I’m having an issue with implementing pcc in my mikrotik RB4011iGS+5HacQ2HnD i have followed multiple tutorials and forums,in my setup i have 2 pppoe links for the internet one 1gb link and one 300mb link,all my clients are behind a bridge trough pppoe,so for the mangle rules too work i have to go in /bridge/setting and enable ip firewall for pppoe,the problem is that when i enable it and test the connection on the clients they get instead of the default 10mb/s connection some 50kb/s.Ive tried to change mangle and firewall rules and checked the cpu load,but it doesn’t exceed 10% worst case,so i don’t really know what to do,it appears to be worse on windows machines(i use them for testing in the network) than on linux(my personal pc),but they are all behind the same modem that uses pppoe in the bridge.If someone could shed some light in what could i do to get a decent troughput i would be glad.
I have this mangle rules rigth now:
add action=mark-connection chain=prerouting comment=\
"marca conn 300mb_in no modem" connection-mark=no-mark in-interface=\
Link_300mb_Alg new-connection-mark=Link_300mb passthrough=yes
"Marca conn 1gb_in no modem" connection-mark=no-mark in-interface=\
Link_1Gb_Alg new-connection-mark=Link_1gb passthrough=yes
"marca conn 1gb da bridge pra fora com pcc" connection-mark=no-mark \
connection-state=new dst-address-type=!local in-bridge-port-list=Lan2 \
in-interface=bridge new-connection-mark=Link_1gb passthrough=yes \
per-connection-classifier=src-address:2/0 routing-mark=!link_1gb
"marca conn 300mb da bridge pra fora com pcc" connection-mark=no-mark \
in-interface=bridge new-connection-mark=Link_300mb passthrough=yes \
per-connection-classifier=src-address:2/1 routing-mark=!link_300mb
connection-state=new disabled=yes dst-address-type=!local \
in-bridge-port-list=Lan2 in-interface=bridge new-connection-mark=Link_1gb \
passthrough=yes per-connection-classifier=src-address:5/3
passthrough=yes per-connection-classifier=src-address:5/4
passthrough=yes per-connection-classifier=src-address:5/2
add action=mark-routing chain=prerouting comment=\
"roteia conn 1gb_in marcada da bridge para o modem" connection-mark=\
Link_1gb connection-state=new disabled=yes in-bridge-port-list=Lan2 \
in-interface=bridge new-routing-mark=link_1gb passthrough=no
"roteia conn 300mb_in marcada da bridge pro modem" connection-mark=\
Link_300mb connection-state=new disabled=yes in-bridge-port-list=Lan2 \
in-interface=bridge new-routing-mark=link_300mb passthrough=no \
"marca conn 1gb saindo do modem" connection-mark=Link_1gb \
connection-state=new new-routing-mark=link_1gb passthrough=no \
"marca con 300mb saindo do modem" connection-mark=Link_300mb \
connection-state=new new-routing-mark=link_300mb passthrough=no \
I’ve looked more into it but still don’t know,if i am behind pppoe pcc gets really slows from 100mb to 10mbs at best,but if i am using the management lan via vpn or cable connected it works fine,so i think that there is a problem in balancing connection trough the bridge.Since no one has said anything so far and its been almost 400 views maybe its just that this isn’t a viable way to load balance,if theres another way to load balance pppoe connection in a bridge to maximize even link usage it would be great to hear.
I would like to comment but as soon as you said filter rules on the bridge, I tend to lose interest.
If you meant IP firewall rules ( the normal ones) then I can look at the config…
Just looking pcc, however there are some things I dont understand.
You use 2.0, 2.1 and then some weird 5.3 setting out of nowhere???
Why are using the ! symbol for route-marks???
Why you use same name for connection mark and route-mark DONT! too confusing.
Try something a bit more conventional/normal.
First four rules for WAN1 and WAN2 ( traffic that comes in via WANx, will go out WANx - mostly for router service purposes or incoming lan server traffic )
The next 3 RULES, attempt to PCC network by realizing throughput difference 300 vs 1000 so emulating a 3:1 ratio ( 33%).
add action=mark-connection chain=prerouting connection-mark=no-mark in-interface=bridge
new dst-address-type=!local new-connection-mark=Link-1g-conn passthrough=yes
per-connection-classifier=src-address:3/2
new dst-address-type=!local new-connection-mark**=Link-300-conn** passthrough=yes
per-connection-classifier=src-address:3/1
per-connection-classifier=src-address:3/0
The last 2 provide the route marks for the LAN traffic.
add action=mark-connection chain=prerouting connection-mark=Link-300-conn
new-routing-mark=use_300mb passthrough=yes
add action=mark-connection chain=prerouting connection-mark=Link-1g-conn
new-routing-mark=use_1g passthrough=yes
Note1: you will need tables to match add fib name=use_300mb
add fib name=use_1g
Note2: ensure in your fastrack rule you add mark=no-mark
Yes i meant IP firewall rules,they’re pretty much the default ones with fast track disabled and some block to special servers on lan.
The pcc part was also my bad,i was using 2.0 & 2.1 to test(makes it easier to see distribution is a small network),but the distribution i will apply will be a 4/1 hence the 5.0 and so on,with 4 to the 1gb link and 1 to the 300mb,the reason i used the ! in routing marks was to make sure that the rule wouldn’t mark it multiple times(pretty useless since i match connection state but i was desperate).
The problems isn’t with mangling in itself,because when i use mangle rules the traffic gets distributed but from around 95mb it drops to 10mbs(using speedtest),some sites cant even load.
And that just happens if i enable bridge to use ip firewall and enable mangle rules.
Will try enabling fast-track and enabling mangle,maybe it works.
Also changed the names for clarity sake,thanks for the suggestions.
These are my firewall rules,if i enable for bridge to use ip firewall rules the download speed gets bumped from 95mbs to around 10mbs.
From what ive seen if you’re bellow 25 firewall rules it shouldn’t be that bad of a drop.
I should fix your rules, they sucketh!! also on the fastrack no need to disable just add connection-mark=no-mark
You go to trouble to allow all full access to router on input chain, not recommended… should only be the admin.
All users only need access typically to DNS services and sometimes NTP for the smart switches, APs.
add action=drop chain=forward comment=“drop all else”_
NOTE: If you have additional traffic you need to pass, add it where the ****** are located.
Common needs are a shared printer or the admin needs access to the entire LAN.
Thanks for the new rules,but since clients use pppoe they cant really access mikrotik router anyway,implemented some parts of it because better security is always a good thing.But it didn’t really affect my problem with slow download speed when using bridge and ip firewall?,i didn’t think it would because the rules don’t do anything to freaky,but i really wanted to make this work so i could load balance my clients since i have one link just as a fail over and the waste doesn’t really make me happy,as i thought the problems don’t seem to be in the mangle rules.But this set of firewall rules didn’t do it either?maybe i should make the connection coming from the bridge(pppoe) avoid all the other firewall rules or something?
