ok now im having the following problem port forwarding is working on my router but only from my on public ip address 196.212.100.148 and cannot access it via 41.134.110.10 but if i dissable interface 196.212.100.148 ,41.134.110.10 starts working!
here is my nat print:
0 ;;; Loopback-Connection 1
chain=srcnat action=masquerade protocol=tcp src-address=192.168.88.0/24 dst-address=192.168.88.2 out-interface=ether2-Main-LAN
1 chain=srcnat action=masquerade out-interface=ether1-Mweb-Router
2 I chain=srcnat action=masquerade out-interface=ether3-I.S-Router
3 chain=dstnat action=dst-nat to-addresses=192.168.88.2 to-ports=20-21 protocol=tcp dst-address=41.134.110.10 dst-port=20-21
4 chain=dstnat action=dst-nat to-addresses=192.168.88.2 to-ports=22 protocol=tcp dst-address=41.134.110.10 dst-port=22
5 chain=dstnat action=dst-nat to-addresses=192.168.88.2 to-ports=80 protocol=tcp dst-address=41.134.110.10 dst-port=80
6 chain=dstnat action=dst-nat to-addresses=192.168.88.2 to-ports=81 protocol=tcp dst-address=41.134.110.10 dst-port=81
7 chain=dstnat action=dst-nat to-addresses=192.168.88.2 to-ports=443 protocol=tcp dst-address=41.134.110.10 dst-port=443
8 chain=dstnat action=dst-nat to-addresses=192.168.88.2 to-ports=3203 protocol=tcp dst-address=41.134.110.10 dst-port=3203
9 chain=dstnat action=dst-nat to-addresses=192.168.88.2 to-ports=3204 protocol=tcp dst-address=41.134.110.10 dst-port=3204
10 chain=dstnat action=dst-nat to-addresses=192.168.88.2 to-ports=3306 protocol=tcp dst-address=41.134.110.10 dst-port=3306
11 chain=dstnat action=dst-nat to-addresses=192.168.88.2 to-ports=5900-5935 protocol=tcp dst-address=41.134.110.10 dst-port=5900-5935
12 chain=dstnat action=dst-nat to-addresses=192.168.88.2 to-ports=6000-6001 protocol=tcp dst-address=41.134.110.10 dst-port=6000-6001
13 chain=dstnat action=dst-nat to-addresses=192.168.88.2 to-ports=6010 protocol=tcp dst-address=41.134.110.10 dst-port=6010
14 chain=dstnat action=dst-nat to-addresses=192.168.88.2 to-ports=7000 protocol=tcp dst-address=41.134.110.10 dst-port=7000
15 chain=dstnat action=dst-nat to-addresses=192.168.88.2 to-ports=8080-8082 protocol=tcp dst-address=41.134.110.10 dst-port=8080-8082
16 chain=dstnat action=dst-nat to-addresses=192.168.88.2 to-ports=20-21 protocol=tcp dst-address=196.212.100.148 dst-port=20-21
17 chain=dstnat action=dst-nat to-addresses=192.168.88.2 to-ports=22 protocol=tcp dst-address=196.212.100.148 dst-port=22
18 chain=dstnat action=dst-nat to-addresses=192.168.88.2 to-ports=80 protocol=tcp dst-address=196.212.100.148 dst-port=80
19 chain=dstnat action=dst-nat to-addresses=192.168.88.2 to-ports=81 protocol=tcp dst-address=196.212.100.148 dst-port=81
20 chain=dstnat action=dst-nat to-addresses=192.168.88.2 to-ports=443 protocol=tcp dst-address=196.212.100.148 dst-port=443
21 chain=dstnat action=dst-nat to-addresses=192.168.88.2 to-ports=3203 protocol=tcp dst-address=196.212.100.148 dst-port=3203
22 chain=dstnat action=dst-nat to-addresses=192.168.88.2 to-ports=3204 protocol=tcp dst-address=196.212.100.148 dst-port=3204
23 chain=dstnat action=dst-nat to-addresses=192.168.88.2 to-ports=3306 protocol=tcp dst-address=196.212.100.148 dst-port=3306
24 chain=dstnat action=dst-nat to-addresses=192.168.88.2 to-ports=5900-5935 protocol=tcp dst-address=196.212.100.148 dst-port=5900-5935
25 chain=dstnat action=dst-nat to-addresses=192.168.88.2 to-ports=6000-6001 protocol=tcp dst-address=196.212.100.148 dst-port=6000-6001
26 chain=dstnat action=dst-nat to-addresses=192.168.88.2 to-ports=6010 protocol=tcp dst-address=196.212.100.148 dst-port=6010
27 chain=dstnat action=dst-nat to-addresses=192.168.88.2 to-ports=7000 protocol=tcp dst-address=196.212.100.148 dst-port=7000
28 chain=dstnat action=dst-nat to-addresses=192.168.88.2 to-ports=8080-8082 protocol=tcp dst-address=196.212.100.148 dst-port=8080-8082
and my mangel print:
0 chain=input action=mark-connection new-connection-mark=wan1_conn passthrough=no in-interface=ether1-Mweb-Router
1 I chain=input action=mark-connection new-connection-mark=wan2_conn passthrough=no in-interface=ether3-I.S-Router
2 chain=output action=mark-routing new-routing-mark=to_wan1 passthrough=no out-interface=ether1-Mweb-Router
