PCC PROBLEM
hi there
I have 5xDSL lines
conn1 5 Mbps
conn2 5 Mbps
conn3 3.5 Mbps
conn4 3.5 Mbps
conn5 2.5 Mbps
I see a problem that all of 5 dsl lines get the same traffic
/ip firewall mangle export
add action=accept chain=prerouting comment=“” disabled=no dst-address=
192.168.1.0/24 in-interface=LAN
192.168.2.0/24 in-interface=LAN
192.168.3.0/24 in-interface=LAN
192.168.4.0/24 in-interface=LAN
192.168.5.0/24 in-interface=LAN
add action=mark-connection chain=prerouting comment=“” connection-mark=no-mark
disabled=no in-interface=ISP1 new-connection-mark=conn1 passthrough=yes
disabled=no in-interface=ISP2 new-connection-mark=conn2 passthrough=yes
disabled=no in-interface=ISP3 new-connection-mark=conn3 passthrough=yes
disabled=no in-interface=ISP4 new-connection-mark=conn4 passthrough=yes
disabled=no in-interface=ISP5 new-connection-mark=conn5 passthrough=yes
disabled=no dst-address-type=!local in-interface=LAN new-connection-mark=
conn1 passthrough=yes per-connection-classifier=both-addresses:5/0
conn2 passthrough=yes per-connection-classifier=both-addresses:5/1
conn3 passthrough=yes per-connection-classifier=both-addresses:5/2
conn4 passthrough=yes per-connection-classifier=both-addresses:5/3
conn5 passthrough=yes per-connection-classifier=both-addresses:5/4
add action=mark-routing chain=prerouting comment=“” connection-mark=conn1
disabled=no in-interface=LAN new-routing-mark=to_conn1 passthrough=
yes
add action=mark-routing chain=prerouting comment=“” connection-mark=conn2
disabled=no in-interface=LAN new-routing-mark=to_conn2 passthrough=
yes
add action=mark-routing chain=prerouting comment=“” connection-mark=conn3
disabled=no in-interface=LAN new-routing-mark=to_conn3 passthrough=
yes
add action=mark-routing chain=prerouting comment=“” connection-mark=conn4
disabled=no in-interface=LAN new-routing-mark=to_conn4 passthrough=
yes
add action=mark-routing chain=prerouting comment=“” connection-mark=conn5
disabled=no in-interface=LAN new-routing-mark=to_conn5 passthrough=
yes
add action=mark-routing chain=output comment=“” connection-mark=conn1
disabled=no new-routing-mark=to_conn1 passthrough=yes
add action=mark-routing chain=output comment=“” connection-mark=conn2
disabled=no new-routing-mark=to_conn2 passthrough=yes
add action=mark-routing chain=output comment=“” connection-mark=conn3
disabled=no new-routing-mark=to_conn3 passthrough=yes
add action=mark-routing chain=output comment=“” connection-mark=conn4
disabled=no new-routing-mark=to_conn4 passthrough=yes
add action=mark-routing chain=output comment=“” connection-mark=conn5
disabled=no new-routing-mark=to_conn5 passthrough=yes
I know that my problem is to per connection classifier denominator/remainder
please tell me what should i put to this denominator/reminder for the 5 dsl lines i have
For a completely even split, the smallest common denominator is 0.5 - 10 lines for 5 meg, 7 lines for 3.5 meg, 5 lines for 2.5 meg. That doesn’t scale well as that results in 39 lines total.
I would think it better to live with 2.5 meg splits, which will leave your 3.5 meg lines slightly underutilized:
add action=mark-connection chain=prerouting comment="" connection-mark=no-mark disabled=no dst-address-type=!local in-interface=LAN new-connection-mark=conn1 passthrough=yes per-connection-classifier=both-addresses:7/0
add action=mark-connection chain=prerouting comment="" connection-mark=no-mark disabled=no dst-address-type=!local in-interface=LAN new-connection-mark=conn1 passthrough=yes per-connection-classifier=both-addresses:7/1
add action=mark-connection chain=prerouting comment="" connection-mark=no-mark disabled=no dst-address-type=!local in-interface=LAN new-connection-mark=conn2 passthrough=yes per-connection-classifier=both-addresses:7/2
add action=mark-connection chain=prerouting comment="" connection-mark=no-mark disabled=no dst-address-type=!local in-interface=LAN new-connection-mark=conn2 passthrough=yes per-connection-classifier=both-addresses:7/3
add action=mark-connection chain=prerouting comment="" connection-mark=no-mark disabled=no dst-address-type=!local in-interface=LAN new-connection-mark=conn3 passthrough=yes per-connection-classifier=both-addresses:7/4
add action=mark-connection chain=prerouting comment="" connection-mark=no-mark disabled=no dst-address-type=!local in-interface=LAN new-connection-mark=conn4 passthrough=yes per-connection-classifier=both-addresses:7/5
add action=mark-connection chain=prerouting comment="" connection-mark=no-mark disabled=no dst-address-type=!local in-interface=LAN new-connection-mark=conn5 passthrough=yes per-connection-classifier=both-addresses:7/6
For reference, the 39 lines would be:
