PCC Load Balancing WAN with DHCP WAN address
Hi All,
I’ve been using PCC for a long time without issue, but now I’ve come across an issue whereby both WAN addresses are dynamically assigned by the ISP which includes a dynamic gateway, I don’t seem to be able to mark the gateway in this scenarios even if I create a static default route to the interface with marks they don’t seem to be able to detect the gateway address which has been assigned, is there a workaround for this?
Kind Regards
Hi All,
My issue has been resolved by adding the below to the DHCP-client script section.
:if ($bound=1) do={/ip route set [find routing-table=<routing mark>] gateway=$"gateway-address" }
I did need to create a dummy entry to start within the routing table with the created as this command sets(changes existing) and doesn’t add a new one.
