in ip firewall mangle, i add in “hotspot=auth” , but it seen not work with load balancing, but if i delete “hotspot=auth”, it works fine with load balancing, but hotspot cannot work, may i know what is the problem?
/ ip address
add address=192.168.0.1/24 network=192.168.0.0 broadcast=192.168.0.255 interface=LAN
add address=192.168.1.2/24 network=192.168.1.0 broadcast=192.168.1.255 interface=ISP1
add address=192.168.2.2/24 network=192.168.2.0 broadcast=192.168.2.255 interface=ISP2
/ ip firewall mangle
add chain=prerouting dst-address=192.168.1.0/24 action=accept in-interface=LAN
add chain=prerouting dst-address=192.168.2.0/24 action=accept in-interface=LAN
add chain=prerouting in-interface=ISP1 connection-mark=no-mark action=mark-connection
new-connection-mark=ISP1_conn
add chain=prerouting in-interface=ISP2 connection-mark=no-mark action=mark-connection
new-connection-mark=ISP2_conn
add chain=prerouting in-interface=LAN connection-mark=no-mark dst-address-type=!local hotspot=auth
per-connection-classifier=both-addresses:2/0 action=mark-connection new-connection-mark=ISP1_conn
per-connection-classifier=both-addresses:2/1 action=mark-connection new-connection-mark=ISP2_conn
add chain=prerouting connection-mark=ISP1_conn in-interface=LAN action=mark-routing
new-routing-mark=to_ISP1
add chain=prerouting connection-mark=ISP2_conn in-interface=LAN action=mark-routing
new-routing-mark=to_ISP2
add chain=output connection-mark=ISP1_conn action=mark-routing new-routing-mark=to_ISP1
add chain=output connection-mark=ISP2_conn action=mark-routing new-routing-mark=to_ISP2
/ ip route
add dst-address=0.0.0.0/0 gateway=192.168.1.1 routing-mark=to_ISP1 check-gateway=ping
add dst-address=0.0.0.0/0 gateway=192.168.2.1 routing-mark=to_ISP2 check-gateway=ping
add dst-address=0.0.0.0/0 gateway=192.168.1.1 distance=1 check-gateway=ping
add dst-address=0.0.0.0/0 gateway=192.168.2.1 distance=2 check-gateway=ping
/ ip firewall nat
add chain=srcnat out-interface=ISP1 action=masquerade
add chain=srcnat out-interface=ISP2 action=masquerade
Remove “hotspot=auth” from the rules
Add two more rules to exclude hotspot packets from being routed to your ISP. Place these rules before the first “mark-routing” rule.
/ip firewall mangle
add action=mark-packet chain=output connection-mark=ISP1_conn disabled=no new-packet-mark=hotspot passthrough=no port=64872-64875 protocol=tcp
add action=mark-packet chain=output connection-mark=ISP2_conn disabled=no new-packet-mark=hotspot passthrough=no port=64872-64875 protocol=tcp
skillful:
/ip firewall mangle
/ ip address
/ ip route
/ ip firewall nat
it is like this?
it is my hotspot user also can use PCC load balancing method?
add chain=prerouting in-interface=ISP1 connection-mark=no-mark action=mark-connection \
add chain=prerouting in-interface=ISP2 connection-mark=no-mark action=mark-connection \
add chain=prerouting in-interface=LAN connection-mark=no-mark dst-address-type=!local \
add action=mark-packet chain=output connection-mark=ISP1_conn disabled=no new-packet-mark=hotspot \
add action=mark-packet chain=output connection-mark=ISP2_conn disabled=no new-packet-mark=hotspot \
add chain=prerouting connection-mark=ISP1_conn in-interface=LAN action=mark-routing \
add chain=prerouting connection-mark=ISP2_conn in-interface=LAN action=mark-routing \
thanks.. , but it works about 1-2 minutes, after that i cannot access to internet anymore… is there somethings wrong with my setting?
Hi
I am looking at setting up load balancing on my hotspot and would like to know if this is working?
Regards