3 I chain=output action=mark-routing new-routing-mark=to_wan2 passthrough=no out-interface=ether3-I.S-Router
4 chain=prerouting action=accept dst-address=41.134.110.0/28 in-interface=ether2-Main-LAN
5 chain=prerouting action=accept dst-address=196.212.100.0/28 in-interface=ether2-Main-LAN
6 chain=prerouting action=accept protocol=tcp src-address=41.134.110.0/28 in-interface=ether1-Mweb-Router src-port=20-21
7 chain=prerouting action=accept protocol=tcp src-address=41.134.110.0/28 in-interface=ether1-Mweb-Router src-port=22
8 chain=prerouting action=accept protocol=tcp src-address=41.134.110.0/28 in-interface=ether1-Mweb-Router src-port=80
9 chain=prerouting action=accept protocol=tcp src-address=41.134.110.0/28 in-interface=ether1-Mweb-Router src-port=81
10 chain=prerouting action=accept protocol=tcp src-address=41.134.110.0/28 in-interface=ether1-Mweb-Router src-port=443
11 chain=prerouting action=accept protocol=tcp src-address=41.134.110.0/28 in-interface=ether1-Mweb-Router src-port=3203
12 chain=prerouting action=accept protocol=tcp src-address=41.134.110.0/28 in-interface=ether1-Mweb-Router src-port=3204
13 chain=prerouting action=accept protocol=tcp src-address=41.134.110.0/28 in-interface=ether1-Mweb-Router src-port=3306
14 chain=prerouting action=accept protocol=tcp src-address=41.134.110.0/28 in-interface=ether1-Mweb-Router src-port=5900-5935
15 chain=prerouting action=accept protocol=tcp src-address=41.134.110.0/28 in-interface=ether1-Mweb-Router src-port=6010
16 chain=prerouting action=accept protocol=tcp src-address=41.134.110.0/28 in-interface=ether1-Mweb-Router src-port=6000-6001
17 chain=prerouting action=accept protocol=tcp src-address=41.134.110.0/28 in-interface=ether1-Mweb-Router src-port=7000
18 chain=prerouting action=accept protocol=tcp src-address=41.134.110.0/28 in-interface=ether1-Mweb-Router src-port=8080-8082
19 chain=prerouting action=accept protocol=tcp src-address=196.212.100.0/28 src-port=20-21
20 chain=prerouting action=accept protocol=tcp src-address=196.212.100.0/28 src-port=22
21 chain=prerouting action=accept protocol=tcp src-address=196.212.100.0/28 src-port=80
22 chain=prerouting action=accept protocol=tcp src-address=196.212.100.0/28 src-port=81
23 chain=prerouting action=accept protocol=tcp src-address=196.212.100.0/28 src-port=5900-5935
24 chain=prerouting action=accept protocol=tcp src-address=196.212.100.0/28 src-port=3203
25 chain=prerouting action=accept protocol=tcp src-address=196.212.100.0/28 src-port=3204
26 chain=prerouting action=accept protocol=tcp src-address=196.212.100.0/28 src-port=443
27 chain=prerouting action=accept protocol=tcp src-address=196.212.100.0/28 src-port=3306
28 chain=prerouting action=accept protocol=tcp src-address=196.212.100.0/28 src-port=6010
29 chain=prerouting action=accept protocol=tcp src-address=196.212.100.0/28 src-port=6000-6001
30 chain=prerouting action=accept protocol=tcp src-address=196.212.100.0/28 src-port=7000
31 chain=prerouting action=accept protocol=tcp src-address=196.212.100.0/28 src-port=8080-8082
32 chain=prerouting action=mark-connection new-connection-mark=wan1_conn passthrough=yes dst-address=!192.168.88.0/24 in-interface=ether2-Main-LAN
per-connection-classifier=both-addresses:2/0
33 chain=prerouting action=mark-connection new-connection-mark=wan2_conn passthrough=yes dst-address=!192.168.88.0/24 in-interface=ether2-Main-LAN
per-connection-classifier=both-addresses:2/1
34 chain=prerouting action=mark-routing new-routing-mark=to_wan1 passthrough=no in-interface=ether2-Main-LAN connection-mark=wan1_conn
35 chain=prerouting action=mark-routing new-routing-mark=to_wan2 passthrough=no in-interface=ether2-Main-LAN connection-mark=wan2_conn
and my route print:
DST-ADDRESS PREF-SRC GATEWAY DISTANCE
0 A S 0.0.0.0/0 41.134.110.9 1
1 S 0.0.0.0/0 196.212.100.145 1
2 A S 0.0.0.0/0 41.134.110.9 1
3 S 0.0.0.0/0 196.212.100.145 2
4 ADC 41.134.110.0/28 41.134.110.10 ether1-Mweb-Router 0
5 ADC 192.168.88.0/24 192.168.88.1 ether2-Main-LAN 0
so basically what happens was the connection comes in but it leaves via the other wan connection, how do i make it use the same rout it came in from?
