i’ve the same problem. This works only if i disable this rules
add chain=input in-interface=pppoe-out1 action=mark-connection new-connection-mark=wan1_conn
add chain=input in-interface=pppoe-out2 action=mark-connection new-connection-mark=wan2_conn
add chain=output connection-mark=wan1_conn action=mark-routing new-routing-mark=to_wan1
add chain=output connection-mark=wan2_conn action=mark-routing new-routing-mark=to_wan2
Please we need help
Chupaka
22
and what exactly do you see with those rules enabled?
whet if you disable just input or output rules, but not together?
gtpro
23
Hey Logros try this setup, adjust it to your needs.
/ip firewall mangle
add action=mark-connection chain=input disabled=no in-interface=pppoe-out1 new-connection-mark=pppoe-out1_conn passthrough=yes
add action=mark-connection chain=input disabled=no in-interface=pppoe-out2 new-connection-mark=pppoe-out2_conn passthrough=yes
add action=mark-connection chain=input disabled=no in-interface=pppoe-out3 new-connection-mark=pppoe-out3_conn passthrough=yes
add action=mark-connection chain=input disabled=no in-interface=pppoe-out4 new-connection-mark=pppoe-out4_conn passthrough=yes
add action=mark-connection chain=output disabled=no dst-port=80 new-connection-mark=pppoe-out1_conn passthrough=yes per-connection-classifier=both-addresses:4/0 protocol=tcp
add action=mark-connection chain=output disabled=no dst-port=80 new-connection-mark=pppoe-out2_conn passthrough=yes per-connection-classifier=both-addresses:4/1 protocol=tcp
add action=mark-connection chain=output disabled=no dst-port=80 new-connection-mark=pppoe-out3_conn passthrough=yes per-connection-classifier=both-addresses:4/2 protocol=tcp
add action=mark-connection chain=output disabled=no dst-port=80 new-connection-mark=pppoe-out4_conn passthrough=yes per-connection-classifier=both-addresses:4/3 protocol=tcp
add action=mark-connection chain=prerouting disabled=no dst-address-type=!local dst-port=!80 in-interface=Local new-connection-mark=pppoe-out1_conn passthrough=yes per-connection-classifier=both-addresses:4/0 protocol=tcp
add action=mark-connection chain=prerouting disabled=no dst-address-type=!local dst-port=!80 in-interface=Local new-connection-mark=pppoe-out2_conn passthrough=yes per-connection-classifier=both-addresses:4/1 protocol=tcp
add action=mark-connection chain=prerouting disabled=no dst-address-type=!local dst-port=!80 in-interface=Local new-connection-mark=pppoe-out3_conn passthrough=yes per-connection-classifier=both-addresses:4/2 protocol=tcp
add action=mark-connection chain=prerouting disabled=no dst-address-type=!local dst-port=!80 in-interface=Local new-connection-mark=pppoe-out4_conn passthrough=yes per-connection-classifier=both-addresses:4/3 protocol=tcp
add action=mark-routing chain=prerouting connection-mark=pppoe-out1_conn disabled=no in-interface=Local new-routing-mark=to_pppoe-out1 passthrough=yes
add action=mark-routing chain=prerouting connection-mark=pppoe-out2_conn disabled=no in-interface=Local new-routing-mark=to_pppoe-out2 passthrough=yes
add action=mark-routing chain=prerouting connection-mark=pppoe-out3_conn disabled=no in-interface=Local new-routing-mark=to_pppoe-out3 passthrough=yes
add action=mark-routing chain=prerouting connection-mark=pppoe-out4_conn disabled=no in-interface=Local new-routing-mark=to_pppoe-out4 passthrough=yes
add action=mark-routing chain=output connection-mark=pppoe-out1_conn disabled=no new-routing-mark=to_pppoe-out1 passthrough=yes
add action=mark-routing chain=output connection-mark=pppoe-out2_conn disabled=no new-routing-mark=to_pppoe-out2 passthrough=yes
add action=mark-routing chain=output connection-mark=pppoe-out3_conn disabled=no new-routing-mark=to_pppoe-out3 passthrough=yes
add action=mark-routing chain=output connection-mark=pppoe-out4_conn disabled=no new-routing-mark=to_pppoe-out4 passthrough=yes
add action=masquerade chain=srcnat disabled=no out-interface=pppoe-out1
add action=masquerade chain=srcnat disabled=no out-interface=pppoe-out2
add action=masquerade chain=srcnat disabled=no out-interface=pppoe-out3
add action=masquerade chain=srcnat disabled=no out-interface=pppoe-out4
add action=redirect chain=dstnat disabled=no dst-port=80 in-interface=Local protocol=tcp to-ports=3123
If this rules are enabled. Webproxy doesn’t work and i don’t see connections on webproxy tab
