Hi all,
a., Is there any PCI or miniPCI card over 6 GHz compatible with mikrotik?
b., Or even compatible with other linux-based/open sourced operation system?
c., If one of the above exists then what about manufacturers and prices?
Thanks,
gyoztes
Hi all,
Thanks,
gyoztes
RouterOS supports 802.11a,b,g
frequencies that you are talking about, are outside of these standards, and can’t work unless that miniPCI has some kind of frequency converter inside (like the UBNT cards)
