PCC + pppoe clients + routing trouble
Hi
I’m having some trouble with setting up a RB1200 for load balancing over 2 ADSL links. The problem appears to be that anything marked for the second link doesn’t find it’s way out. That includes inbound and outbound. When I switch the default route to pppoe-out2 then the second link works. At the moment the second link default route with distance=2 is not active. I have checked my connections and they are getting the correct route marking.
I’ve followed the PCC wiki page meticulously and the only difference in my set-up is the per-connection-classifier. I have tried a couple of different configuration and nothing is working as it should. I suspect there is something wrong elsewhere in my configuration that I am missing and need some help spotting it. Can you help?
/interface pppoe-client
add ac-name="" add-default-route=no allow=pap,chap,mschap1,mschap2 comment=\
    "" dial-on-demand=no disabled=no interface=ether9 \
    max-mru=1480 max-mtu=1480 mrru=disabled name=pppoe-out1 password=xxxxxx \
    profile=default service-name="" use-peer-dns=no user=\
    xxxxxxxxxxx
    "" dial-on-demand=no disabled=no interface=\
    ether8 max-mru=1480 max-mtu=1480 mrru=disabled name=pppoe-out2 password=\
    xxxxxx profile=default service-name="" use-peer-dns=no user=\
    xxxxxxxxxxx
add address=192.168.0.253/24 comment="LAN Bridge interface" disabled=no \
    interface=lan-ether1 network=192.168.0.0
add address=10.0.0.253/32 disabled=no interface=ether10 network=255.255.255.0
add address=192.168.1.10/24 disabled=no interface=ether8 network=192.168.1.0
ether8 is the second link modem that has an IP of 192.168.1.1 for web management.
/ip firewall mangle
add action=mark-routing chain=prerouting connection-mark=wan1_conn disabled=no in-interface=lan-ether1 new-routing-mark=to_wan1 passthrough=no
add action=mark-routing chain=prerouting connection-mark=wan2_conn disabled=no in-interface=lan-ether1 new-routing-mark=to_wan2 passthrough=no
add action=mark-connection chain=prerouting connection-mark=no-mark disabled=no in-interface=pppoe-out1 new-connection-mark=wan1_conn passthrough=yes
add action=mark-connection chain=prerouting connection-mark=no-mark disabled=no in-interface=pppoe-out2 new-connection-mark=wan2_conn passthrough=yes
add action=mark-connection chain=prerouting connection-mark=no-mark disabled=no dst-address-type=!local in-interface=lan-ether1 new-connection-mark=wan1_conn passthrough=yes per-connection-classifier=\
    src-address:2/0
add action=mark-connection chain=prerouting connection-mark=no-mark disabled=no dst-address-type=!local in-interface=lan-ether1 new-connection-mark=wan2_conn passthrough=yes per-connection-classifier=\
    src-address:2/1
add action=mark-routing chain=output connection-mark=wan1_conn disabled=no new-routing-mark=to_wan1 passthrough=yes
add action=mark-routing chain=output connection-mark=wan2_conn disabled=no new-routing-mark=to_wan2 passthrough=yes
add check-gateway=ping disabled=no distance=1 dst-address=0.0.0.0/0 gateway=pppoe-out1 routing-mark=to_wan1 scope=30 target-scope=10
add check-gateway=ping disabled=no distance=1 dst-address=0.0.0.0/0 gateway=pppoe-out2 routing-mark=to_wan2 scope=30 target-scope=10
add check-gateway=ping disabled=no distance=1 dst-address=0.0.0.0/0 gateway=pppoe-out1 scope=30 target-scope=10
add check-gateway=ping disabled=no distance=2 dst-address=0.0.0.0/0 gateway=pppoe-out2 scope=30 target-scope=1
add action=dst-nat chain=dstnat comment="" disabled=no dst-port=5222,5223,7777,9090,9091 in-interface=!lan-ether1 protocol=tcp to-addresses=192.168.0.153
add action=dst-nat chain=dstnat comment="" disabled=no dst-port=25,443,465,993,3103 in-interface=!lan-ether1 protocol=tcp to-addresses=192.168.0.175
add action=dst-nat chain=dstnat comment="Service ports from kwagga -> exch-cpt" disabled=no dst-port=110,995,5669,12489 in-interface=!lan-ether1 protocol=tcp src-address=xxx.xx.xx.x to-addresses=192.168.0.175
add action=dst-nat chain=dstnat comment="" disabled=no dst-port=5670 in-interface=!lan-ether1 protocol=udp to-addresses=192.168.0.175 to-ports=161
add action=dst-nat chain=dstnat comment="" disabled=no dst-port=873 in-interface=!lan-ether1 protocol=tcp to-addresses=192.168.0.152
add action=dst-nat chain=dstnat comment="" disabled=no dst-port=5668 in-interface=!lan-ether1 protocol=tcp src-address=xxx.xx.xx.x to-addresses=192.168.0.136
add action=dst-nat chain=dstnat comment="" disabled=no dst-port=5671 in-interface=!lan-ether1 protocol=tcp src-address=xxx.xx.xx.x to-addresses=192.168.0.155
add action=dst-nat chain=dstnat comment="" disabled=no dst-port=5667 in-interface=!lan-ether1 protocol=tcp src-address=xxx.xx.xx.x to-addresses=192.168.0.154
add action=masquerade chain=srcnat disabled=no out-interface=pppoe-out1
add action=masquerade chain=srcnat disabled=no out-interface=pppoe-out2
