I am running Mikrotik RouterOS 2.8 on the routerBoard 230 outdoor kit. I am trying to install some generic PCMCIA Ethernet adapter in it. I insert the card, I boot it up. I get a power light on the card, and when I plug it into the switch I get a link light.
However, when I “/interface print” I see no mention of the card. What gives? Any tips on making this card available? Am I missing something?
You have to make sure you have the correct PCMCIA Adaptor. I have found that not all supported my MT. I assume you are using a PCI adaptor? Why not use a PCI LAN Card?
You will also need to check to see if the chipset of the PCMCIA card is supported as well.
