I have problem in displaying ethernet in routerOS 6.36 ( NIC is connected through PCI slot and it is 10G interface)
it is showing in system>resource>pci> pr details as
but in interface>ethernet is not displaying
kindly help
kindly help
Check in Supported Hardware if your 10G card is actually supported by ROS.
Displaying it on System > Resources > PCI just means being electronically recognized, not that the OS supports it.
is there any to request Mikrotik team to support the hardware
You can always try mail to support@mikrotik.com
When your hardware is not supported, the easiest/fastest way is to install a hypervisor that supports the hardware
and run RouterOS under that hypervisor.
