mark=no-mark’ for your logging rule?
Try this…
Note that the ISP1 gives us 2Mbps and ISP2 - 4Mbps so we want a traffic ratio 1:2 (1/3 of the source/destination IP pairs from 192.168.0.0/24 goes through ISP1, and 2/3 through ISP2).
IP addresses of the router:
[admin@Router] ip address> print
ADDRESS NETWORK BROADCAST INTERFACE
0 192.168.0.254/24 192.168.0.0 192.168.0.255 Local
1 10.1.0.2/28 10.1.0.0 10.1.0.15 Public1
2 10.1.1.2/28 10.1.1.0 10.1.1.15 Public2
Add the default routes - one for ISP1 and 2 for ISP2 so we can get the ratio 1:3:
[admin@Router] ip route> add gateway=10.1.0.1,10.1.1.1,10.1.1.1
[admin@Router] ip route> print
DST-ADDRESS G GATEWAY DISTANCE INTERFACE
0 ADC 10.1.0.0/28 Public1
1 ADC 10.1.1.0/28 Public2
2 ADC 192.168.0.0/24 Local
3 A S 0.0.0.0/0 r 10.1.0.1 Public1
r 10.1.1.1 Public2
r 10.1.1.1 Public2
After configure all go to the clint PC open three command Prompt windows
and type c:\ tracert (any URL) all three windows with diff. URLs
if two trace show u 10.1.1.1 and one shows 10.1.0.1
its means u done the load balancing
No Chupaka I didn’t, let me do it again it should be in prerouting, postrouting or output?
Ok it seems that now it’s working ok, this is what I did:
1.- Inverted the PCC rules as Chubaka sugested adsl2 to both-addresses:2/0 and adsl1 to both-adresses:2/1
2.- Removed masquarade for the two wan connections and left masquarade for the Hotspot and PPoE server
3.- Removed use proxy in the default Hotspot profile (I know that it looks that has nothing to do with the problem but it didn’t worked until I did that)
4.- Reboot the router (It didn’t work until I rebooted the router)
Thankyou for the help Chubaka and I’ll keep you posted if it keeps workinf fine.
Regards.
Yep!!! it’s perfect now, thank you for your help.
you are welcome =)
p.s. I’m not Chu**b**aka :smiley:
Upppsss, sorry about that Chupaka.
