hi guys,
i need your help, the problem probably is my confs, let me explain my structure
RB1000, ROS 3.30
ether1 - LAN
ether3 - 8Mb throw cisco router
ether4 - 4Mb throw cisco router
my lan network 10.13.0.0
I have LoadBalance with PCC working not soo good, that’s why i’m here asking your help.
My problem:
INTERNET
RB1000 (PCC)
rb750 (pptp)
i’m trying to implementa a pptp server on rb750, with a SRC AND DST NAT with a Valid ip on RB1000 to the rb750, sometimes i can connect and sometimes not!
I think that the problem is because the connections is comming from the link 1 and it’s getting back to link 2.
I saw on forums, including the one that i follow to implement the pcc, that i must “accept” from connected networks to avoid the balancing, but i’m still getting this problem.
My rules:
/ip firewall mangle
add action=accept chain=prerouting comment="Sem Balance" disabled=no dst-address-list=SemBalance
add action=accept chain=prerouting comment="" disabled=no dst-address=xxx.xxx.xxx.104/29 in-interface=ether1
add action=accept chain=prerouting comment="" disabled=no dst-address=xxx.xxx.xxx.96/28 in-interface=ether1
add action=mark-connection chain=input comment=\
"____________Inicio Conf PCC (Load Balance) --------------- Marca Conexoes de entrada para que voltem pelo mesmo link" disabled=no in-interface=\
ether3 new-connection-mark=EBT_conn passthrough=yes
add action=mark-connection chain=input comment="" disabled=no in-interface=ether4 new-connection-mark=OI_conn passthrough=yes
add action=mark-connection chain=output comment="Load Balance Proxy" connection-state=new disabled=no new-connection-mark=EBT_conn passthrough=yes \
per-connection-classifier=both-addresses:3/0
add action=mark-connection chain=output comment="" connection-state=new disabled=no new-connection-mark=EBT_conn passthrough=yes per-connection-classifier=\
both-addresses:3/1
add action=mark-connection chain=output comment="" connection-state=new disabled=no new-connection-mark=OI_conn passthrough=yes per-connection-classifier=\
both-addresses:3/2
add action=mark-routing chain=output comment="Retorna as conexoes marcadas no inicio, pelo mesmo link que entraram" connection-mark=EBT_conn disabled=no \
new-routing-mark=EBT_traffic passthrough=yes
add action=mark-routing chain=output comment="" connection-mark=OI_conn disabled=no new-routing-mark=OI_traffic passthrough=yes
add action=mark-connection chain=prerouting comment=\
"Load Balance (PCC), para os dois links (OI e EBT) sendo um peso maior o link da EBT por causa da velocidade maior" disabled=no dst-address-type=!local \
in-interface=ether1 new-connection-mark=EBT_conn passthrough=yes per-connection-classifier=both-addresses-and-ports:3/0
add action=mark-connection chain=prerouting comment="" disabled=no dst-address-type=!local in-interface=ether1 new-connection-mark=EBT_conn passthrough=yes \
per-connection-classifier=both-addresses-and-ports:3/1
add action=mark-connection chain=prerouting comment="" disabled=no dst-address-type=!local in-interface=ether1 new-connection-mark=OI_conn passthrough=yes \
per-connection-classifier=both-addresses-and-ports:3/2
add action=mark-routing chain=prerouting comment=\
"Aponta as conexoes do load balance para as novas tabelas de roteamento, possibilitando o Load Balance(PCC)" connection-mark=EBT_conn disabled=no \
in-interface=ether1 new-routing-mark=EBT_traffic passthrough=yes
add action=mark-routing chain=prerouting comment="____________FIM Load Balance (PCC)" connection-mark=OI_conn disabled=no in-interface=ether1 \
Can you help me?
And, sorry for my bad english!!
greets from brazil!
Luiz Maia
Lcm
