PCI-E Nic questions
I have a router I’m trying to put together. Does anyone know if the Intel Pro/1000 PT Quad Port nic works with the RouterOS?
Also, does anyone know if the PCI-E 16x slot where the video card goes work for anything other than video cards?
I tried to use this setup and so far the nic won’t recognize. I have a bunch of other intel cards and they work great only this one seems not to be working in the 16x port that i have on the motherboard.
Thank You,
Matt
1- Try the newest version of MT
2- PCI-E X16 can compatible with X8 X4 X1
Tried the newest version of MT and it still didn’t work. I got my hands on several other motherboards and tried the card in all of those also. Still no go. I plugged the card in a Microsoft box and the card recognizes. I have another core router that i use and that box has the Intel 1000 PT Dual Port PCI-E nics and they work great. This one i have now is the exact same model just it has 4 ports instead of 2 on the nic.
MT however doesn’t show any using this card.
Matt
I’m also interested in the PCI-E Intel Quad Port (88215) card working with MikroTik.
Hardware/Software:
Dell PowerEdge 860
128MB CF in Addonics SATA adapter
MikroTik 3.0rc4
Well the main reasons i ask about this card, is I purchased dual port Intel PCI-E PT nics and they worked great. This one didn’t.
The main problems i have is MT list of supported nic. Is almost non of the nics they have listed are available for new now. Atleast the dual and quad port nics.
Matt
