PCC & NTH Qestion
ok, I know this is a beaten to death topic as there are many question on it but I need some help still.
I am trying to setup a load balancing for 2 WAN link, 10Mbps + 3Mbps (it is odd, I know) and I need to use PCC to have persistent HTTPS connection (meaning same WAN out all the time for a session initiated from a local host), Using NTH is easy but how should I put it using PCC?
add action=mark-connection chain=prerouting comment=“” disabled=no dst-address-type=!local new-connection-mark=WAN1_IN passthrough=yes per-connection-classifier=both-addresses-and-ports:??/?? src-address=10.0.0.1-10.0.0.255
add action=mark-connection chain=prerouting comment=“” disabled=no dst-address-type=!local new-connection-mark=WAN2_IN passthrough=yes per-connection-classifier=both-addresses-and-ports:??/?? src-address=10.0.0.1-10.0.0.255
any help?
PS: beside HTTPS, the rest of the traffic is Load balance using NTH which is much easier:
add action=mark-connection chain=prerouting comment=“myMark” connection-state=new disabled=no new-connection-mark=“TO_WAN1” passthrough=no nth=2,1
add action=mark-connection chain=prerouting comment=“myMark” connection-state=new disabled=no new-connection-mark=“TO_WAN2” passthrough=no nth=2,1
