PCC With 2 WANs mangle rules
Hi, i have problems with PCC configuration. As soon i enable Mangle rules i have difficulties to connect internet. For example no ping to internet from MGMT subnetwork.
At the moment failover between WAN1 and WAN2 works, but no load balancing.
I’m stuck and cant find out where or what i should change.
My Scheme
2 connections: from same ISP.
ISP cable modem1 in bridge configuration–>CAPaCRouter1Ether2 as WAN1
ISP cable modem2 in bridge configuration–>CAPaCRouter2Ether2_Vlan3–>Switch–>CAPaCRouter1Ether1 Vlan3 as WAN2
Here is CAPaCRouter1 configuration
add interface=bridge name=InternetVlan10 vlan-id=10
add interface=ether1 name=Internet_VLAN3 vlan-id=3
add interface=bridge name=KaameradVLAN20 vlan-id=20
add interface=bridge name=MGMTVlan99 vlan-id=99
add interface=bridge name=SuperuserVLAN40 vlan-id=40
add interface=bridge name=UksedVLAN30 vlan-id=30
add interface=bridge name=VoIP_VLAN50 vlan-id=50
set 0 vlan-header=add-if-missing vlan-mode=secure
set 2 vlan-mode=secure
add comment=defconf name=WAN
add comment=defconf name=LAN
add name=MGMT
add name=ALLLAN
add name=WAN1
add name=WAN2
add name=MGMTvlan99 ranges=192.168.99.100-192.168.99.120
add name=InternetVLAN10 ranges=192.168.10.20-192.168.10.254
add name=KaameradVLAN20 ranges=192.168.20.50-192.168.20.99
add name=UksedVLAN30 ranges=192.168.30.50-192.168.30.99
add name=SuperuserVLAN40 ranges=192.168.40.50-192.168.40.99
add name=VoIP_VLAN50 ranges=192.168.50.10-192.168.50.20
add address-pool=MGMTvlan99 disabled=no interface=MGMTVlan99 lease-time=3d
name=MGMTVlan99
add address-pool=InternetVLAN10 disabled=no interface=InternetVlan10
lease-time=30m name=InternetVLAN10
add address-pool=KaameradVLAN20 disabled=no interface=KaameradVLAN20
lease-time=30m name=KaameradVLAN20
add address-pool=UksedVLAN30 disabled=no interface=UksedVLAN30 lease-time=30m
name=UksedVLAN30
add address-pool=SuperuserVLAN40 disabled=no interface=SuperuserVLAN40
lease-time=30m name=SuperuserVLAN40
add address-pool=VoIP_VLAN50 disabled=no interface=VoIP_VLAN50 name=
VoIP_VLAN50
add bridge=bridge comment=defconf interface=wlan2
add bridge=bridge interface=wlan3
add bridge=bridge interface=ether1
set discover-interface-list=MGMT
/ip settings
set rp-filter=strict tcp-syncookies=yes
add independent-learning=no ports=ether1,switch1-cpu switch=switch1 vlan-id=
10
20
30
40
99
add independent-learning=no ports=ether1,switch1-cpu switch=switch1 vlan-id=3
50
add comment=defconf interface=Internet_VLAN3 list=WAN
add interface=MGMTVlan99 list=MGMT
add interface=InternetVlan10 list=LAN
add interface=KaameradVLAN20 list=LAN
add interface=SuperuserVLAN40 list=LAN
add interface=UksedVLAN30 list=LAN
add interface=ether2 list=WAN
add interface=InternetVlan10 list=ALLLAN
add interface=KaameradVLAN20 list=ALLLAN
add interface=MGMTVlan99 list=ALLLAN
add interface=SuperuserVLAN40 list=ALLLAN
add interface=UksedVLAN30 list=ALLLAN
add interface=ether2 list=WAN1
add interface=Internet_VLAN3 list=WAN2
add address=192.168.99.22/24 interface=MGMTVlan99 network=192.168.99.0
add address=192.168.10.1/24 interface=InternetVlan10 network=192.168.10.0
add address=192.168.20.1/24 interface=KaameradVLAN20 network=192.168.20.0
add address=192.168.30.1/24 interface=UksedVLAN30 network=192.168.30.0
add address=192.168.40.1/24 interface=SuperuserVLAN40 network=192.168.40.0
add address=192.168.50.1/24 interface=VoIP_VLAN50 network=192.168.50.0
add address=192.168.3.2/24 interface=Internet_VLAN3 network=192.168.3.0
/ip dhcp-client
Script!!
