PCI card TP-LINK TL-WN653AG. Does it work on ROS v2.9?
Did anyone tried to use TP-LINK’s PCI card TL-WN653AG?
Here are specifications:
802.11a/b/g
up to 108 Mbps data rate
~100mW
RP-SMA connector
http://www.tp-link.com/products/product_des.asp?id=27
Unfortunately I can’t find any info about chip. Could it be Atheros that is supported in ROS?
looks like it’s atheros: http://forum.wifi.hr/oglasnik/ptlwn653ag-abg-t141.0.html
but i’m not sure if it will work in RouterOS, maybe somebody has tested it.
Thanks. It looks like it’s AR5413 chipset. That should be supported by ROS v2.9. And I can guess that it’s Atheros chip because of data rate up to 108Mbps. That can only have cards with Atheros chip.
