I had configured PCC with 4 WAN links successfully, and the fifth WAN link for web browsing only on RB450G. Today, I used the same configuration on RB2011, but did not work at all.except for load balancing via PCC. browsing did not go to fifth link at all.
Is this related to RB2011 that has two internal switches or what’s the case here?
Hello Pukkita,
you are right…
I just noticed a big mistake i did…after 3 days of leaving the router and now with clear mind i found the conf mistake. It was very easy and subtle conf that any one could do that without paying attention. May be because i am getting old. hahahahah
the mistake was that instead of puting dst.port 80 and 443, i configured srt.port 80 and 443.
after fixing it…everything went smooth.