add action=mark-connection chain=prerouting comment="" connection-mark=no-mark disabled=no dst-address-type=!local in-interface=LAN new-connection-mark=conn1 passthrough=yes per-connection-classifier=both-addresses:39/0
add action=mark-connection chain=prerouting comment="" connection-mark=no-mark disabled=no dst-address-type=!local in-interface=LAN new-connection-mark=conn1 passthrough=yes per-connection-classifier=both-addresses:39/1
add action=mark-connection chain=prerouting comment="" connection-mark=no-mark disabled=no dst-address-type=!local in-interface=LAN new-connection-mark=conn1 passthrough=yes per-connection-classifier=both-addresses:39/2
add action=mark-connection chain=prerouting comment="" connection-mark=no-mark disabled=no dst-address-type=!local in-interface=LAN new-connection-mark=conn1 passthrough=yes per-connection-classifier=both-addresses:39/3
add action=mark-connection chain=prerouting comment="" connection-mark=no-mark disabled=no dst-address-type=!local in-interface=LAN new-connection-mark=conn1 passthrough=yes per-connection-classifier=both-addresses:39/4
add action=mark-connection chain=prerouting comment="" connection-mark=no-mark disabled=no dst-address-type=!local in-interface=LAN new-connection-mark=conn1 passthrough=yes per-connection-classifier=both-addresses:39/5
add action=mark-connection chain=prerouting comment="" connection-mark=no-mark disabled=no dst-address-type=!local in-interface=LAN new-connection-mark=conn1 passthrough=yes per-connection-classifier=both-addresses:39/6
add action=mark-connection chain=prerouting comment="" connection-mark=no-mark disabled=no dst-address-type=!local in-interface=LAN new-connection-mark=conn1 passthrough=yes per-connection-classifier=both-addresses:39/7
add action=mark-connection chain=prerouting comment="" connection-mark=no-mark disabled=no dst-address-type=!local in-interface=LAN new-connection-mark=conn1 passthrough=yes per-connection-classifier=both-addresses:39/8
add action=mark-connection chain=prerouting comment="" connection-mark=no-mark disabled=no dst-address-type=!local in-interface=LAN new-connection-mark=conn1 passthrough=yes per-connection-classifier=both-addresses:39/9
add action=mark-connection chain=prerouting comment="" connection-mark=no-mark disabled=no dst-address-type=!local in-interface=LAN new-connection-mark=conn2 passthrough=yes per-connection-classifier=both-addresses:39/10
add action=mark-connection chain=prerouting comment="" connection-mark=no-mark disabled=no dst-address-type=!local in-interface=LAN new-connection-mark=conn2 passthrough=yes per-connection-classifier=both-addresses:39/11
add action=mark-connection chain=prerouting comment="" connection-mark=no-mark disabled=no dst-address-type=!local in-interface=LAN new-connection-mark=conn2 passthrough=yes per-connection-classifier=both-addresses:39/12
add action=mark-connection chain=prerouting comment="" connection-mark=no-mark disabled=no dst-address-type=!local in-interface=LAN new-connection-mark=conn2 passthrough=yes per-connection-classifier=both-addresses:39/13
add action=mark-connection chain=prerouting comment="" connection-mark=no-mark disabled=no dst-address-type=!local in-interface=LAN new-connection-mark=conn2 passthrough=yes per-connection-classifier=both-addresses:39/14
add action=mark-connection chain=prerouting comment="" connection-mark=no-mark disabled=no dst-address-type=!local in-interface=LAN new-connection-mark=conn2 passthrough=yes per-connection-classifier=both-addresses:39/15
add action=mark-connection chain=prerouting comment="" connection-mark=no-mark disabled=no dst-address-type=!local in-interface=LAN new-connection-mark=conn2 passthrough=yes per-connection-classifier=both-addresses:39/16
add action=mark-connection chain=prerouting comment="" connection-mark=no-mark disabled=no dst-address-type=!local in-interface=LAN new-connection-mark=conn2 passthrough=yes per-connection-classifier=both-addresses:39/17
add action=mark-connection chain=prerouting comment="" connection-mark=no-mark disabled=no dst-address-type=!local in-interface=LAN new-connection-mark=conn2 passthrough=yes per-connection-classifier=both-addresses:39/18
add action=mark-connection chain=prerouting comment="" connection-mark=no-mark disabled=no dst-address-type=!local in-interface=LAN new-connection-mark=conn2 passthrough=yes per-connection-classifier=both-addresses:39/19
add action=mark-connection chain=prerouting comment="" connection-mark=no-mark disabled=no dst-address-type=!local in-interface=LAN new-connection-mark=conn3 passthrough=yes per-connection-classifier=both-addresses:39/20
add action=mark-connection chain=prerouting comment="" connection-mark=no-mark disabled=no dst-address-type=!local in-interface=LAN new-connection-mark=conn3 passthrough=yes per-connection-classifier=both-addresses:39/21
