PCI Ethernet Cards Not Detected
Dear All,
I have 3 NICs on the PC I just configured as Mikrotik Router. Unfortunately only the in-built NIC on the Motherboard was detected by mikrotik while the other two are not detected.
I am using an Intel Motherboard on a Compaq Deskpro EN
I am handicapped as I cannot format and reinstall the RouterOS because I have a Level 4 license registered with the HDD.
Can somebody help me out?
Regards 2 u all.
The EN has an Intel NIC onboard I belive..
You would be best off using a dual port Compaq / Intel NIC.
You can get them off the net from $10 to 30$ the Compaq 64Bit dual 10/100 NIC will work in a 32bit slot.. I do it all the time.
Craig
Thank you Craig,
You are right it has an Intel NIC. But do you think if I disable the on board NIC, the Dlink cards I bought will work?
I have 2 units I am working on and I already have 5 NICs on ground.
Winsome
No..
Are all the NICs tha same ?
Or are the ones that dont show on their own board..
My guess is they arrent a supported chipset.
Craig
ROS v3 has new intel drivers, maybe you can try the new beta?
No more headache, just change 2 of the NIC with supported version. Try some used-NIC, it’s better supported rather than new one. If you want to use DLink, trys 538-tx or 530-tx both are good.