add address=192.168.10.0/24 dns-server=192.168.99.22 gateway=192.168.10.1
netmask=24
add address=192.168.20.0/24 dns-server=192.168.99.22 gateway=192.168.20.1
netmask=24
add address=192.168.30.0/24 dns-server=192.168.99.22 gateway=192.168.30.1
netmask=24
add address=192.168.40.0/24 dns-server=192.168.99.22 gateway=192.168.40.1
netmask=24
add address=192.168.50.0/24 dns-server=192.168.99.22 gateway=192.168.50.1
netmask=24
add address=192.168.99.0/24 dns-server=192.168.99.22 gateway=192.168.99.22
netmask=24
set allow-remote-requests=yes servers=8.8.8.8,8.8.4.4
/ip firewall address-list
add address=212.7.26.0/24 comment=wan0 list=wanSubnets; From script
add address=192.168.10.0/24 comment=“Lubatud sisevorgu aadressi vahemik”
list=“Lubatud aadressid”
add address=192.168.20.0/24 comment=“Lubatud sisevorgu aadressi vahemik”
add address=192.168.30.0/24 comment=“Lubatud sisevorgu aadressi vahemik”
add address=192.168.40.0/24 comment=“Lubatud sisevorgu aadressi vahemik”
add address=192.168.99.0/24 comment=“MGMT IP vahemik” list=MGMT
add address=192.168.50.0/24 comment=“Lubatud sisevorgu aadressi vahemik”
add address=192.168.99.0/24 comment=“Lubatud sisevorgu aadressi vahemik”
/ip firewall mangle
add action=accept chain=prerouting dst-address-list=“Lubatud aadressid”
in-interface-list=ALLLAN log-prefix=“accept prerout”
add action=accept chain=prerouting dst-address-list=wanSubnets
add action=accept chain=prerouting dst-address=192.168.3.0/24
add action=mark-connection chain=prerouting connection-mark=no-mark
in-interface-list=WAN1 new-connection-mark=wan1_conn passthrough=yes
in-interface-list=WAN2 new-connection-mark=wan2_conn passthrough=yes
dst-address-type=!local in-interface-list=ALLLAN new-connection-mark=
wan1_conn passthrough=yes per-connection-classifier=both-addresses:2/0
wan2_conn passthrough=yes per-connection-classifier=both-addresses:2/1
add action=mark-routing chain=prerouting connection-mark=wan1_conn
in-interface-list=ALLLAN new-routing-mark=to_wan1 passthrough=yes
add action=mark-routing chain=prerouting connection-mark=wan2_conn
in-interface-list=ALLLAN new-routing-mark=to_wan2 passthrough=yes
add action=mark-routing chain=output connection-mark=wan1_conn
new-routing-mark=to_wan1 passthrough=no
add action=mark-routing chain=output connection-mark=wan2_conn
new-routing-mark=to_wan2 passthrough=no
add action=masquerade chain=srcnat comment=“defconf: masquerade”
out-interface-list=WAN1
out-interface-list=WAN2
add check-gateway=ping comment=to_wan1 distance=1 gateway=8.8.8.8
add check-gateway=ping comment=to_wan1 distance=2 gateway=8.8.4.4
add check-gateway=ping comment=" to_wan2" distance=1 gateway=8.8.4.4
add check-gateway=ping comment=" to_wan2" distance=2 gateway=8.8.8.8
add check-gateway=ping comment=" to_wan2" distance=2 gateway=8.8.4.4
add check-gateway=ping comment=" to_wan2" distance=1 dst-address=8.8.4.4/32
gateway=192.168.3.1 scope=10
add check-gateway=ping comment=to_wan1 distance=1 dst-address=8.8.8.8/32
gateway=212.7.26.1 scope=10
Maybe problem is that Ether1 interface is a bridge port and with that hardware i cant achieve what i want. Do i need more ports?
Under /ip settings you have rp-filter set to strict ; this does not work correctly with routing tables per https://wiki.mikrotik.com/wiki/Manual:IP/Settings#Properties
Try setting your rp-filter to loose and see if that helps resolve.
Thank You issme!
Seems it helped.
I have question, if i monitor my firewall i don’t see any hits on those mangle rules
Why is it so?