add action=mark-connection chain=prerouting comment="" connection-mark=no-mark disabled=no dst-address-type=!local in-interface=LAN new-connection-mark=conn3 passthrough=yes per-connection-classifier=both-addresses:39/22
add action=mark-connection chain=prerouting comment="" connection-mark=no-mark disabled=no dst-address-type=!local in-interface=LAN new-connection-mark=conn3 passthrough=yes per-connection-classifier=both-addresses:39/23
add action=mark-connection chain=prerouting comment="" connection-mark=no-mark disabled=no dst-address-type=!local in-interface=LAN new-connection-mark=conn3 passthrough=yes per-connection-classifier=both-addresses:39/24
add action=mark-connection chain=prerouting comment="" connection-mark=no-mark disabled=no dst-address-type=!local in-interface=LAN new-connection-mark=conn3 passthrough=yes per-connection-classifier=both-addresses:39/25
add action=mark-connection chain=prerouting comment="" connection-mark=no-mark disabled=no dst-address-type=!local in-interface=LAN new-connection-mark=conn3 passthrough=yes per-connection-classifier=both-addresses:39/26
add action=mark-connection chain=prerouting comment="" connection-mark=no-mark disabled=no dst-address-type=!local in-interface=LAN new-connection-mark=conn4 passthrough=yes per-connection-classifier=both-addresses:39/27
add action=mark-connection chain=prerouting comment="" connection-mark=no-mark disabled=no dst-address-type=!local in-interface=LAN new-connection-mark=conn4 passthrough=yes per-connection-classifier=both-addresses:39/28
add action=mark-connection chain=prerouting comment="" connection-mark=no-mark disabled=no dst-address-type=!local in-interface=LAN new-connection-mark=conn4 passthrough=yes per-connection-classifier=both-addresses:39/29
add action=mark-connection chain=prerouting comment="" connection-mark=no-mark disabled=no dst-address-type=!local in-interface=LAN new-connection-mark=conn4 passthrough=yes per-connection-classifier=both-addresses:39/30
add action=mark-connection chain=prerouting comment="" connection-mark=no-mark disabled=no dst-address-type=!local in-interface=LAN new-connection-mark=conn4 passthrough=yes per-connection-classifier=both-addresses:39/31
add action=mark-connection chain=prerouting comment="" connection-mark=no-mark disabled=no dst-address-type=!local in-interface=LAN new-connection-mark=conn4 passthrough=yes per-connection-classifier=both-addresses:39/32
add action=mark-connection chain=prerouting comment="" connection-mark=no-mark disabled=no dst-address-type=!local in-interface=LAN new-connection-mark=conn4 passthrough=yes per-connection-classifier=both-addresses:39/33
add action=mark-connection chain=prerouting comment="" connection-mark=no-mark disabled=no dst-address-type=!local in-interface=LAN new-connection-mark=conn5 passthrough=yes per-connection-classifier=both-addresses:39/34
add action=mark-connection chain=prerouting comment="" connection-mark=no-mark disabled=no dst-address-type=!local in-interface=LAN new-connection-mark=conn5 passthrough=yes per-connection-classifier=both-addresses:39/35
add action=mark-connection chain=prerouting comment="" connection-mark=no-mark disabled=no dst-address-type=!local in-interface=LAN new-connection-mark=conn5 passthrough=yes per-connection-classifier=both-addresses:39/36
add action=mark-connection chain=prerouting comment="" connection-mark=no-mark disabled=no dst-address-type=!local in-interface=LAN new-connection-mark=conn5 passthrough=yes per-connection-classifier=both-addresses:39/37
add action=mark-connection chain=prerouting comment="" connection-mark=no-mark disabled=no dst-address-type=!local in-interface=LAN new-connection-mark=conn5 passthrough=yes per-connection-classifier=both-addresses:39/38
But again: I wouldn’t use that.
On a sidenote, I hope this makes it clear how to derive those values. This is basic math, it’s very, very simple. You’re trying to find the smallest number that that 5, 3.5 and 2.5 cleanly divide by. That is 0.5. Then you need 5/0.5 = 10 lines for 5 meg pipes, 3.5/0.5 = 7 lines for 3.5 meg pipes, etc.
In your case that results in too many lines of configuration for packets to have to traverse, so it’s better to find a closer value that doesn’t completely fairly spread traffic, but results in less configuration. That value is 2.5 - it’s a clean division for 5 and 2.5, and 3.5 is a pretty close match for a factor of 1.
fewi i hope for you to respond
i understand this
please kindly tell me what is the best configuration for me?
you write a lot of rules here.
please please help me
if i make the all 5 lines 3.5mb what configuration can i put ?
I understand now
very very thanks fewi
