Dear All,
I have Mikrotik PPPoE Server with 3 LAN cards. (Max interface support in this pc is 3)
1 interface for LAN users / pppoe, ip = 172.16.0.1/16
2 interfaces for WANs, for PCC Load Balancing.
DHCP Pool for LAN Users = 172.16.0.10-172.16.0.255
PPPoE Pool for PPPoE Users = 10.0.0.1-10.0.0.255
Now I want to Add SQUID Proxy Server, so all HTTP request can be redirect to SQUID server.
(Note: Currently SQUID (in transparent mode) is on same Subnet as LAN users, SQUID IP is = 172.16.0.2, (Squid have 2 lan interfsace, one for lan, one for WAN connected with isp) I know its not secure to place Squid in user Subnet, But I want it this way for a time being, )
What rules need to be added ? Will PCC be a problem in forwarding HTTP request to squid ???
I have tried this rule but its not forwarding any request to SQUID. Its counting very little packets, but when I check squid logs, I don’t see any actvity, SQUID is working fine in transparent mode if I directly access it via user end (pointing proxy in browser or by defining default gw to squid), its connectivity is ok.
add chain=dstnat src-address=10.0.0.1/24 dst-port=80 protocol=tcp action=accept
add chain=dstnat src-address=10.0.0.1/24 dst-port=80 protocol=tcp action=dst-nat to-address=172.16.0.2 to -port=8080
Is PCC having some problem with redirecting rule ?
~ Mickey Mouse ~
