PCQ + 6.39rc45 breaks system
Hi, I’m running 6.39rc45 on an RB751U. My Quick Set mode is CPE, and I’m running a pseudo bridge with a Buffalo router that runs Tomato.
First of all, I’d like to report that the wireless repeater setup for my environment works successfully with this build, and it didn’t on 6.38, so thanks for that.
However, I’m trying to create a PCQ with the following command:
/queue simple add max-limit=500k/2100k name=PCQ queue=pcq-upload-default/pcq-download-default target=192.168.1.0/24
The command applies successfully, and I can verify in WebFig that the queue has been created. But after about 30 seconds the whole thing grinds to a halt and later tries to reboot, but it never successfully manages to reboot again. It is no longer is pingable, and power-cycling it doesn’t help. The only way to fix it is by using the factory reset procedure.
This bug is reproducible every time, I’ve tested it about 6 times with different subnets.
Thanks for the help.
Got a fast reply from Mikrotik support:
(MikroTik Support) wrote:
We have managed to reproduce such issue and will fix this in next rc release.
Sorry for any inconvenience caused.
Best regards,