add action=accept chain=input comment="accept established connection packets" connection-state=established disabled=no
add action=accept chain=input comment="accept related connection packets" connection-state=related disabled=no
add action=drop chain=input comment="drop invalid packets" connection-state=invalid disabled=no
add action=accept chain=input disabled=no src-address=192.168.0.0/24
add action=jump chain=input comment="jump to chain ICMP" disabled=no jump-target=icmp protocol=icmp
add action=accept chain=input comment="Allow Broadcast Traffic" disabled=no dst-address-type=broadcast
add action=log chain=input disabled=no log-prefix="Filter:"
add action=drop chain=input comment="drop everything else" disabled=no
add action=accept chain=icmp disabled=no src-address=xxx.xx.xx.x
add action=drop chain=icmp comment="Drop everything else" disabled=no protocol=icmp
add action=drop chain=forward comment="drop invalid connections" connection-state=invalid disabled=no protocol=tcp
add action=accept chain=forward comment="allow already established connections" connection-state=established disabled=no
add action=accept chain=forward comment="allow related connections" connection-state=related disabled=no
add action=drop chain=forward disabled=no src-address=0.0.0.0/8
add action=drop chain=forward disabled=no dst-address=0.0.0.0/8
add action=drop chain=forward disabled=no src-address=127.0.0.0/8
add action=drop chain=forward disabled=no dst-address=127.0.0.0/8
add action=drop chain=forward disabled=no src-address=224.0.0.0/3
add action=drop chain=forward disabled=no dst-address=224.0.0.0/3
add action=accept chain=forward comment="" disabled=no src-address=192.168.0.175
add action=accept chain=forward comment="" disabled=no src-address=192.168.0.136
add action=accept chain=forward comment="" disabled=no src-address-list=servers-lan
add action=accept chain=forward comment="" disabled=no src-address-list=trusted-lan
add action=jump chain=forward disabled=no jump-target=tcp protocol=tcp
add action=jump chain=forward disabled=no jump-target=udp protocol=udp
add action=jump chain=forward disabled=no jump-target=icmp protocol=icmp
add action=accept chain=tcp comment="" disabled=no dst-port=25,53,80,110,143,443,873,1194,3690,5228,5666-5671,8200,9418,12489 protocol=tcp
add action=accept chain=udp comment="" disabled=no dst-port=53,123,161,1194,33434-33534 protocol=udp
add action=accept chain=forward comment="" disabled=no dst-port=\
    21,22,1022,1222,3000,3389-3397,8080,8081,8291,60080,65443 protocol=tcp src-address-list=support-engineers
add action=log chain=forward disabled=no log-prefix="Filter:"
add action=drop chain=forward comment="Drop everthing else" disabled=no
add ac-name=“” > add-default-route=no > allow=pap,chap,mschap1,mschap2 comment=
“” dial-on-demand=no disabled=no interface=ether9
profile=default service-name=“” use-peer-dns=no user=
xxxxxxxxxxx
xxxxxx profile=default service-name=“” use-peer-dns=no user=
xxxxxxxxxxx
i have a question according to the bolt parameter. Why don’t you set is to yes?
My suggestion, to have better overview for troubleshooting, first you will need to focus on the PCC load balancing issue, therefore just disable everything except related setting mentioned on the wiki,
a) mangle
b) routing table
c) ip address
d) nat (just leave the src-nat to output interface as you did and turn off another setting)
Make sure this basic configuration work. As a Second step you could go to dst-nat. As you have dst-nat setting make sure your pcc does not impact to incomming connection. Otherwise you will response the request of the user on the internet site with difference route (ip address) and i would not work.
Third Step go with the firewall rules and so on
When I enable that the distance field is greyed out. Following the wiki example I need to set distance to 1 & 2.
Thanks for the suggestions. I’ve redone my configuration and dropped the pppoe clients in favor of the working example on the wiki with local IPs. I have also disbaled all the NAT (other than applicable masq) and filter rules for now.
I now have inbound on both links and my LAN users are able to browse out, but only on the first link. Entry for entry my set-up is the same as the wiki page, the only thing I can see is that the 2nd link default route is not active.
I suspect that has to be the case?
Something interesting. When I try to ping a public IP from the seconf link, I get exactly one reply and then the rest is dropped.
Could you attach the ip firewall mangle screen shot?
My configuration is working now. The problem was the order of my mangle rules.
Posting your “solution” rather than “it works now” might help someone else…
:slight_smile:
Nothing changed. I simply dragged the mangle rules so that they appear in the same order as the PCC wiki page.
