PCC with Two input Interfaces
Hello everyone,
I am trying to do a PCC for load balancing. I have succeeded using the wiki example with one local interface. Now there is a modification with my network, I have introduced another local interface. How do I modify my PCC config to allow traffic coming from this interface enjoy the load balance?
thanks, I’ll appreciate your help
/ ip firewall mangle
add chain=input in-interface=LOCAL2 action=mark-connection new-connection-mark=LOCAL2_conn
add chain=input in-interface=LOCAL3 action=mark-connection new-connection-mark=LOCAL3_conn
add chain=output connection-mark=LOCAL2_conn action=mark-routing new-routing-mark=to_LOCAL2
add chain=output connection-mark=LOCAL3_conn action=mark-routing new-routing-mark=to_LOCAL3
add chain=prerouting dst-address=172.16.5.64/28  action=accept in-interface=LOCAL
add chain=prerouting dst-address=196.255.62.224/28  action=accept in-interface=LOCAL
add chain=prerouting dst-address-type=!local in-interface=LOCAL per-connection-classifier=both-addresses:2/0 \
    action=mark-connection new-connection-mark=LOCAL2_conn passthrough=yes
add chain=prerouting dst-address-type=!local in-interface=LOCAL per-connection-classifier=both-addresses:2/1 \
    action=mark-connection new-connection-mark=LOCAL3_conn passthrough=yes
add chain=prerouting connection-mark=LOCAL2_conn in-interface=LOCAL action=mark-routing new-routing-mark=to_LOCAL2
add chain=prerouting connection-mark=LOCAL3_conn in-interface=LOCAL action=mark-routing new-routing-mark=to_LOCAL3
/ ip route
add dst-address=0.0.0.0/0 gateway=172.16.5.65 routing-mark=to_LOCAL2 check-gateway=ping
add dst-address=0.0.0.0/0 gateway=172.16.6.65 routing-mark=to_LOCAL3 check-gateway=ping
add dst-address=0.0.0.0/0 gateway=172.16.5.65 distance=1 check-gateway=ping
add dst-address=0.0.0.0/0 gateway=172.16.6.65 distance=2 check-gateway=ping
/ ip firewall nat
add chain=srcnat out-interface=LOCAL2 action=masquerade
add chain=srcnat out-interface=LOCAL3 action=masquerade
you have to local interface(client)???ot what
Just duplicate the PCC lines for the second LAN interface. Your first LAN interface appears to be called LOCAL. If your second LAN interface is called LAN2, you’d keep this:
And add directly below it:
add chain=prerouting dst-address-type=!local in-interface=LAN2 per-connection-classifier=both-addresses:2/0 \
add chain=prerouting dst-address-type=!local in-interface=LAN2 per-connection-classifier=both-addresses:2/1 \
And ensure that those lines are directly below one another, and before the mangle rules that set the routing marks.
I tried to duplicate my PCC rules for the second LAN (WIFI). Below is my new mangle rules:
add chain=prerouting dst-address=172.16.5.64/28  action=accept in-interface=WIFI
add chain=prerouting dst-address=196.255.62.224/28  action=accept in-interface=WIFI
add chain=prerouting dst-address-type=!local in-interface=WIFI per-connection-classifier=both-addresses:2/0 \
add chain=prerouting dst-address-type=!local in-interface=WIFI per-connection-classifier=both-addresses:2/1 \
add chain=prerouting connection-mark=LOCAL2_conn in-interface=WIFI action=mark-routing new-routing-mark=to_LOCAL2
add chain=prerouting connection-mark=LOCAL3_conn in-interface=WIFI action=mark-routing new-routing-mark=to_LOCAL3
/ ip route
add dst-address=0.0.0.0/0 gateway=196.255.62.225 routing-mark=to_LOCAL3 check-gateway=ping
add dst-address=0.0.0.0/0 gateway=196.255.62.225 distance=2 check-gateway=ping
/ ip firewall nat
After this, everything slows down drastically. The two Internet interface (LOCAL2 & LOCAL3) was now dragging, I could hardly hit 200kbps (the two interface is hit 1.5Mbps when working fine). It picks up anytime I disable LOCAL3 failing over to LOCAL2. what could be wrong pls?
I think, the problem was not MT, I restarted the second internet interface, everything now works fine.!
Thanks fewi for your assistance
Glad it’s working.
