I’m looking for a budget 10G SFP+ NIC (can also be dual-port) that can be used in a normal PC (ie. it’s not server hardware).
I’ve tested the “HP 10GbE Network Adapter NC523SFP / SFP-H10GB-CU3M, 2 x SFP+, PCIe x8”,
but it’s designed to be used in server hardware as it requires active cooling, and gets also very hot.
So, either a new NIC, or an alternative solution using a cooling fan for the above NIC,
or perhaps a standalone mini cooling fan that can be inserted into an empty slot next to the NIC.
Anybody else had this same problem and can give some tips, links? Thx.
I’m also using Mellanox ConnectX-3 (and some older ConnectX-2) cards, they are working perfectly fine with no additional cooling in my PCs or Workstations.
