Good morning people arose a doubt following miinha aki have four modems in bridge pppoe sure everyone using the same starling plumb ip as the gateway to all using the NetWatch with ip 200.160.2.3 and ip router by setting the same ip you out by pppoe-OUT1 that would be a modem AAte so good when you turn off the modem over ip continues to drip as if it had normal active and NetWatch always think the link is ok even using the scripts etc still so someone tell me if you know how to fix it with the gatewaysse disable the pppoe-OUT1 modems on the same bridge.
Aprinou Hello, I’m having the same problem here. If any colleague can help
