PCC or NTH over VLANS with Hotspot
Hi All,
I currently have 3 WAN links load balanced for 8 VLANs using NTH and every thing works fine. I run NTH for load balancing with hotspot and it works perfectly. But the only problem i have is that once NTH starts to work, i loose connectivity between systems on my network. I can only reach(ping) systems from within the router. For example systems within my LAN cannot reach the servers within my LAN. Please i really need your help with this, as i have tried everything i can to get this to work.
Someone suggested that i use PCC, if i am to use PCC again(because i have used it before and it seemes not to work). Will i repeat this part
add chain=prerouting dst-address=10.111.0.0/24 action=accept in-interface=Local
add chain=prerouting dst-address=10.112.0.0/24 action=accept in-interface=Local
for the 8 VLANs?
Reference:
http://wiki.mikrotik.com/wiki/Manual:PCC
yep, add those rules with your LAN addresses
