pcc setup return problem
ok well iv setted up my pcc just as cording to the manual but here is what boters me if someone tyes to access my one public ip 41.134.110.10 it times out but using my other one 196.212.100.148 it works but if i disabel 196.212.100.148 ip 41.134.110.10 starts working in its place wich is correct in a way but i want load balancing not failover! pcc is made for load balancing! here is my config!
nat:
0 ;;; Loopback
chain=srcnat action=masquerade src-address=192.168.88.0/24
dst-address=192.168.88.2 out-interface=ether2-Main-LAN
1 chain=src-nat action=accept dst-address=41.134.110.10
2 chain=src-nat action=accept dst-address=196.212.100.148
3 chain=srcnat action=masquerade out-interface=ether1-Mweb-Router
4 chain=srcnat action=masquerade out-interface=ether3-I.S-Router
5 chain=dstnat action=dst-nat to-addresses=192.168.88.2 to-ports=20-21
protocol=tcp dst-address=41.134.110.10 dst-port=20-21
6 chain=dstnat action=dst-nat to-addresses=192.168.88.2 to-ports=20-21
protocol=tcp dst-address=196.212.100.148 dst-port=20-21
7 chain=dstnat action=dst-nat to-addresses=192.168.88.2 to-ports=22
protocol=tcp dst-address=41.134.110.10 dst-port=22
8 chain=dstnat action=dst-nat to-addresses=192.168.88.2 to-ports=22
protocol=tcp dst-address=196.212.100.148 dst-port=22
9 chain=dstnat action=dst-nat to-addresses=192.168.88.2 to-ports=80
protocol=tcp dst-address=41.134.110.10 dst-port=80
10 chain=dstnat action=dst-nat to-addresses=192.168.88.2 to-ports=80
protocol=tcp dst-address=196.212.100.148 dst-port=80
11 chain=dstnat action=dst-nat to-addresses=192.168.88.2 to-ports=81
protocol=tcp dst-address=41.134.110.10 dst-port=81
12 chain=dstnat action=dst-nat to-addresses=192.168.88.2 to-ports=81
protocol=tcp dst-address=196.212.100.148 dst-port=81
13 chain=dstnat action=dst-nat to-addresses=192.168.88.2 to-ports=443
protocol=tcp dst-address=41.134.110.10 dst-port=443
14 chain=dstnat action=dst-nat to-addresses=192.168.88.2 to-ports=443
protocol=tcp dst-address=196.212.100.148 dst-port=443
15 chain=dstnat action=dst-nat to-addresses=192.168.88.2 to-ports=3203
protocol=tcp dst-address=41.134.110.10 dst-port=3203
16 chain=dstnat action=dst-nat to-addresses=192.168.88.2 to-ports=3203
protocol=tcp dst-address=196.212.100.148 dst-port=3203
17 chain=dstnat action=dst-nat to-addresses=192.168.88.2 to-ports=3204
protocol=tcp dst-address=41.134.110.10 dst-port=3204
18 chain=dstnat action=dst-nat to-addresses=192.168.88.2 to-ports=3204
protocol=tcp dst-address=196.212.100.148 dst-port=3204
19 chain=dstnat action=dst-nat to-addresses=192.168.88.2 to-ports=3306
protocol=tcp dst-address=41.134.110.10 dst-port=3306
20 chain=dstnat action=dst-nat to-addresses=192.168.88.2 to-ports=3306
protocol=tcp dst-address=196.212.100.148 dst-port=3306
21 chain=dstnat action=dst-nat to-addresses=192.168.88.2 to-ports=5900-5935
protocol=tcp dst-address=41.134.110.10 dst-port=5900-5935
22 chain=dstnat action=dst-nat to-addresses=192.168.88.2 to-ports=5900-5935
protocol=tcp dst-address=196.212.100.148 dst-port=5900-5935
23 chain=dstnat action=dst-nat to-addresses=192.168.88.2 to-ports=6000-6001
protocol=tcp dst-address=41.134.110.10 dst-port=6000-6001
24 chain=dstnat action=dst-nat to-addresses=192.168.88.2 to-ports=6000-6001
protocol=tcp dst-address=196.212.100.148 dst-port=6000-6001
25 chain=dstnat action=dst-nat to-addresses=192.168.88.2 to-ports=6010
protocol=tcp dst-address=41.134.110.10 dst-port=6010
26 chain=dstnat action=dst-nat to-addresses=192.168.88.2 to-ports=6010
protocol=tcp dst-address=196.212.100.148 dst-port=6010
27 chain=dstnat action=dst-nat to-addresses=192.168.88.2 to-ports=7000
protocol=tcp dst-address=41.134.110.10 dst-port=7000
28 chain=dstnat action=dst-nat to-addresses=192.168.88.2 to-ports=7000
protocol=tcp dst-address=196.212.100.148 dst-port=7000
29 chain=dstnat action=dst-nat to-addresses=192.168.88.2 to-ports=8080-8082
protocol=tcp dst-address=41.134.110.10 dst-port=8080-8082
30 chain=dstnat action=dst-nat to-addresses=192.168.88.2 to-ports=8080-8082
protocol=tcp dst-address=196.212.100.148 dst-port=8080-8082
mangel:
0 chain=input action=mark-connection new-connection-mark=wan1_conn
passthrough=no in-interface=ether1-Mweb-Router
1 chain=input action=mark-connection new-connection-mark=wan2_conn
passthrough=no in-interface=ether3-I.S-Router
2 chain=output action=mark-routing new-routing-mark=to_wan1 passthrough=no
3 chain=output action=mark-routing new-routing-mark=to_wan2 passthrough=no
4 chain=prerouting action=mark-connection new-connection-mark=wan1_conn
passthrough=yes dst-address=!192.168.88.0/24
in-interface=ether2-Main-LAN
per-connection-classifier=both-addresses:2/0
5 chain=prerouting action=mark-connection new-connection-mark=wan2_conn
in-interface=ether2-Main-LAN connection-mark=wan2_conn
per-connection-classifier=both-addresses:2/1
6 chain=prerouting action=accept dst-address=41.134.110.0/28
7 chain=prerouting action=accept dst-address=196.212.100.0/28
8 chain=prerouting action=mark-routing new-routing-mark=to_wan1
passthrough=no in-interface=ether2-Main-LAN connection-mark=wan1_conn
9 chain=prerouting action=mark-routing new-routing-mark=to_wan2
passthrough=no in-interface=ether2-Main-LAN connection-mark=wan2_conn
– [Q quit|D dump|up|down]
